Placement of mash transfer pump
- Stonecutter
I’m going to be doing my first “large” batch mashing this St. Patrick’s Day. It’ll be in the fashion of a Single Pot Still Irish Whiskey .
24 gallon ferment. Off the grain
22 lbs. flaked Barley
24lbs. Malted Barley
5lbs. flaked Corn
US05 yeast
I’ll mash in the garage but my fermenter sits in the basement and rather than carry buckets up and down the stairs I’d like to use the Blichmann riptide pump to transfer from the garage down a set of stairs and into the fermenter.
First things first. I’m not even sure I’ll have the head pressure. Blichmann claims 7 GPM with 21’ of head pressure and as the mash tun is close to the stairs almost all fluid travel will be downhill, however it’ll be about a 40’ run.
My main question is pump placement. I think gravity will be my friend here and that the weight of the mash will be able to push most of the liquid down the stairs rather easily so my reasoning tells me to have that pump either midway between the mash tun and the fermenter. If not closer to the fermenter. What do you guys think?
5lbs. flaked Corn
US05 yeast
-Thomas Paine
-Thomas Paine
Re: Placement of mash transfer pump
As long as the pump is primed, you should be able to pump it UP 2 flights of stairs. 21' of head at 7 gpm is pretty good. Do they provide a pump curve graph?
― Charles Ives
― Charles Ives
Stonecutter wrote: ↑Sat Mar 04, 2023 11:10 am
Is the pump even necessary ? If going from high to low perhaps all you need is to just start a siphon.
________________
Found it
at 18' of head it'll be about 1 gpm. at 6' head it'll be about 6 gpm.“Awards are merely the badges of mediocrity.”
― Charles Ives
― Charles Ives
- Stonecutter
Ya beat me to it Juana! It’ll be a 1/2” diameter hose
-Thomas Paine
-Thomas Paine
- Stonecutter
Yeah, I could definitely do that as well. I think I could use something to prop up the hose at the fermenter to make it work. I’ll try both. I got this fancy pump so I’m itching to try it out
Edit: I’ll put the pump near the fermenter and see how she goes
-Thomas Paine
-Thomas Paine
Without seeing the liquid level of where it's pumping from, be careful not to run it dry. You'll be close to a 3 min transfer time if their curve isn't BS.Stonecutter wrote: ↑Sat Mar 04, 2023 11:59 am I’ll put the pump near the fermenter and see how she goes
Edit: 50' of 1/2" pipe holds .5 gal of volume, according to that curve it'll take -5 seconds to move that.
Anytime you see generic competitor numbers, question the data.
― Charles Ives
― Charles Ives
- Stonecutter
Good point Juana. 3 minutes would be awesome, I’ll be happy if it works at all! I’m sure I’ll have to use a bucket for the last little bit of it but with a little luck o’ the Irish we should be able to save a few vertebrae.
I’ll have my cousins over. Identical Twin Brothers about as goofy as they come but between the three of us we should be able to bungle our way through the day.
One of us watch the pot, one watch the fermenter and the other can get the beer and pour the shots.
-Thomas Paine
-Thomas Paine
Please tell me their names aren't Daryl.
― Charles Ives
― Charles Ives
- Stonecutter
No Sir.
-Thomas Paine
-Thomas Paine
- Twisted Brick
LOL! I miss the Bob Newhart show...
- Stonecutter
I knew I missing something. I’m too much of a young punk
-Thomas Paine
-Thomas Paine
skip to 2:30
― Charles Ives
― Charles Ives
- Stonecutter
Haha!! Close. They’re a bit more put together than that. Just a bit though
-Thomas Paine
-Thomas Paine
- Salt Must Flow
Since the mash will be flowing down to the basement, it will siphon downhill without a pump. I would use the pump at the mash ton and it will not only prime the siphon, it will likely push it faster than the mash would siphon on its own.
Head pressure charts are usually for pumping upward. Are you primarily asking about pumping the fermented mash back up to the garage to distill?
+1Salt Must Flow wrote: ↑Sat Mar 04, 2023 7:03 pm Since the mash will be flowing down to the basement, it will siphon downhill without a pump. I would use the pump at the mash ton and it will not only prime the siphon, it will likely push it faster than the mash would siphon on its own.
upward and for line losses, and your line loss will be insignificant next to an upward vertical push.
― Charles Ives
― Charles Ives
- Stonecutter
Thanks for the response Salt. I really appreciate the input I’m not super familiar with pumps so it’s nice to get some solid suggestions.Salt Must Flow wrote: ↑Sat Mar 04, 2023 7:03 pm Since the mash will be flowing down to the basement, it will siphon downhill without a pump. I would use the pump at the mash ton and it will not only prime the siphon, it will likely push it faster than the mash would siphon on its own.
To clear things up. I’m primarily asking about the best placement of pump from the mash tun in the garage to the fermenter downstairs. I distill on the same level as the fermenter so no worries there.
-Thomas Paine
-Thomas Paine
- Salt Must Flow
Yeah these types of pumps are meant to push so I would absolutely put it close to the mash ton.Stonecutter wrote: ↑Sat Mar 04, 2023 7:14 pmThanks for the response Salt. I really appreciate the input I’m not super familiar with pumps so it’s nice to get some solid suggestions.Salt Must Flow wrote: ↑Sat Mar 04, 2023 7:03 pm Since the mash will be flowing down to the basement, it will siphon downhill without a pump. I would use the pump at the mash ton and it will not only prime the siphon, it will likely push it faster than the mash would siphon on its own.
