Well that didn't last long.
If it plugs in, post it here.
EricTheRed
Post by EricTheRed »
My little 5 litre copper alembic still normally runs on gas.
A couple of runs ago i bought a good quality hot plate. Solid plate.
I bypassed the thermo switch and connected it to my 4KW power controller.
Worked like a dream for the first run.
Second run a week or two later ie today it gave up shortly after reducing power to 30%
Not sure the little 1500w hot plate elements can deal with running at lower voltages for extended periods of time.
One learns as one goes.
Ta
Life has gotten interesting!
Re: Well that didn't last long.
Now that it has cooled down, does it heat up again? How many amps does it draw?
EricTheRed
Cooled.
Plugged in.
Pulls nada amps
Going to open and see it is rotten wires
EricTheRed
Wiring not burnt.
All connections tight and solid
There are hot plates for sale that don't have solid plates. You still have to bypass their simmerstat to run a still on them.
Sporacle
Post by Sporacle »
Dumb question, Is it the SCR Eric?
EricTheRed
Sporacle wrote: Sun Dec 04, 2022 1:42 am Dumb question, Is it the SCR Eric?
No. I plugged the hotplate directly into the wall. Nada
EricTheRed
NZChris wrote: Sun Dec 04, 2022 1:40 am There are hot plates for sale that don't have solid plates. You still have to bypass their simmerstat to run a still on them.
Hard to find here in south africa
Ben
Post by Ben »
You need to ohm out the element and see if it failed. Should be something like 9.6ohms resistance (verify that number, I made some assumptions). If that is good you have a different problem, something else needs bypassed.
They are hard to find in NZ too, so I get them out of China.
Demy
Post by Demy »
If you have a multimeter you could check the continuity between the poles of the plate, if the plate is burnt you will have no continuity
