With Harris Stay Clean Liquid Flux sometimes being hard to get hold of or extremely expensive outside of the U.S.A. I have, at various times looked for equivalent performing fluxes. Thought it might be helpful to some throw in a table of listed contents for similar liquid fluxes as per their data sheets.
FLUX__________________________________ AMMONIUM CHLORIDE___ZINC CHLORIDE____HYDROCHLORIC ACID____OTHER
Activ8 102 liquid flux____________________<30____________________NA _____________NA ___________________Urea <30%
Superior No22__________________________NA ____________________30-40% _________0.5-5%_________________NA
Oatey No 11___________________________3-7%___________________15-40%__________10-30%_________________NA
Griffon GRF S39________________________10-25%_________________25-50%__________NA____________________Ethanediol>2.5<10% Glycerol 1-2.5%
Harris Stay Clean_______________________ 5-25%_________________<30%____________<5%___________________ Methyl Alcohol<5% Water
Bakers No3 Flux ________________________1-10%__________________20-30%__________NA____________________NA
Rubyfluid Stainless Steel_________________NA_____________________30-45%__________3-10%_________________Ethylene Glycol 20-50%
Duzall Flux ____________________________5-20%__________________5-70%___________5-15%__________________Glycerin <5% Methanol <5%
Weldbraze Liquid Flux___________________NA _____________________40% ____________<5%___________________Low Hazard Salts 5-15%
Apologies its so cluttered, i had it set as a table but having difficulties.
Liquid fluxes similar to Harris Stay Clean
Reason: HSB is the solder
- Dancing4dan
Re: Liquid fluxes similar to Harris Stay Clean
Try taking a screen shot and load it as a photo
Marcus Aurelius
Marcus Aurelius
Cheers.
Thanks for the screenshot SS.
Thanks for the info and Still_stirrn for the table .
I’m still using a bottle of Duzzall , I bought in New Zealand over 40 years ago . It works perfectly on stainless and Copper .
My Grandfarther was a plumber . Always made his own by collecting all the off cuts from galvanised iron and dropping them into Hydrochloric acid until all the zinc had reacted ( turned into zinc Chloride ) and stopped fizzing .
Yes I did it too and it works...if you add a source of ammonium chloride. Phosphoric acid also works well.Yummyrum wrote: ↑Fri Dec 29, 2023 6:58 pm Thanks for the info and Still_stirrn for the table .
