Best filler for soldering
Post your builds here.
Tōtōchtin
Member
Post by Tōtōchtin »
Hola,
I need to install some 2" ferrules in a 30l keg. No even spots on the bottom so I will need to fill 1/4" gaps. I am trying to stay away from going to borrow some welding equipment from the village. I only have a weak ass propane torch to work with. Any ideas what's the best material to use with a propane torch.
Tōtō
Si vis pacem, para bellum
Steve Broady
Re: Best filler for soldering
Post by Steve Broady »
Have you considered grinding the ferrule to fit the shape of the keg? Or flaring the hole in the keg so that it fits the ferrule? I realize you’re not in the US, but if you can get things through customs, there are tools available relatively inexpensively which are designed to flare a hole like that.
Salt Must Flow
Post by Salt Must Flow »
So you mean on the side of the keg or literally on the actual bottom/underside? If you mean the side, just grind the ferrule for a tight fit.
When I installed a ferrule on the top of my keg, it wasn't flat either. I cut on the red line (cutting away the high spots) and that allowed the ferrule to sit flat on the low spots so it could be welded. I know you're soldering, but that would work for soldering too. Once the ferrule was completely welded, I ground the interior protrusions smooth.
Tōtōchtin
Member
Post by Tōtōchtin »
As you can see thru the weep hole where the bottom is. The sides are raised about 3/8 -7/16" ths, so no grinding on my ferrules. Being here I almost was going to use a cheap coat hanger, what we used back before the wheel was invented.
I will probably use a 60% stick(last one) I have as a filler and use the Harris 8 I have to glue the ferrules on. It's for a heating element so not much stress on the fitting.
Tōtō
Salt Must Flow
Ahhhh I see now. I would cut a hole and grind it out just the right size for the ferrule to slide THROUGH perfectly. Nice & tight so there's no gaps.
Sporacle
Post by Sporacle »
Yep, as SMF said drill and grind to get tight fit with the ferrule into the keg.
You could slightly taper the ferrule male with a grinder and then lightly tap the ferrule into place.
Make sure it's cleaned and prepped prior to fitting so you can go ahead and solder once it's tight.
acfixer69
Post by acfixer69 »
You can hammer a flat spot at the location on the keg and you can make a good fit no filler needed.
Tōtōchtin
Member
Post by Tōtōchtin »
I thought of that when I saw the picture I posted. I made this a problem getting my 2 inch ferrules with narrow shoulder, 1/2".
ecir54
Post by ecir54 »
a 1/4" gap is not a feasible situation to any welder don' try it. couple ways to avoid have been discussed, befriend a experienced tig welder is recommended either way that's a tough joint to make with strength being a key factor
Oldvine Zin
Post by Oldvine Zin »
acfixer69 wrote: Sun May 28, 2023 3:59 pm You can hammer a flat spot at the location on the keg and you can make a good fit no filler needed.
:thumbup:
Stay safe
OVZ
