Vm/LM head
Karstr
Vm/LM head
Post by Karstr »
In this kind of coloumn, can I let the filling go over the VM-port?
Re: Vm/LM head
No .
The whole concept behind a VM is the proportioning of Vapour between the apperature in the valve and the column diameter . Hence , the VM port must be in the vapour space above the packing .
There should always be a few inches gap above the packing ( I believe that is what you mean by filling) to allow a space for any liquid that spurts out of the packing to fall back rather than splash into the VM port .
Some folk like to run the column in a semi flooded condition , this would be impossible if the packing was higher than the VM port as it would fill the port with liquid .
While I do like the flexability of all the tri-clamp stuff , sometimes they end up being rather wasting of space in some configurations .
You would be better to have the site glass below the VM port and filling most of it with packing . Just leave enough space so you can still see the top to watch for flooding and to see the reflux rain.That plus the space in the lower part of the Tee should provide enough between the port and the top of the packing while maximising the height of available packing .
Karstr
Re: Vm/LM head
Post by Karstr »
Yummyrum wrote: ↑Thu Feb 08, 2024 1:05 pm No .
Thank you, that makes good sense.
Salt Must Flow
Re: Vm/LM head
Post by Salt Must Flow »
Would you mind listing a link of where you bought that LM segment? Or snap a pic of what the inside looks like? I'm always curious to see how manufacturers design LM segments like that. Many use different designs.
tjsc5f
Re: Vm/LM head
Post by tjsc5f »
Salt Must Flow wrote: ↑Thu Feb 08, 2024 3:14 pm Would you mind listing a link of where you bought that LM segment? Or snap a pic of what the inside looks like? I'm always curious to see how manufacturers design LM segments like that. Many use different designs.
I bet it's one of these
https://www.aliexpress.us/item/32568044 ... pt=glo2usa
Karstr
Re: Vm/LM head
Post by Karstr »
tjsc5f wrote: ↑Thu Feb 08, 2024 3:25 pm
Correct sir! I will do a cople of mods, I will use a plate of some sort on top of it, to direct the liquid to the side. And I will use some sort of screen on the bottom, to senter the flow.
Salt Must Flow
Re: Vm/LM head
Karstr, this is just a rough sketch of how you could direct the reflux to the side. You could flatten a piece of copper pipe to make a copper plate. I'd anneal it too. You could use a Dremel with a cutting disk to cut the center out. Bend the center downward slightly and curl the center shaped like a flower pedal. The entire contraption could be installed using a Still Dragon Plate Gasket above the LM segment.
I'm pretty sure the center part should be smaller (grind or cut away more material) to create a wider gap between it and the surrounding ring to allow more room for rising vapor. Like I said, this is just a rough sketch to get the point across.
Karstr
Re: Vm/LM head
Post by Karstr »
Salt Must Flow wrote: ↑Thu Feb 08, 2024 5:06 pm Karstr, this is just a rough sketch of how you could direct the reflux to the side. You could flatten a piece of copper pipe to make a copper plate. I'd anneal it too. You could use a Dremel with a cutting disk to cut the center out. Bend the center downward slightly and curl the center shaped like a flower pedal. The entire contraption could be installed using a Still Dragon Plate Gasket above the LM segment.
Thanks, that seems like a perfect solution. I have seen a simpler one, with I'll like to try, cut the handle of a spoon, and stick the blade in the side-gap
What do you think?
zach
Re: Vm/LM head
Post by zach »
I was thinking to make a LM head like this one. I currently run a LM, but would like to have visual feedback of reflux ratio.
viewtopic.php?t=87788
Could this design also be used for a VM/LM head ?
tjsc5f
Re: Vm/LM head
Post by tjsc5f »
Salt Must Flow wrote: ↑Thu Feb 08, 2024 5:06 pm The entire contraption could be installed using a Still Dragon Plate Gasket above the LM segment.
Is silicone safe to use now?
