2nd heads?
2nd heads?
Occasionally my run takes a bit longer then I expect. I will usually shut it down if it gets late and then finish it up the next day. Out of paranoia, I'll toss the first 50-150ml of the same wash after it starts dripping again. Is this necessary?
Re: 2nd heads?
Heya OG.
There shouldn't be as many nasties in the foreshots on an interrupted run (as talked about elsewhere.. sorry I dont have the link) and so people have said you can throw less away, but it would help to know:
- What kind of still you are using.
- What size is your boiler
Re: 2nd heads?
Thanks for the reply. I have a 30L reflux distiller. Right now I'm in the middle of running a rum wash with no packing and no reflux. It's going pretty good so far.
