Looking for the Louche...
All about absinthe
kiwipete
Post by kiwipete »
Hi
I have so far made only 2 (small) batches of absinthe, following to a tee the classic Pontarlier recipe and method, but scaled down to make 1 liter of product, so like so:
- 0.95 litre of 85% ABV neutral alcohol
- 25 grammes of wormwood
- 50 grammes of anise (green, andalusian)
- 50 grammes of fennel (doux Provence)
Macerated the above in a glass jar in a water bath at 60C for 12 hours (using sous vide), then added 450mils of water (water the first time, for the second time I used the tails from the first batch plus some water) and distilled as per recipe.
Did the colouring step as per recipe: take 400 mils of the product, added Pontica (10 grammes), Hyssop (10 grammes) and Melissa (5 grammes) into a glass jar kept in water bath at 60C for 4 hours. Let it cool down, strain and mix back in to the other product. Diluted to 70% ABV.
The stuff tasts great and has a beautiful colour, but I dont get any louching, at all. After the first batch, I thought that might be because of the fact that I didn't have any tails and I also read (after having made the first batch) that you should grind your anise and fennel to get better extraction of the oils.
So for the second batch I was expecting better results, because I now had some tails and I ground the anise and fennel. Unfortunately, again, no louche.
If somebody spots an error in the recipe or method that might have caused it, please let me know.
So what I can I do to get it to louche properly? I know I could add some star anise, which will most likely fix it , but that sorta feels wrong for a couple of reasons:
- the star anise might over power the green anise, flavour wise.
- it feels a bit like the cheats way out; you would imagine that back in the day when they devised and used the Pontarlier recipe it would louche OK.
So I'm looking for feedback, comments, suggestions. Anything welcome.
This topic has 10 more replies
Register Login
