ADA still
juana_b
ADA still
Post by juana_b »
I'm going to be building a rig for a friend. It will be used by someone who is blind. I have a pretty good idea of what it'll be and it won't have a thermometer port. But, I'm looking for any ideas on how to go about getting braille on copper. I think that would be a nice touch.
― Charles Ives
Steve Broady
Re: ADA still
Post by Steve Broady »
I would probably make a separate plate with braille embossed in from the back, then solder or rivet that to whatever you want it on. Or 3D print a braille label and glue it on, so that it won’t be so hot.
elbono
Re: ADA still
Post by elbono »
My first thought was OMG!!
But, my grandfather and uncle were blind and it was amazing what they could do. They had all kinds of methods accomplish what I did by sight. Their memory was incredible.
Ask them what they want, my uncle was very easy to insult by accommodating him in ways he didn't need.
I would focus on safety issues they can't detect without vision.
One of my favorite memories is my uncle mowing the lawn, knew how many steps to the lot line, turn around and know he got to the drive when the mower started throwing gravel. My grandfather would sit on the stoop in case he got lost.
Re: ADA still
My first thoughts please keep us informed on this process as personally I don’t know how it can be done.
Re: ADA still
Punch it into the copper sheet before you start forming it.
Re: ADA still
Post by The Baker »
I don't know about safety for blind distillers.
But nowadays I am sure there a lot of pieces of equipment that will talk to you; give audible information...
Or that can be checked by touch, like say how full something is...
Dougmatt
Re: ADA still
Post by Dougmatt »
Wow. I am so impressed that you are doing this. I wish I had a lot to add, but the only things that come to mind are
a) keep it simple - no reason for a lot of complexity, my still is 2 pieces with a gasket so I would try to minimize the number of sections that would require breakdown
B) temperature - since temp is used in fermentation and mashing, why not get a talking thermometer (ex: https://www.aph.org/product/talking-coo ... ermometer/ ) and a way to insert it in the still. I know everyone thinks temp is a “bad” thing, but in this case it would represent an audible queue for things like how far from the point of distillate production.
On getting the braille on copper, I like the soldered on plates idea. Stamping could work, but might create a weak spot.
If you are looking for “lots” of labels, there are high temp label materials available from several manufacturers (Brady is an example). Not sure if they have a size to fit your label maker.
Another thought is to audio label things. Wondering if the “talking tin” could be purposed for what you are thinking ( http://www.braillebookstore.com/Talking-Tin.1) . Just a thought.
That’s it. No more reading!
Salt Must Flow
Re: ADA still
Post by Salt Must Flow »
Curious ... what would braille be useful for? I can't think of any use for it on parts. If I touched any part of my still while wearing a blindfold I'd be able to determine what it is immediately. Now if it were part of a controller that would make sense. Perhaps a 0%, 25%, 50%, 75% and 100% power indicator maybe.
If you have any files that need 3D printed, I can print it for you. My only concern would be heat on risers/columns as that wouldn't be practical. Let me know if you need any thing printed.
Like elbono said, safety first. I'd do some runs with him first and find out what safety features need solidified. He may need temp alarms, but even something that simple may not be that simple for someone who is blind with digital devices though I'm IGNORANT regarding devices that may or not be manufactured for the blind.
What is your friend interested in making? I'm thinking from start to finish and like Bushman said, I don't know how this can be done. At least not with some help. It's a hell of an endeavor.
zach
Re: ADA still
Post by zach »
I use a digital meat thermometer with an audio alarm and place the sensor just below my condenser on a LM rig.
I set the alarm set point for 140 F, so I make sure I am paying attention as things warm up.
If I had no vision, I'd also want an alarm on the condenser outlet cooling water to give me another alarm. A cooling water flow switch to enable the heater might be another safety that is worth it in this case.
StillerBoy
Re: ADA still
Post by StillerBoy »
juana_b wrote: ↑Sun Jan 08, 2023 1:40 pm I have a pretty good idea of what it'll be and it won't have a thermometer port.
It would help if you could clarify what is meant by the statement above..
Everyone is shooting in the dark or making assumptions without what type/style of still is considered to built.. a pot still style is probably possible (depending on the person's abilities), but a reflux column, that has many more items that need attention..
Mars
– Albert Einstein
juana_b
Re: ADA still
Post by juana_b »
This will be a pot still to replace the Vevor they currently use on propane.
― Charles Ives
Re: ADA still
I assumed from your OP that you were wanting to put a name on the still. Are you asking for more than that, like how to build one and run it?
Re: ADA still
Post by The Baker »
juana_b wrote: ↑Mon Jan 09, 2023 7:02 pm This will be a pot still to replace the Vevor they currently use on propane.
They already distil despite blindness?!
juana_b
Re: ADA still
Post by juana_b »
NZChris wrote: ↑Mon Jan 09, 2023 9:49 pm I assumed from your OP that you were wanting to put a name on the still. Are you asking for more than that, like how to build one and run it?
Nope, just looking for ideas on putting braille on copper.
Frankly I was thinking of hiding messages to break balls.
― Charles Ives
juana_b
Re: ADA still
Post by juana_b »
The Baker wrote: ↑Mon Jan 09, 2023 10:01 pm
Yes. For years now.
