Dukes of Hazzard
Maverick1988
Dukes of Hazzard
Post by Maverick1988 »
Hello,
I'm fairly new to posting in here but the feedback I've gotten has been awesome so far.
I am brand new to distilling, As of right now, I've only ever done one whiskey stripping run and made a second whiskey wash for another stripping run and the plan is to mix the outcomes of that and do a spirit run to see how things turn out.
I've heard that whiskey is one of the most difficult things to do with distilling... so naturally.... I tried the most difficult thing first hahahaha.
But this post is actually about my next plan.
I've decided that after this whiskey experiment I wanted to do something a bit "easier" which will be a flaked corn/cornmeal (whichever I can find) and sugar wash. The plan is to distill into a base of moonshine and then once jarred, flavor it into different recipes from there.
The plan so far is...
50L water
13lbs Flaked corn/cornmeal
19lbs sugar
a bit of Amylase Enzyme
I feel like this should produce a good amount as well as be a bit more simple than whiskey but I would love to hear any tips or suggestions before starting the process so I can adjust accordingly instead of winging it like I did with my first batch of whiskey (I will likely start next week).
Chucker
Re: Dukes of Hazzard
Post by Chucker »
Experimentation can be a valuable component of the learning process as long as you critically review your results. You’ll get something out of this but it’ll be more akin to a sugar wash as you won’t get a decent conversion of flaked corn without further enzymes. But it will provide some corn flavor. I think you will get better flavor if you target yield less as that’s quite a bit of sugar. But I’ve also started similarly and had to reach some conclusions on my own.
Rather than belabor this, I’d suggest that you go to the Tried and True section. You’ll find several groupings that will have the base info right at the start. I think that one or more of these will help give you a basis to help sort this out if you’re looking for principles to apply. There are also a number of specific recipes that will accelerate your path to good results and give you a solid foundation to build on.
Best!
subbrew
Post by subbrew »
I recommend backing off the sugar. A quick calculation shows a starting gravity of around 1.093. might be OK if using wine yeast but for beer or brewers yeast it will stress it. I would suggest working with a recipe from the tried and true. That way you know the recipe is solid and you can learn more about using your equipment without a recipe variable. UJSSM is a recipe that is close to what you are suggesting.
Maverick1988
Chucker wrote: Tue Jun 18, 2024 5:58 am Experimentation can be a valuable component of the learning process as long as you critically review your results. You’ll get something out of this but it’ll be more akin to a sugar wash as you won’t get a decent conversion of flaked corn without further enzymes. But it will provide some corn flavor. I think you will get better flavor if you target yield less as that’s quite a bit of sugar. But I’ve also started similarly and had to reach some conclusions on my own.
Best!
Thanks, I appreciate the response. I'm still excited to see how the whiskey turns out. So far my biggest mistake is the size of my still. I have the setup of it, but 50L seems to be a lot for a beginner and all the washes have to be huge in order to properly run it.... but live and learn that's okay and I should be able to make lots.
I actually got this moonshine recipe online as a "no fail" recipe... basically, it's very difficult to screw up from what all the reviews say. As well, the plan is more just moonshine volume that should hopefully get 80-90% and proof down. Then flavor it after in individual jars.... which is where the experimentation should really come into play.
Maverick1988
subbrew wrote: Tue Jun 18, 2024 6:11 am I recommend backing off the sugar. A quick calculation shows a starting gravity of around 1.093. might be OK if using wine yeast but for beer or brewers yeast it will stress it. I would suggest working with a recipe from the tried and true. That way you know the recipe is solid and you can learn more about using your equipment without a recipe variable. UJSSM is a recipe that is close to what you are suggesting.
Thanks for the tip.
I got this recipe as a tried and true... sort of no fail recipe. I've been using red star yeast but I also have two packs of turbo yeast (Which seems to be a bad word around here hahaha).
jonnys_spirit
Post by jonnys_spirit »
If you're doing sugar+corn without gelatinizing and converting the corn I'd recommend checking out the UJSSM recipe in the Tried & True recipe section. This is similar and uses cracked corn plus recycling of some backset each generation to get a compounding effect.
Low wines + fresh ferment is what folks generally refer to as a 1.5 distillation. Give it a go and let us know how it turns out.
Cheers,
j
Maverick1988
jonnys_spirit wrote: Tue Jun 18, 2024 7:02 am If you're doing sugar+corn without gelatinizing and converting the corn I'd recommend checking out the UJSSM recipe in the Tried & True recipe section. This is similar and uses cracked corn plus recycling of some backset each generation to get a compounding effect.
Cheers,
j
I got the recipe as sort of a fail safe going into my very first moonshine run.
From what I understand, the sugar is for the ABV, the Corn is for flavor. Thanks, though, I'll check out the UJSSM recipe for sure.
subbrew
Post by subbrew »
If the corn is only for flavor then you do not need the amylase enzyme. The only reason to add enzymes is to convert the corn. My numbers above assumed the corn was converted. If not, then the gravity is not overly high, about 1.061 with no corn contribution.
Maverick1988
subbrew wrote: Tue Jun 18, 2024 7:35 am If the corn is only for flavor then you do not need the amylase enzyme. The only reason to add enzymes is to convert the corn. My numbers above assumed the corn was converted. If not, then the gravity is not overly high, about 1.061 with no corn contribution.