- Stonecutter
Awesome. I realize I could’ve asked the manufacturer but honestly I didn’t think about it till just now. It’ll be a little victory for me in my shed if everything works out and I’ll keep you all posted. Super stoked to try out this whiskey style.Salt Must Flow wrote: ↑Sat Mar 04, 2023 8:03 pm Yeah these types of pumps are meant to push so I would absolutely put it close to the mash ton.
Cheers Mates
-Thomas Paine
-Thomas Paine
Mash tun.
So, you're going to be transferring wort instead of a thick mash?
- Stonecutter
Yes Sir. False bottom with a pickup tube.
Fermenting off the grain and recycling the grains as best I can or feel the need to. I forgot to mention I’ll be using 3lbs of Rice hulls in my mash.
-Thomas Paine
-Thomas Paine
- Stonecutter
Alright ladies, gents and what have yous.
The mash is a brewing about ready to try and transfer this gloop. The rice Hulls are holding up fairly well. I’m not sure if the HBS sold me flaked oat or flaked Barley. It’s damn viscous. Fingers crossed here. No BIAB just a screen. Dog help us if this shit don’t come out the pickup tube.
Got Corn Beef ages Cabbage on the stove and the “Quiet Man” on the tube
HAPPY ST. PATRICKS DAY!!!
-Thomas Paine
-Thomas Paine
― Charles Ives
― Charles Ives
- Stonecutter
Well…. The whole plan is a flaming pile of dog shit on the carpet. I got good conversion but the pickup tube was completely useless. Lesson learned. Everything I read in the forum said to use a BIAB. I thought I could skirt the lessons learned by others. Nope
Anyway plan B in effect. Fermenting on the grain for the first time. Time to see what the conical can throw me in the 7th inning
-Thomas Paine
-Thomas Paine
That's the thing with this forum Stonecutter........many others have usually made the mistakes for us, before we even try, sometimes we still need to find out the hard way though.
On the other hand nothing ventured nothing gained, you can now be on the list of those who can advise NOT to do it that way....along with giving reasons why its not a good idea.
I also seem to remember once, a member saying he was going to build this wierd arse looking column thing with plates in it.............some said "WONT WORK"
He did it anyway.......out of that we ended up with hobby sized plated columns "the flute" , the rest is history, thank you Old Dog.
Moral of that one is "sometimes it pays to not listen and to find out for your self".
One question.Stonecutter wrote: ↑Fri Mar 17, 2023 3:37 pm
Does the conical fermenter have a big enough lid you can dip it out.
Stonecutter, I lauter my bourbon. And I never said it was easy. As Shady has said many times, “never underestimate corn’s ability to f_ck things up”. Because of the oils and proteins in the corn, it will turn into a pastey mess.
My mash tuns are 10 gallon vertical Coleman coolers with a pickup grid of copper with longitudinal slots (not just holes) in the bottom. I have a stainless steel perforated grate above the pickup grid as well, so there should be a small “basin” for the wort to accumulate below the grist. Still, the fine dust from the mash will work its way below the grate and build up as I’m recirculating the wort to build the mash tun’s filter bed.
But the grains will still form a thick “goop”, as you’ve called it. And as I begin runoff to the fermenters, the grainbed becomes like a “yoghurt” consistency. As I runoff, I have to make thin knife slices down into the grainbed to allow the sparge water to rinse the grains deeper into the tun. I’ve learned through practice that this helps keep the liquor draining. The depth of your grainbed will make it easier to sparge if it’s not too deep.
And the runoff will have some of the fine grain “dust” as it drains. However, it would still be pump-able with a centrifugal pump. I use a magnetic-drive (March) pump with the output “throttled” so it doesn’t suck the grainbed down in the mash tun. It is a bit of a “balancing act” and a complete lauter does take a long time. From the pump, the wort runs through a tube-in-tube (Liebig) chiller so it is cool and ready to pitch immediately, which I do as I’m filling the fermenters. The ferment is often active even before the fermenter is full and I’m done with the sparge.
So, don’t fret your process. But as we’ve said, corn (and rye) will mess you up. So, you have to work diligently to get your liquor into the fermenter. Corn grist is thick like a pudding and the rye liquor is sticky like glue. So, when combined you get something like a “spongey brick”.
This could be why many brewers just resort to fermenting on-the-grain and leave the squeezing to post-fermentation. Indeed, I’m in the small minority of us here who lauter our mashes.
- Stonecutter
Not sure what you mean by dip it out? Was looking at the conical this morning. This has been and is going to continue be an interesting learning experience.
Going to make sure I get notes taken down for this one. Taking notes is something I definitely need to improve on
SS did a little searching all I could find was info regarding counterflow leibig style wort chillers but no pictures. Care to share or PM some images? I had every intention of recirculating and sparging. I’ve done so in the past with a different setup. I believe my perforated false bottom just isn’t designed for such a high unmalted grain bill.
-Thomas Paine
-Thomas Paine
https://a.co/d/i6kSUaB
Here's one style of counterflow tube in tube that's common in small water cooled refrigeration systems.
― Charles Ives
― Charles Ives
- Stonecutter
https://fhsteinbart.com/product/counter ... erconvolu/still_stirrin wrote: ↑Sat Mar 18, 2023 5:48 am From the pump, the wort runs through a tube-in-tube (Liebig) chiller so it is cool and ready to pitch immediately, which I do as I’m filling the fermenters. The ferment is often active even before the fermenter is full and I’m done with the sparge.
Is this pretty much what you’re using? I like the idea. I might have to get me one of these things.
-Thomas Paine
-Thomas Paine
