Steam rig planning
ckdistills
Steam rig planning
Post by ckdistills »
I’m ready for steam! Been reading here for awhile, but serious now after my failed rye on electric experiment.
Here’s what I’m thinking and a few questions follow. Very similar to other builds here. Versatility is important, I can see using this with a steam wand to cook corn, steam strip rye or on-grain or on fruit, or in a traditional thumper configuration. I mostly make 20-25 gallon grain mashes so a 15 gallon keg would work well.
Boiler: existing 7.75 gallon slim 1/4 keg. I need 2 gallons to cover the element, which provides 5 gallons for steam with a bit of safety margin. Used as a thumper in traditional configuration.
Thumper: New 1/2 keg. Use as boiler when configured with a traditional thumper.
Steam injection. PRV with vacuum break on the steam generator, ball valve to vent steam (boiler always open to atmosphere), inclined pipe between steam generator & boiler so that water drips back to the boiler. Steam travels via 3/4” copper. Steam injected via 1/2” or 3/4” copper pipe inside 2” TC tee. Distillate exits via TC tee to product condenser.
Questions:
Do I need a manometer? It would provide safety redundancy but with the PRV is not strictly required? I’ll have a sight glass on both kegs and can see pukes. And my product condenser is CSST coil inside 2” pipe - would take gross negligence to clog.
Steam injection pipe size - I’d like to use 1/2” but don’t want risk it clogging. 1/2” lets me use fittings like these where with 3/4” I’d need to make the fittings.
https://www.brewhardware.com/product_p/ ... double.htm
https://www.brewhardware.com/product_p/tc15m12npt.htm
What is the order of operations in use? Do you wait until you’re generating steam to insert the injection pipe into the thumper? Seems the safest to avoid clogging but practically a pain with very hot components and needing to loosen/tighten fittings as the connector angles change when inserting the pipe.
From my rye in electric boiler thread:
Bolverk wrote: Mon Mar 25, 2024 3:51 pm With a 3500w you'll carry over 93ml of water per min, heat up will take about about 74 mins, thats 1.8 gal just in heat up, then figure about a 2 hours to strip so thats another 2.94 gals. If your 7.75 kegs is like mine, you probably need 2 gal to cover the element. So you're right at 7 gals with no head space for the boil... I'd do your steam keg out of a 15g and only fill it with like 10 gals.
Sorry to detract from this electric thread... if/when you start another one we can carry on over there.
How is this calculated? I'd love to understand the math - have tried searching to no avail.
This topic has 34 more replies
Register Login
