After a brief search and I couldn’t really find any results. I thought I would post a question here. I’m currently running a 3 inch column with four bubble cap plates. It’s a modular system with TC fittings. I also have a single 4 inch section that I use under a whiskey helmet(pot still) to run my whiskey . I was curious if it would be feasible to add the 4” section on the base of my 3 inch column adding a couple more 4 inch plates? This is on a 26g boiler with 2X 5500W elements.
I suppose my concern would be if it would interfere with the proper rate of the flow of the vapor. I certainly appreciate any insight that could be provided. Thank you.
Adding a 4” section to a 3” bubble plate column
Tweedtelecaster
- Ben
Re: Adding a 4” section to a 3” bubble plate column
Nope, it will be just fine. The vapor will slow slightly, that's it, it speeds up going through the plates then slows into the column sections anyway. Grab a reducer and go.
Tweedtelecaster
Thanks Ben! I actually already have the reducer, I just need a couple 4” bubble cap plates. I’m going to order them up!
- bluefish_dist
Works fine. My vodka still was setup to run 6” plates under a 4” column.
Formerly
Dsp-CO-20051
Dsp-CO-20051
It depends on the plate design of the 4" section.
Because the 4" is going to have to run at 3" speed.
A valid point Shady .
The 3” section will dictate the maximum power that the combination can handle .This power will be way less than what a 4” plated column would be able to handle and run comfortably at .
Bubble caps in the 4” section will cope with the turndown in power whereas, if Perf plates were used , they likely won’t stay loaded .
100% correct Yummy and Shady, it will very much depend on plate type.and design.
