Into the hearts now, but the temperature at the probe is 79.5 or so. In fact, if I lower the heat a bit, the whole thing stops and drops temp. This is the best I can get it to go. The hearts are clean smelling (almost zero smell and burns immediately with a clean blue flame). Everything is coming over at 87% ABV.
I'm using propane and it is a bit fiddly, but I think I have it equalized..I brought it down once the wash was putting off vapor, and then brought it up slowly in steps until I saw the temp start to rise. is it just because of the short column that I am getting 87%? And do you think the temperature is a phantom reading? Or is my heat control just poor?
Mind you, 87% isn't bad for a short column
![Smile :)](./images/smilies/icon_smile.gif)
