DIY Corn Grinder
haeffnkr
DIY Corn Grinder
Post by haeffnkr »
Made a new grinder for whole corn. I think it will work out well.
Parts list
- Harbor Freight angle grinder
- old saw blade cut to size and sharpened like a lawn mower blade
- PVC pipe... 10" or what ever you got
- stainless screen .200 opening
In action - https://streamable.com/lh8rde
What do you think?
haeffnkr
tombombadil
Re: DIY Corn Grinder
Post by tombombadil »
Looks like it worked pretty well!
Things that are home made and spin very ,very fast scare me......I've seen more than one fly apart.
It seems to do the job well.......but it still worries me, you'd want that home made blade balanced very well.
NormandieStill
Post by NormandieStill »
Saltbush Bill wrote: Sat Nov 25, 2023 9:51 pm Things that are home made and spin very ,very fast scare me......I've seen more than one fly apart.
I'd want to see a metal ring around the grinding chamber to contain the blade if or when it decides to come apart.
Good result though. That looks like a nice grind.
Swedish Pride
Post by Swedish Pride »
Love a bit of backyard ingenuity :thumbup:
As others have said, ensure that it's safe and happy grinding
Don't be a dick
Dancing4dan
Post by Dancing4dan »
Nice job! Looks like it works well. There is a blade like that on my gas powered trimmer. Another attachment for a weed wacker!
Marcus Aurelius
Buffalo
Post by Buffalo »
Looks like it does a good job. Since the blade is one piece, I would think it would stay together.
NormandieStill
Buffalo wrote: Sun Nov 26, 2023 6:34 am Looks like it does a good job. Since the blade is one piece, I would think it would stay together.
If it's not balanced then it matters not that it was one piece. At 7000-11000 rpm 10 grams more on one side than the other makes for a huge assymetric force.
haeffnkr
Post by haeffnkr »
HI
Thanks for the feedback thus far!
If anyone has any links of catastrophic failure I would be interested in seeing them. I based my design off of a few youtube videos that work the same but a bit smaller and use plastic and wood to contain the blade.
Overall I wanted a grinder that I dump and grind 40 pounds in a few minutes, one grind, and this should do that no problem.
Yes ... this thing is a bit scary when it is running.
This was sort of a beta test to start with before I made some improvements.
I plan to line the inside with a strip of thin stainless and am looking for some heavy steel pipe 1/4 to 1/2 thick to build a sleeve on the outside to contain the blade if it goes flying. My original idea was to use heavy steel pipe 8 to 10 inch diameter and build the whole thing out of that, making it safer and eliminating the pvc pipe. But Cutting, drilling and tapping the steel pipe would have been taken more time and tools than I had the patience for initially.
thanks haeffnkr
I agree, was surprised when looking at it that it worked as well as it does.
Demy
Post by Demy »
I made the flour mill with a washing machine motor and using another one instead of the blade, I saw some on YouTube but I preferred another system. If he does the job well then it's ok...always be careful.
Dancing4dan
If you are nervous about the PVC see if you can get an old oxygen bottle from a welding supplier. Section it with a side grinder. Ensure it is empty and vented first :shock:
Marcus Aurelius
Bradster68
Post by Bradster68 »
If your worried about a blade that isn't balanced, you can use a dado blade for woodworking. It's made to cut a slot or square trough.in wood. Well balanced
john_bud
Post by john_bud »
I like it!
