Ordering parts
Ordering parts
so this is my first build. And I have been looking for parts. I want all copper. And I am going with 2 in all the way thru the vapor path as well as the condenser.
So I had been shopping all around and looking at prices.
Let me say I was very surprised to find what I feel is a great price on the 2 in pipe and 2 in fittings.
Plummersstock.com ... has very good prices on copper pipe. 2 ,3,4 inch type L. And very reasonable price on fittings as well.
So I just ordered
1 2" x 5 ' type L pipe
2 1/2" x 5' type L pipe
2 2" 90*
1 2"x 1/2" reducer
This is for my pot still head to go on my 15.5 gal feg.
I will be making a shotgun condenser for it as well.
Will be getting my end plates and baffles from
Twisted Brick. Looking forward to getting all my stuff in and get this thing build.
Still left to order...
PTFE gaskets
2" triclamps
I will be making my own easy flanges..
I'm sure there will be more... But I've already spent enough money today. Lol part of the fun. Rabbit hole is getting deeper.
So I just ordered
2 2" 90*
1 2"x 1/2" reducer
PTFE gaskets
2" triclamps
Re: Ordering parts
Check prices for 2” DWV. It’s a thinner wall but still fits the fittings. And DWV will hold many times the pressure your still will see. Also, type M is plenty thick too for all your other piping.
Re: Ordering parts
Thanks for the suggestion. But I already but the bullet so to speak. But will be building a reflux column at some point in the near future. I will look at the DWV and type M for that though. Thank you sir.still_stirrin wrote: ↑Wed Mar 22, 2023 10:41 am Check prices for 2” DWV. It’s a thinner wall but still fits the fittings. And DWV will hold many times the pressure your still will see. Also, type M is plenty thick too for all your other piping.
- Salt Must Flow
Re: Ordering parts
I don't see any elbows or unions in your list though I see you said, "I'm sure there will be more". Have you drawn out your design? You'll need to set the angle of the product condenser which will require elbows, unions (or Tri-Clamp connections).
Re: Ordering parts
Yes I ordered two elbows. So that's already taken care of. I was going to make my own flanges. Unless that turns out not to work. Then I'll have to order some. As well as triclamps. Thank you sir.
Re: Ordering parts
Welp. I retract my statement.. plummersstock.com is not a good place to do business with. They just emailed me and said the price was wrong for my 2" pipe. And are cancelling my order. Bad business in my book. Oh well. Back to the drawing board in ordering my parts...
I did email them back and say that is unacceptable and I expect them to honor the price they originally quoted me. I dought they will. I even threatened to report them to the department of consumer affairs and federal trade commission. Oh well back to ordering parts...
- Salt Must Flow
Re: Ordering parts
If you have a Menards store near you, you can order pipe through them if they don't have it in stock at your local store. I ordered pipe through them and picked it up when it arrived. You can also check your local store's inventory online too.
- Deplorable
Re: Ordering parts
Might as well add a 2" T. Then you need only cap it for a pot still, but you'll be all set for a reflux still.
You already bought enough pipe to build a 2" modular CCVM and shotgun condenser.
Re: Ordering parts
Yep good call. I'm sure I'll want to run reflux column. I'll add it to the growing listDeplorable wrote: ↑Wed Mar 22, 2023 2:20 pm Might as well add a 2" T. Then you need only cap it for a pot still, but you'll be all set for a reflux still.
Re: Ordering parts
We do have a Menards store in the next town over. I'll check them. Thank you sir.Salt Must Flow wrote: ↑Wed Mar 22, 2023 1:56 pm If you have a Menards store near you, you can order pipe through them if they don't have it in stock at your local store. I ordered pipe through them and picked it up when it arrived. You can also check your local store's inventory online too.
Re: Ordering parts
Wildcats wrote: ↑Wed Mar 22, 2023 4:21 pmSalt Must Flow wrote: ↑Wed Mar 22, 2023 1:56 pm If you have a Menards store near you, you can order pipe through them if they don't have it in stock at your local store. I ordered pipe through them and picked it up when it arrived. You can also check your local store's inventory online too.
Just got done ordering parts from Menards. Great suggestion. Thank you
Parts ordered.
2" x5' type L pipe
2" elbow
2" tee
2" cap
1/4" x 20' tubing
Two 1/2"x5' type L pipe
Still need
2"x1/2" reducer
Triclamps
PTFE gaskets
- Salt Must Flow
Re: Ordering parts
I hope you were able to save some money too
Re: Ordering parts
Yeah I just feel like I've made some progress. Tomorrow I'll get Twisted Brick his envelope in the mail. Won't be long now.
- Twisted Brick
Re: Ordering parts
Hey Wildcats,
I get 2 x 1/2" copper reducers from Supply House.
If its not too late, give Menards a call and see if they'll change your 1/2" Type L to Type M. It's thinner and transfers a bit more heat quicker than the L. If they've already pulled it, no biggie.
