I have a 15.5gal keg, and 5gal keg for thumper, and looking to build worm condenser 1/2" 20ft out of a 10 gal Igloo Cooler. I'll circulate cold water from via pond pump from another cooler loaded with ice/water. Anyone else have this worm setup? Any issues you can see? Length of coil ok? I'll certainly make sure there is a continual downward slope in the coil so as not to pool.
Thanks!
Worm Condenser in Igloo
Re: Worm Condenser in Igloo
Build a simple Liebig condenser and be done with it. You'll be glad you did. Cheer's