Salt Must Flow
Re: Vm/LM head
Karstr wrote: ↑Thu Feb 08, 2024 5:25 pm
What do you think?
You're right, that essentially does the exact same thing :thumbup:
I noticed that with your parts, there is a limited amount of space to work with between the Tri-Clamp joint and the inner part of the LM segment below. If there's enough clearance, your idea would work flawlessly.
EDIT: I just realized that you installed the spoon over top of the LM segment. You would just have to be sure there's enough clearance between the spoon and the above reflux condenser.
Last edited by Salt Must Flow on Thu Feb 08, 2024 7:23 pm, edited 2 times in total.
tjsc5f
Re: Vm/LM head
Post by tjsc5f »
zach wrote: ↑Thu Feb 08, 2024 5:27 pm Could this design also be used for a VM/LM head ?
I think you could put pretty much any LM head above a VM takeoff tee.
This type of china LM head is a little more expensive, but would work well with a CSST coil right out of the box.
https://www.aliexpress.us/item/32568049 ... ry_from%3A
Salt Must Flow
Re: Vm/LM head
tjsc5f wrote: ↑Thu Feb 08, 2024 5:36 pm
Wrap it in PTFE tape if you're concerned. Alternatively you could use a Dremel to modify a PTFE gasket very easily to replicate one of those 'Plate Gaskets'.
Re: Vm/LM head
zach wrote: ↑Thu Feb 08, 2024 5:27 pm I was thinking to make a LM head like this one. I currently run a LM, but would like to have visual feedback of reflux ratio.
Having the reflux fall in the center of the packing is good. :thumbup:
Bolverk
Re: Vm/LM head
Post by Bolverk »
I got one of these LM take offs a while back for a project that kinda fell through... been considering doing a version of the amphora pda-1 with it.
https://a.aliexpress.com/_mrTlB9s
Re: Vm/LM head
Karstr wrote: ↑Thu Feb 08, 2024 12:47 pm In this kind of coloumn, can I let the filling go over the VM-port?
I'm confused by the term "filling" do you mean column packing?
Karstr
Re: Vm/LM head
Post by Karstr »
shadylane wrote: ↑Thu Feb 08, 2024 6:46 pm
Im sorry, of course I meant packing😊
Salt Must Flow
Re: Vm/LM head
I just realized that you installed the spoon over top of the LM segment. At first I misunderstood what I was seeing in your photo. You would just have to be sure there's enough clearance between the spoon and the above reflux condenser.
Karstr
Re: Vm/LM head
Post by Karstr »
Jupp, I haven't made the reflux-coil yet, so I'll make it fit
Garouda
Re: Vm/LM head
Post by Garouda »
Bokabob's idea IMHO makes sense for Ø up to 1.5"- 2" max. I followed the trend, but rapidly came to the conclusion that a combined VM/LM head would be better. I built such a combined Ø 3" Boka/VM head because at that time Bokabob was fashion amongst the hobby distillers population.
When I saw the result for real, I doubted and started some research.
“A vapour management still head is very easy to build because the concept is so simple, and is a considerable advance on all previous liquid management techniques that utilize small, temperamental needle valves that can be difficult to procure and which often change their settings with temperature. “
Nixon & McCaw (2001) The Compleat Distiller p.131, The Amphora Society.
I cut the sanitary ferrules that were already welded on my hybrid head and made a VM head that gives me entire satisfaction. I have enough Ø 3" SS pipe, so it wasn't an issue.
"In wine there is Wisdom, in beer there is Freedom, in water there are bacteria."
Benjamin Franklin
"In moonshine there is Rebeldom"
Garouda
Karstr
Re: Vm/LM head
Post by Karstr »
Garouda wrote: ↑Sun Feb 11, 2024 1:25 am Bokabob's idea IMHO makes sense for Ø up to 1.5"- 2" max. I followed the trend, but rapidly came to the conclusion that a combined VM/LM head would be better. I built such a combined Ø 3" Boka/VM head because at that time Bokabob was fashion amongst the hobby distillers population.