― Charles Ives
juana_b
Re: ADA still
Post by juana_b »
I did get a good chuckle out of them when I called it the ADA still. Americans with Disabilities Act for those not in the U.S.
― Charles Ives
Re: ADA still
I searched for braille letter punches, but came up empty handed. I suspect that you just have to do your homework and get it right the first time, punching from the inside, backwards, without any embarrassing mistakes.
juana_b
Re: ADA still
Post by juana_b »
NZChris wrote: ↑Mon Jan 09, 2023 10:35 pm I searched for braille letter punches, but came up empty handed. I suspect that you just have to do your homework and get it right the first time, punching from the inside, backwards, without any embarrassing mistakes.
My search came up empty too, but I'll keep looking and thinking.
I like Steve's idea of a separate plate. I also thought about trying to make bumps freehand with 15% silphos.
After all, it doesn't need to look pretty.
― Charles Ives
juana_b
Re: ADA still
Post by juana_b »
― Charles Ives
elbono
Re: ADA still
Post by elbono »
My uncle used a slate and awl to write braille on paper. https://en.m.wikipedia.org/wiki/Slate_and_stylus
His was like the one at the top of the pic on that wikipage, always in his pocket with a 3x5 index card to make notes
The awl probably wouldn't work for copper but a modified punch and small hammer would work with the slate on thin copper sheet that you can solder to pieces.
You have to work right to left and make the characters backwards.
A neighbor that teaches at the regional school for the deaf and blind tells me it's all done on computers and machines now but I doubt you want to invest in that.
https://en.m.wikipedia.org/wiki/Braille_embosser
bunny
Re: ADA still
Post by bunny »
juana_b wrote: ↑Wed Jan 11, 2023 3:36 pm This has some promising links
https://www.engraversjournal.com/articl ... -ada-signs
Contact Otis Elevator in Honolulu.
They may have some used panel numbers or be able to point you in the right direction.
juana_b
Re: ADA still
Post by juana_b »
I did find a raster braille drill bit and brass balls that could be soldered too.
"Do not touch" is the first phrase that came to mind.
― Charles Ives
elbono
Re: ADA still
Post by elbono »
Put "I told you so" next to the "do not touch"
EricTheRed
Re: ADA still
Post by EricTheRed »
What about 3D printing?
Life has gotten interesting!
Ben
Re: ADA still
Post by Ben »
I would bet other than the control panel there wouldn't be much need for braille, even then the control panel could be one knob. Once the operator gets used to the orientation of the still, the sound the boiler makes and the location of the various condensers they will be able to operate it all by feel/sound. A few audible alarms could be useful, Auber ez-boils have them built in, and the knob is tactile.
Insulation on the boiler would be nice, in case it gets bumped into or leaned on by accident.
Fix the valve locations, make sure they are near the appropriate condenser and that there are no leaks, that way the operator only has to be in proximity of the still.
There could be some nice wizardry with float switches to enable an alarm for receptacle overflow.
Quality quick connects for the water lines to ensure there won't be leaks would be a nice touch.
Make sure the water lines aren't a trip hazard.
An easy to use/navigate system for cut jars, braille tabs with numbers for each jar.
Easy to use storage for empty jars/lids.
Easy way to meter water and white to cut for tasting/nosing/blending.
juana_b
Re: ADA still
Post by juana_b »
There may be a place for 3d printing(and thank you salt for the offer), but with the preliminary discussions we've had about this rig, it's not going to be complicated in any way other than adjustments to the layout. Like elbono's uncle mowing the lawn. When someone gets used to a uh topography(?) it's easy to mess that up with a layout that's a couple of inches off. How many times have you stubbed a toe on a chair that was out from the counter a bit?
And we can f'n see. :lol:
As of now, the goals are to keep it simple and flexible. You can definitely handle tri clamps if you can already assemble and disassemble a vevor blind.
I'll give a quick mention that I'm more nervous around some sighted folks than my friend when shooting.
If you've never spent time with blind folk, you'll have some of your preconceived notions blown away damn quickly.
Edit: And like elbono's family, there are some things that are impossible without sight, and these may hurt one's pride if even the offer to help is extended. For example, I made a visit a while ago and brought an alcometer to check proofs on cuts from many batches. I offered, there was hesitation, approval given, and every one was within 5% of what my friend estimated.
― Charles Ives
Stonecutter
Re: ADA still
Post by Stonecutter »
Kudos to you and your friend Juana :thumbup:
It’ll be awesome to see the results.
-Thomas Paine
Re: ADA still
Stonecutter wrote: ↑Thu Jan 12, 2023 9:19 pm It’ll be awesome to see the results.
Ha ha :D
They won't be worried about louche and misting in their gins and whiskeys like a lot of the sighted folks that come here looking for help to fix what is actually a good thing flavor-wise.
juana_b
Re: ADA still
Post by juana_b »
:clap: You have that spot on NZChris! Not too long ago I had a rum that looked hazy even from across the room but it tasted as a young molly rum should.
Gave 'em some used oak from my last bourbons to put some on.
Now you have me thinking about how I'd blend cuts blindfolded.
― Charles Ives
Stonecutter
Re: ADA still
NZChris wrote: ↑Thu Jan 12, 2023 10:14 pm
Ha ha :D
No pun intended :shifty:
But very good point NZC
-Thomas Paine
