Heating your boiler
Blove88
Heating your boiler
Post by Blove88 »
How fast should you heat up 10 gal of low wines at 60 proof
sadie33
Re: Heating your boiler
Post by sadie33 »
you should not put anything over 40% in your boiler
sadie33
Post by sadie33 »
oh, and if it's low wines, that means your doing your spirit run, you want to go slow...It usually takes me about an hour to heat on a spirit run. 5 gal pot still on my stove.
Stonecutter
Post by Stonecutter »
sadie33 wrote: Fri Mar 24, 2023 1:18 pm you should not put anything over 40% in your boiler
True Sadie33 but 30% is just fine :wink:
Heat it up as fast as you can without puking. It’s low wines so your chances of puking are reduced. Once you start producing you’ll want to back off and collect low and slow. Another trick is to back heat off when your still is hot to the touch most the way up the riser. Once you get a feel for it you should be able to learn when to start cranking down the heat input so you don’t smear too much on the front end.
-Thomas Paine
sadie33
Post by sadie33 »
Stonecutter wrote: Fri Mar 24, 2023 3:02 pm
LOL, yes, it was 60 proof, not 60%!! :thumbup:
Sporacle
Post by Sporacle »
Blove88 wrote: Fri Mar 24, 2023 12:21 pm How fast should you heat up 10 gal of low wines at 60 proof
Go by sound and touch, the boiler sound will settle just prior to heat getting to your riser, as Stoney said feel the riser and reduce you power to the desired setting for your run.
On my pot I shut the power down totally for ten minutes when I feel the bottom of my riser getting hot (that's hot not warm) :thumbup:
greggn
Post by greggn »
Sporacle wrote: Fri Mar 24, 2023 3:34 pm
Why ?
________________
Blove88
Post by Blove88 »
[/q
Blove88
Post by Blove88 »
I've been going full blast and backing off at 100 deg and slowly bringing up to temp
Sporacle
Post by Sporacle »
greggn wrote: Fri Mar 24, 2023 3:49 pm
Why ?
Just a habit, do it with my stripping runs and it helps prevent pukes.
Carried over to my spirit runs and the 10 minutes give me a chance to do anything outside the shed for the next 8 hours :thumbup:
Plus I'm heating at about double what I run at
Stonecutter
Blove88 wrote: Fri Mar 24, 2023 3:53 pm I've been going full blast and backing off at 100 deg and slowly bringing up to temp
Yeah, it’s really up to you when to back that heat off. Running by temperature isn’t recommended but I don’t see anything wrong with using a thermometer to give you a good indication of when your still is going to start producing, it’s what I do along with feeling the rig, I can tell when my rig is getting close to producing and that’s when I back off heat input till I get my desired collection speed. I don’t pay any attention to the thermometer after that.
Slow drip until my heads are gone then adjust to collect hearts a touch faster, then slow drip as tails come on.
Sounds like you’re on the right track Blove88
-Thomas Paine
jonnys_spirit
Post by jonnys_spirit »
Low wines heats quicker than beer/wash. Once up to temp - mybe 35-40 min w/5k5W on 15g - I dial way way back and pull fores low and slow for an hour.
-j
greggn
Post by greggn »
Sporacle wrote: Fri Mar 24, 2023 3:54 pm
Why ?
Are you running dirty ?
I can understand cutting back the power but I'm not sold on shutting off.
________________
Blove88
Post by Blove88 »
Stonecutter wrote: Fri Mar 24, 2023 4:06 pm
Thank you
Blove88
Post by Blove88 »
jonnys_spirit wrote: Fri Mar 24, 2023 4:41 pm Low wines heats quicker than beer/wash. Once up to temp - mybe 35-40 min w/5k5W on 15g - I dial way way back and pull fores low and slow for an hour.
-j
Thank you sir
Sporacle
Post by Sporacle »
greggn wrote: Fri Mar 24, 2023 4:49 pm
Why ?
Everything is cleared, Mollases is always a bit pukey.
Just what I do :thumbup:
HDNB
Post by HDNB »
i always heat up the night before an leave it hot until the next morning. my thoughts are some esterfication happens, the heat hastens the process...plus it makes the spirit run day go faster by shortening heat up time.
dunno if it helps other than a shorter heat time on run day, but it does make some fine whisky.
now i drink for evil.