But the idea to use a LM-unit to take off the heads and foreshots is good?
Re: Vm/LM head
Karstr wrote: ↑Sun Feb 11, 2024 3:38 am
Yeah , that was the big sell Karstr , The romantic idea that the nasty stuff goes out the LM poo hole and then you switch to the pure untouched virgin VM port for the collection of hearts :ebiggrin:
Damn , I fell for it too :oops:
It’s a crock of shit .
The transition of fractions regardless of still head types is always continuous . The Fores come , then transition into the heads then transition into the hearts . One washes and rinses the previous one keeping the “pipes clean”
There is no contamination or smearing in any still head .
So by the time the desirable Hearts are coming through , any previous fractions are well and truely purged . :thumbup:
I went down the LM/VM path . My LM port was disconnected after about 2 runs . Only mud wasps now take up residence in the unused LM valve.
viewtopic.php?p=7481508#p7481508
Once you realise that VM is so easy to use and has no contamination issues , you wonder why you bothered with the LM port that need constant re-adjustment.
Garouda
Re: Vm/LM head
Post by Garouda »
Karstr wrote: ↑Sun Feb 11, 2024 3:38 am But the idea to use a LM-unit to take off the heads and foreshots is good?
IMHO it isn't the effort worth, you are not in a laboratory, and you are not interested in collecting foreshots, and then heads, but some palatable good stuff.
Many years ago, I also followed the Bokabob fashion, but I rapidly changed my mind. We came from a time when the type of still presented on the web was based on a milk keg with a weird reflux system, fortunately things have changed.
A VM still is very easy to build and to run, it's very effective too.
When you proceed with your spirit run, collect the first cc's in separate small jars, depending on the size of your batch.
Also bear in mind that there is no methanol in a grain nor in a sugar wash. Methanol is produced by the decay of pectins, you'll have that issue with brandies only.
Label your jars. Collect two or three small ones, then use bigger ones. I usually take two 250ml bottles, after I use 500ml bottles. I forget the first 250ml bottle, sometimes I take a few cc from the second one to make rum. The next day, I taste each 500ml bottle by pouring about 2cc in a glass and I add +/- 3cc of water to taste it. I spit the booze in a bucket and pour the rest of the glass in a separate bottle.
Hope it helps...
Benjamin Franklin
Garouda
Karstr
Re: Vm/LM head
Post by Karstr »
Thanks, this is really useful information for a novice destiller! How do I know when I have the correct opening on the VM-port?
Re: Vm/LM head
Karstr wrote: ↑Sun Feb 11, 2024 6:30 am Thanks, this is really useful information for a novice destiller! How do I know when I have the correct opening on the VM-port?
The VM valve (port opening) adjusts the reflux ratio. A small opening gives a high RR and hence, high purity. So, the opening depends on how high you want the %ABV off the spout.
If you start with a small opening, enough to produce a drip or small stream, and then collect a sample to measure, you can adjust the opening according to where you want the collection to be.
Experience with YOUR still will train you how to set it for the product you want to produce.
Salt Must Flow
Re: Vm/LM head
For my 3" VM, I use a 1" stainless steel gate valve. If I were to build a 2" VM, a 1" valve wouldn't necessarily be too big. A 3/4" valve is probably fine. After using a VM for years, I have no interest in LM. VM just just operates itself. All I have to do is crack open the valve to remove foreshots, open it a little more for heads and a little more for hearts. Once tails hits, I just just down. The % ABV remains 95%+ from start to finish with no other fiddling around.
Karstr
Re: Vm/LM head
Post by Karstr »
I really like this forum, and the effort you guys do to explain novice distillers how to start the new hobby.
Garouda
Re: Vm/LM head
Post by Garouda »
Salt Must Flow wrote: ↑Sun Feb 11, 2024 11:18 am For my 3" VM, I use a 1" stainless steel gate valve. If I were to build a 2" VM, a 1" valve wouldn't necessarily be too big. A 3/4" valve is probably fine. After using a VM for years, I have no interest in LM. VM just just operates itself. All I have to do is crack open the valve to remove foreshots, open it a little more for heads and a little more for hearts. Once tails hits, I just just down. The % ABV remains 95%+ from start to finish with no other fiddling around.
