Sugar mash waiting time
Cakicen
Post by Cakicen »
Hello everyone,
I am making mashes from beet sugar. I get only hearts from spirit runs. All distillation processes are the same. However sometimes my alcohol taste is like sugar or honey, very tasty. But sometimes it is not tasty and not satisfying taste. I distill my wash when hydrometer reading is 990 and also the wash starts to seem clear. Should I wait longer for sugary taste or should I start to distill immediately when hydrometer is 990 and not to wait for clear appearance? Many thanks in advance. Regards.
Salt Must Flow
Re: Sugar mash waiting time
Post by Salt Must Flow »
Are you trying to make a neutral spirit using a reflux column? I'm not sure exactly what you are making or what kind of still you are using.
As soon as it is done fermenting, you can strip it. Waiting longer for it to clear (or forcing the wash to clear) can be beneficial when you are making a clean neutral because clearing a wash aids in removing flavor. Not clearing should encourage more flavor.
Cakicen
Post by Cakicen »
Salt Must Flow wrote: Mon Oct 23, 2023 9:07 am Are you trying to make a neutral spirit using a reflux column? I'm not sure exactly what you are making or what kind of still you are using.
Yes I am making neutral spirit with a pot still.
By flavor do you mean sugar flavor? Because there is only yeast and beet sugar in mash. After the fermentation there is no sugar left though. What I want is a flavor of sugar after distillation.Thanks.
Cakicen
Post by Cakicen »
Salt Must Flow
For the most potential for flavor, you could just do your stripping run as soon as you are confident fermentation is finished. Some washes or mashes may have a tendency to scorch if not adequately cleared. I assume you would know best with what you are fermenting.
greggn
Post by greggn »
Cakicen wrote: Mon Oct 23, 2023 9:30 am
Cakicen wrote: Mon Oct 23, 2023 9:32 am
These goals are in opposition to each other.
________________
What you make with sugar is not a mash, a mash is made with grains.
A ferment made with sugar is a wash.
You will find it very difficult to make "neutral" with a pot still.
Please work on using the right words for what you are doing.
Stonecutter
Post by Stonecutter »
I’m new to this whole thing, subsequently I don’t know shit.
IMHO it seems to me that your flavor profiles MAY have less to do with a function of time and more to do with variables during your ferment. Things like infections and yeast stress.
It could also be small variables in how you’re running the product during your spirit run. As was mentioned above the more details you give can sometimes lead to more specific advice.
-Thomas Paine
Cakicen
Post by Cakicen »
Saltbush Bill wrote: Mon Oct 23, 2023 12:45 pm What you make with sugar is not a mash, a mash is made with grains.
Sorry for my English. Yes then I am making a wash ferment with simple sugar. What I wonder is, why some of the distilled alcohol have nice sugar flavor and some have not. They are all from the same wash. I mean they are all from 2 kg same sugar, 8 liter same water, 30 grams same baking yeast. What is the reason some has very nice flavor and some does not? Thanks
Cakicen
Post by Cakicen »
Also the distillation process is same. First strip run, than spirit run. Same ratios of heads, hearts, tails. I get only the hearts, trash the others.
Cakicen
Post by Cakicen »
Stonecutter wrote: Mon Oct 23, 2023 2:53 pm I’m new to this whole thing, subsequently I don’t know shit.
Thank you for the nice explanation
Cakicen wrote: Mon Oct 23, 2023 8:50 pm
You're recipe is stressing the yeast during fermentation.
If you want consistency, I'd recommend using 1.5kg or a little less sugar in 8ltrs water.
The yeast also needs some nutrients such as FERMAID K™
Cakicen
Post by Cakicen »
shadylane wrote: Tue Oct 24, 2023 11:42 pm
Thanks very much. I use DAP and don't know if I need further nutrients. I will try to fix hydrometer setting around 1080 by increasing water as per your suggestion 👍🙏
