The second recipe is a sugarhead made with the spent grains. Since its wheated, and its a sugarhead, and my favorite wheat beer ever is Three Floyds Gumballhead, I stole his name for this. Its a nice drinkin likker but especially good for pantydroppers and flavored stuff.
I call this recipe 'easy' because I dont cook the corn over fire. Lazy bastard that I am. I boil the water, then add the corn and let it steep cook for several hours, wrapped in a blanket. It works great, gelatinizes the corn just fine. Finally, 1/2barrel is in the title because it is tuned for a 15.5gal 1/2 barrel BAP (big ass pot) cooker. Keg with the top cut out. And a 15.5g still.
Ok on with it already.
WHEATED BOURBON RECIPE (Edited April 2015)
Ingredients:
10 gallons water
2 gallons backset (to lower the pH of the mash. Or sub with 2 more gal water and 15ml lactic acid)
4 teaspoons gypsum (calcium sulfate, lowers the pH a tad and yeast like Calcium)
22 lbs cracked corn (washed and drained with warm water in a bucket)
OR 16 lbs corn meal (corn meal converts more efficiently due to much smaller crack size).
5 lbs wheat malt, milled.
3 lbs 6 row, milled (or 2 row, or use 8 lbs wheat malt total)
A good ale yeast (US-04, US-05, Nottingham, Wyeast 1272, WLP023 Burton or similar) 2-3 packets, or a healthy starter.
A note on yeasts, US-05, Nottingham, WLP001 and Wyeast 1272 are very clean fermenting and produce very little esters. Make a great whiskey. US-04, WLP023 Burton and many other English style yeasts produce more fruity esters that will come across in the bourbon. The cuts get trickier and the final yield might be slightly less for these estery English yeasts but it does add a nice interesting touch to the bourbon.
Process:
1 - Bring the water, backset and gypsum to a boil in your half barrel BAP. It takes a while, and helps if you wrap a flame proof insulating blanket around the pot while its heating up. I usually quit at 205F out of impatience, and to avoid boiling the oxygen out of the water (yeast need oxygen).
2 - Turn the heat off and stir in the corn.
3 - Wrap it up in extra blankets, even if you have the flame proof insulator on it. And let it steep cook for several hours or overnight. Note the corn is pasteurized now so nothing funky is gonna grow in there. Helps to stir a few times as the corn will settle.
4 - After 3+ hours (I do overnight) remove the blankets, stir well and check temp. When I make this, I start the process at 8PM, stir in my corn by 10PM and at 9AM in the morning its 155F or so still. So if you wrap it up well it will hold temp just fine.
5 - Point a big fan at the BAP and stir a few minutes, it will drop fast, watch it. at 146F, stir in the 8 lbs milled malt and wrap it back up tight in blankets. Stir occasionally.
6- After minimum 2 hours or up to several hours. Cool to 80F or below and pitch the yeast (Note after mashing, its best to drop temp fast and pitch yeast. Malt carries bacteria that doesnt get pasteurized) Ferment at 65-70. Dont ferment beer yeasts in the 80's too hot for them and they'll get pissed and throw too much crap in your drink.
7 - It will be mostly done in 3-4 days, if you leave it to ferment out dry 5-7 days the yeast will add more fruityness (a good thing). Commercial distillers would like to do this but dont have the time, for economical reasons. Some push to 60+ hours to try and get more fruit. We do have the time
8 - When its done, squeeze out the grain through a large mesh grain bag. This isint as hard as some people make out. 20 minutes and Im done, and will get close to 11 gallons to distill. Let it sit overnight to settle out. The cloudyness is yeast. You dont want to distill that if you can avoid it, but if in a pinch for time its fine, Im hard pressed to taste any difference when I have run cloudy washes.
9 - rack the clear wash off the top of the settling buckets into your 1/2brl still. Do a quick stripper run. Pitch 6 oz of fores. I run the stripper until the low wines avg about 30%. You could go a bit longer but youre burning a lot of propane for a little bit of alcohol. (Whiskey distilleries typically go to 20% low wines, economics, and the large steam boilers are already running anyway). Save the backset from the stripper for next time. Its sterile, so stores fine in a sterilized bucket. You can also freeze blocks in gallon ziplock bags. Ive done both.
10 - Run the low wines slower in a spirit run. Pitch another 6 oz fores.
Cuts and Yield:
Make your cuts to taste. This recipe gives me 4 quarts at 56% usually, without feints added to the runs, or a higher yield if you have feints to add.
Age on toasted and charred all around oak. Dont touch it for 4 months, at that point its damn good. And only gets better with more time.
At todays grain prices $11/ 50lbs corn, $48/50lb wheat and $46/50lb 6row, This works out to $11.22 for 7 fifths of 80 proof. Or $1.60 a fifth.
Why do I distill? My answer in another thread on here - Im a cheap bastard with expensive tastes.
A note on oak aging, according to Jimbo - Oak needs to be toasted at 400-450 for 2-4 hours AND then charred all sides exposed to likker. Lots of ways to do this. Raw wood baked and charred gives more sweetness faster. Used barrels are great. Take a little longer. JD staves from a half barrel planter work great. I cut them into 1x1x5 inch sticks, and char the unexposed 5 surfaces with a torch. They are already toasted so dont need that treatment. Soak charred wood for several hours in water to remove some tannins and grit. For the JD sticks 1 ea 1x1x5 stick per quart. This is 88 sq inches per gallon. A 55g barrel gives about 52 square inches per gallon. I havent done the math on 5 gallon barrels yet but them used Balcones barrels sure are nice, I have 3.
BOURBON GUMBALLHEAD RECIPE Delicious sugarhead drinkin likker.
Instead of dumping that pile of squeezed out spent grain (and goo from the bottom of the settling buckets) in the compost (like I used to do! ugh) cook up 16 lbs of sugar with 2 gallons of the backset from the stripper run above and 10 gallons water. Cool and pour over the spent grain. There's plenty yeast embedded in the grain so no need for more yeast. This baby will start up quick and ferment out fast, 1.061 to 1.000 in 4 days. Squeeze it out like above, let it settle and run it twice, all same as above. You could pull a couple quarts of hearts out of the first run for a sweeter tasting shine. The second run will be cleaner. With the bourbon feints from above added, the yield is about 6 quarts of 56% or so! At the price I paid for sugar at Aldi last time this works out to $0.98 per 80 proof fifth!
Cheers friends.