Your comments are 100% in line with what I can observe at my place. :clap: :thumbup:
I can get a slightly higher ABV (96%) when I increase the length of my column, the limitation is the roof of my 'distillery' though.
Same for me Ø3" with a 1" gate valve. By construction, this reduction of 3" to 1" causes 'de facto' a high reflux ratio, even with the valve full open.
That Bokabob fashion must have made lots of damages. When I was in that trend, one could hardly find needle valves, I bought mine on eBay, from the USA. Now you can easily find those 'temperamental needle valves' on online shops in China.
I'm happy that I scrapped my hybrid head before making all the connections enabling that LM/VM transition.
I like to quote Nixon & McCaw (2001), THE COMPLEAT DISTILLER,The Amphora Society.
About vapour management, on page 131 they wrote:
"It has three further advantages:
■ once calibrated its settings remain the same
■ it maintains a constant selected reflux ratio for any boiler power setting or vapour composition
■the quantity of product distillate automatically reduces at the end of a run when the tails begin to be evident."
I disagree with this though, and would appreciate the opinion of some experts like Yummyrum for instance. Indeed, for me this is contradictory:
"it maintains a constant selected reflux ratio for any boiler power setting or vapour composition" AND "the quantity of product distillate automatically reduces at the end of a run when the tails begin to be evident" If the output reduces, it means that the reflux increases, because the amount of the vapour produced remains constant for a given power. The distillate product reduces, where does the difference go if it is not with the reflux ???
Anyway, having a sight glass, this is what I can observe, the amount of reflux increases, and the quantity of distillate reduces when the tails are coming.
Notwithstanding this, I highly recommend that book. And I definitely recommend a VM setting !
A photo says more than long sentences:
Here the Boka head I scrapped (I cut both ferrules )
And here the final VM setting:
Benjamin Franklin
Garouda
NormandieStill
Re: Vm/LM head
Post by NormandieStill »
Garouda wrote: ↑Sun Feb 11, 2024 7:24 pm I disagree with this though, and would appreciate the opinion of some experts like Yummyrum for instance. Indeed, for me this is contradictory:
The amount of vapour produced for a given power is not constant because as you remove alcohol from the wash, the boiling point increases (meaning that so does the energy required to vaporize the wash). So for a given amount of energy you get less vapour produced. You can see this clearly on a lot still run if you measure your take off rate and don't change the power at all. E.g. the first 2 litres of distillate from a stripping run will take much less time than the second 2 litres.
Re: Vm/LM head
I’d agree with that Normandie . :thumbup:
The amount of vapour will taper off during the run . But because the proportion that the vapour is split remains the same , so is the reflux ratio . IE the proportions of reflux to collected remains the same but each is less as the run proceeds .
This is where LM’s are a pain in the arse because you have to keep slowly reducing the the collected amount to keep the RR constant .
What does raise my concerns is where they say that the output automatically reduces when tails arrive .
That kind of implies that you just run it and it will automatically stop producing when tails arrive …… which couldn’t be further from the truth .
As mentioned above , there is a slow taper off in vapour as the run progresses . Yes it is less towards the end compared to at the start , but there is no sudden stop ….. certainly not before tails is pouring into your collection jar iff’n you are expecting it to suddenly stop .
So newby beware , keep collecting in jars . The sudden automatic tails shutoff does not happen . :ewink:
Always stick a spoon under the spout with a splash of water and have a taste each time you change the jar . The tails will suddenly appear on the taste iff’n you can’t smell it as you raise the spoon yo your face .
Now iff’n you are a sick bastard and continue to collect that putrid stinky tails shit and have it all through your condenser , you will eventually find that it does finally substantially slow down .
I prefer to stop it well in advance :thumbup:
