Apple Jack has NO alcohol??
I made some apple jack this year. Turned about 60 gallons of 5-6% cider into just a bit over 6 gallons. While I am sure that there was not pure conversion, my alcoholometer read negative proof, going about an inch below the 0 mark. Has anyone experienced this, or may have a idea why this has happened? I did test the meter on some 70 proof and it read within 1 proof of 70 (69...nice). My thought was that it may because of additional suspended molecules and residual sugar that may have been concentrated by the freeze jacking process. BTW it turned out fantastic and everyone who has tried it has been a fan.
Re: Apple Jack has NO alcohol??
The alcohol meter only works on pure distilled spirits, with no added sugars, etc.
You need to measure precisely and use math to know the ABV of a drink like Applejack.
- Stonecutter
When you drink it does it get you drunk?
-Thomas Paine
-Thomas Paine
<never mind>
I just made some negative proof water .
When it warmed up to 20°C it was fixed
If you are jacking , warm the sample to 20°C before taking ABV reading .
Lol....well done Yummy
Well, if you’re using a hydrometer to measure “alcohol content”, please understand that the hydrometer only measures DENSITY relative to water. So, with a density less than 1.000, or an alcohol potential less than 0%ABV simply means that you’re using the wrong tool to measure the alcohol content.WiAppleOak wrote: ↑Thu Jun 01, 2023 8:40 am I made some apple jack this year…
Turned about 60 gallons of 5-6% cider into just a bit over 6 gallons…
While I am sure that there was not pure conversion, “my alcoholometer read negative proof, going about an inch below the 0 mark.”
Has anyone experienced this, or may have a idea why this has happened? …
To use the brewing hydrometer, you measure the density BEFORE fermentation and the density AFTER fermentation and the change in specific gravity (or alcohol potential) only measure the SUGARS consumed by the yeast for conversion to alcohol. It only represents “the potential” alcohol in your ferment.
For a “freeze jacked” distillation, the “potential alcohol” is concentrated along with other flavor constituents as you freeze and “jack off” the ice (frozen water) from your spirit. It typically will concentrate the flavors as well as acids in the resulting spirit. I’ve jacked spirits many times before and the resulting flavors are dramatically amplified, including those flavors you DON’T want.
Now, why would your alcometer, a hydrometer I suppose, read a “negative” potential? Well, again because your “alcometer” measures the density and the density is LESS than 1.000 because the DENSITY of ALCOHOL is LESS THAN WATER. You have water and apple juice AND ALCOHOL which combined is less than pure water. You’re using the WRONG tools!
Here’s a big note: Sugar + water = wash gives a gravity greater than 1.000, which has an “alcohol potential”. But, alcohol + water gives a gravity less than 1.000, such that the “potential alcohol” will be LESS than unity.
Use your brewing hydrometer to measure “potential alcohol” into the boiler. But use the Proof & Traille (distiller’s) hydrometer to measure the alcohol in the spirit from your still. The P&T hydrometer measure’s the density relative to water of liquids with a density LESS than water, as a mixture of ethanol and water will be. Less water, ie - lower density = higher alcohol (and other constituents) concentration and a higher purity in your product. The more your P&T hydrometer sinks into the test cylinder means that that the “proof” is higher.
Hmmmm…. all that seems kinda’ “newby” to me. Understand the science and the mystery will disappear.WiAppleOak wrote: ↑Thu Jun 01, 2023 8:40 am… I did test the meter on some 70 proof and it read within 1 proof of 70 (69...nice). My thought was that it may because of additional suspended molecules and residual sugar that may have been concentrated by the freeze jacking process. BTW it turned out fantastic and everyone who has tried it has been a fan.
