new to me parrot
new to me parrot
just finished this up.
Re: new to me parrot
Prettiest Polly I’ve seen in long while ….water cooled as well
Nice work Eric
Nice work Eric
- Dancing4dan
Nice work!
Marcus Aurelius
Marcus Aurelius
thanks guys look forward till it gets a couple years of patina.
Nice work!
please do us all a favor and post the images to this site, not a hosting service. if I tap the image to get a better look I end up redirected to a hosting service advert link. Strip your data from the image before you post, but that is too nice of work to be lost to an image server change or broken link. That is one of the nicest parrots I have seen yet!
yes i read the rules on pictures no help to these blind eyes.
Nice work mate!
"Homer J Simpson"
"Homer J Simpson"
Eric , I’d also suggest you learn how to upload pics direct to forum using the attachment method .
PM me if you need more help .
You do good work . I hate to see topics down the track with no pics due to external hosting services no linger providing .
Beautiful work! Mark me down as wanting one!
That’s it. No more reading!
Ecir54, very pretty. Do you have a picture of the top of the column?
ok got pics figured but couldn't get one to rotate right
Buffalo see here
viewtopic.php?p=7701427#p7701427
Buffalo see here
Very nice craftsmanship! Sure is pretty.
mod the parrot a little. lowered the reducer and changed the support. Have 20 gallons to run so will put it to use tomorrow.
That is one amazing little parrot/water cooler! Well done!
well that didn't work out the way i wanted it to. Vent was short for starters, added a swaged piece of pipe to extend it but still couldn't get the meter to float right. Think vent was to small too.
Maybe pull the thermo out of the vent
You could also have the parrot empty into a small graduated cylinder and float the meter in that
Hang on.....
Hopefully you can fix it as it's a great looking bit of kit.
My parrot that has now been dismantled had a one inch tube for the meter,
Can you get a narrower alcometer? But having seen your build skills I'm sure you'll have it fixed in no time
Good luck
Hang on.....
Good luck
now that thinking if vent is above upper needle valve it should work.
Hi eric .
It’s a bit hard to work out the relative height's from the camera angle and perspective , but wondering how high is the bottom of the vent Tee above the overflow tube in the parrot ? I’m wondering if the overflow tube to alcmeter clearance is too small , the alcohol might be backing up as it trys to get past . That would then start to block off the vent pipe with rising liquid negating any gains from the vent .IE you would start to get surging problems and alc meter bounce .
I’d agree with Sporicle that maybe upsizing the overflow tube diameter ,or getting a skinnier Alc meter should fix things
the bottom of the tee is equal to the overflow tube.
used this one for years without anyone problems. Same sizes of copper used, the difference being this one is open to the atmosphere.