Re: Ordering parts
Oh snap... I'll try see if I can change it today while I'm at work. No biggie tho.... I'll make sure I get it before I build my condenser. Thanks again sirTwisted Brick wrote: ↑Wed Mar 22, 2023 8:56 pmHey Wildcats,
Re: Ordering parts
I see my rating is changed to "bootlegger" moving up in the world!! Gotta love this fourm.
Re: Ordering parts
For the pieces you need in the future I found this site to be a bit cheaper.
https://www.coppertubingsales.com/
Tōtō
Tōtō
Si vis pacem, para bellum
Re: Ordering parts
Thank you sir. I will have a look at their prices.Tōtōchtin wrote: ↑Thu Mar 23, 2023 6:42 am For the pieces you need in the future I found this site to be a bit cheaper.
Tōtō
Re: Ordering parts
Ok so I been real busy. And have not made anymore progress until this morning.
Just ordered...
10 2" PTFE gaskets
12 2" copper ferrules
1. 2" sight glass
Submersible pump
Still need..
Water hoses
Valve for water lines
End caps and baffles for condenser
I'm sure there will be more. My ferrules won't be in till the first of the month. So I still have time.
Anything else y'all can think of??
What about a thermometer....
Just ordered...
10 2" PTFE gaskets
1. 2" sight glass
Submersible pump
Still need..
Water hoses
- Salt Must Flow
Re: Ordering parts
I've always used brass needle valves from the local Ace Hardware store and they seem to work really well for both stripping runs and spirit runs. They work great with my shotgun condenser so they have to work with a Liebig condenser too. I'm on well water and send my waste water down the drain. I also use push lock ball valves to turn water on & off too just for convenience.
Re: Ordering parts
For water lines I use PU tubing it's not as stiff as nylon. 6.5mm i.d. will work with 1/4" hose barbs.
+1 on the push connects. I use these. Short piece of tube on hose barb with hose clamp then everything else is push connect.
- Salt Must Flow
Re: Ordering parts
In a quick Google search it says max operating temp for Polyurethane tubing is 260C/500F! That's crazy high. I've been using Polypropylene tubing (200+F) because I've cooked Polyethylene tubing in the past. That Polyurethane tubing would handle way more than we could ever do to it.
Re: Ordering parts
Thanks so much for the links and feedback. It is greatly appreciated.Salt Must Flow wrote: ↑Sun Mar 26, 2023 2:47 pmIn a quick Google search it says max operating temp for Polyurethane tubing is 260C/500F! That's crazy high. I've been using Polypropylene tubing (200+F) because I've cooked Polyethylene tubing in the past. That Polyurethane tubing would handle way more than we could ever do to it.
I kinda went overboard with the flanges. It's more than usual. But I really want to be as modular.
Re: Ordering parts
There are many varieties of polyurethane, I can pretty much guarantee this stuff isn't good for those temps but it's held up well in my use. My RC exit temp is usually 55C-130F ish but it has gotten higher when I wasn't paying close enough attention.Salt Must Flow wrote: ↑Sun Mar 26, 2023 2:47 pm In a quick Google search it says max operating temp for Polyurethane tubing is 200C/400F! That's crazy high. I've been using Polypropylene tubing (200+F) because I've cooked Polyethylene tubing in the past. That Polyurethane tubing would handle way more than we could ever do to it.
I used to extrude TPU for jacketing ABS sensor cables, my memory is our melt temp was around 200C-400F. Easily formable at that temp. It is tough stuff though, any wire or cable near the wheel of a vehicle lives a very hard life.
- Twisted Brick
Re: Ordering parts
Did you order I/O ports? Thermometer not needed.
BTW, how much power you planning to put into your boiler on strips?
Re: Ordering parts
I haven't thought about the water I/O yet. And I will be heating on gas burner. I haven't got that yet either. I did order the water lines and fittings in the link above. The 10 mm ones.Twisted Brick wrote: ↑Mon Mar 27, 2023 9:27 amDid you order I/O ports? Thermometer not needed.
Re: Ordering parts
What do you recommend on the water I/O. Can't wait to get everything and get started.
Re: Ordering parts
I see pics of burners from Australia and New Zealand that make me salivate. There isn't as good a variety available in the US. I used one of these before I went electric. To get the control I wanted I needed a 5 psi regulator it was more than enough for my needs. 20 psi is ridiculous on those burners.
Re: Ordering parts
Thank you. I will be ordering this one. As I did the tubing you suggested. Much appreciated sir!elbono wrote: ↑Mon Mar 27, 2023 2:06 pmI see pics of burners from Australia and New Zealand that make me salivate. There isn't as good a variety available in the US. I used one of these before I went electric. To get the control I wanted I needed a 5 psi regulator it was more than enough for my needs. 20 psi is ridiculous on those burners.
Re: Ordering parts
The burner I run is a 4 ring job , all or just one or any combination of rings can be used.
The pic is of the adjustable regulator I use....adjusts from 0 to 15 psi. It's easy to adjust and works well on even the smallest ring if used alone.
I once tried to use a reg that adjusted from 15 to 25 psi.....it was a pain in the arse to use......way to big and fiddly to adjust.