I'm still gonna run the corn though.. flavor is good, extra abv never hurt either.
I have a buddy who was doing this exact recipe. says he was running 55Gallon washes 75lbs of sugar 50lbs of corn meal and 1lbs of yeast. (My wash will be obviously scaled down to fit my 50L still)
Not sure how believable it is, but he says in 5 Gals he was getting 3-4L of 80-90 abv
jonnys_spirit
In order to convert corn you need to cook/boil it for a good while until it gelatinizes then add the amylase at the specified temp (usually around 150*F)...
Cheers,
jonny
subbrew
Post by subbrew »
I agree the corn flavor is good. I will disagree that extra abv never hurt. extra abv makes for a hot drink with off flavors.
That recipe will work fine if all you are looking for is cheap drink. But that gravity with bread yeast is going to have a lot of esters and high alcohols. I will assume your buddy meant 80 to 90 proof, not abv. If not he would be pushing 18% abv wash but there is only enough sugar in those numbers for a bit less than 12%. And even if he meant proof, if he is getting 3 to 4 L from 5 gal he is not making cuts, at least very loose ones if he is.
Up to you what you make. But that is not a recipe for a quality drink. That is a recipe that gives moonshine the reputation for being rough and hangover producing.
Maverick1988
subbrew wrote: Tue Jun 18, 2024 9:13 am I agree the corn flavor is good. I will disagree that extra abv never hurt. extra abv makes for a hot drink with off flavors.
I agree with you there, I'm very new to this so I'm just going by the reviews on the recipe, and my friend. I know others who tried it from him and they said it was good. but I never have.
jonnys_spirit
Maverick1988 wrote: Tue Jun 18, 2024 9:36 am
This is a good reason to stick with a tried and true recipe from the HD site especially for when you're starting out.. Ton's of info and experience documented with these specific recipes... Recipes from other sources are a crap shoot... At least until you fee confident shooting more from the hip with ferments, distillation, cuts, and aging...
Cheers,
jonny
Maverick1988
jonnys_spirit wrote: Tue Jun 18, 2024 9:59 am
Cheers,
jonny
I'll check it out for sure, I appreciate it.
Honestly, my biggest worry when it comes to distilling anything is making the proper cuts. Personally, I'd like decent volume, but the cuts scare the hell out of me for now.
jonnys_spirit
Maverick1988 wrote: Tue Jun 18, 2024 10:09 am
Cheers,
jonny
Are you running a pot still?
Cheers,
jonny
Maverick1988
Cheers,
jonny
Yup I have a 50L North Still system with a 1750 heating element and a 3Inch copper potstill
MooseMan
Post by MooseMan »
Maverick1988 wrote: Tue Jun 18, 2024 10:09 am Honestly, my biggest worry when it comes to distilling anything is making the proper cuts. Personally, I'd like decent volume, but the cuts scare the hell out of me for now.
Good cuts will only come with practice and experience, my advice on this is to run into small jars and be extra fussy, when you get to a jar that makes you think heads are finished, go one jar further, or two!
Same for tails, slight hint of tails smell, stop collecting in small jars, write off the previous jar or two and turn up the heat and strip the rest.
All the heads you didn't include, add to the stripped tails, and that will all go back into your next run, so being tight on cuts is wasting nothing.
That recipe in your first post?
Just make a UJSSM and be glad you did.
jonnys_spirit
MooseMan wrote: Tue Jun 18, 2024 10:44 am
You can turn this into a UJ if you save some backset and there's tons of support over on the UJ thread...
The good news is that on one hand cuts are a matter of subjective taste - you can make them wider or more narrow. Too wide and you get headaches.. You won't poison yourself or otherwise harm yourself. Too narrow and it's just clean white dog which is a good thing...
If you haven't already check the required reading links at the bottom of every page. There's a newbie's guide to pot stilling cuts which is helpful and many more threads on cuts...
Make your cuts on this run and live with the product. Make more. Rinse and repeat... You'll find your sweet spot :)
Cheers,
jonny
Stilljoy McFlavour
Post by Stilljoy McFlavour »
Considering the title of this post, how could it not be about Uncle Jesse’s Simple Sour Mash. Turns out it is actually your answer.
As for making cuts; I found it extremely difficult to make good cuts when I was starting out. Making a selection based on smells and flavors that were basically all new to me and that I could not identify was almost like flipping a coin. As I did more runs I learned to recognize the various compounds, and making proper cuts became easier and easier.
This guide by kiwistiller offers fantastic advice about getting started with making good cuts
viewtopic.php?t=11640
Maverick1988
Stilljoy McFlavour wrote: Tue Jun 18, 2024 12:46 pm Considering the title of this post, how could it not be about Uncle Jesse’s Simple Sour Mash. Turns out it is actually your answer.
I thoughts about making Uncle Jesse's Sour Mash, But my thought was that i literally started with something more difficult like Whiskey making my own recipe, etc. It seems to be working out so far. So my thought process was try to make this next one as simple as possible.... Corn and Sugar. So I got advice from a buddy of mine who sent me the recipe and it's literally listed as a sort of safe proof recipe.
Basically I wanted to go from difficult to "easy" and see how it goes, just make something that'll be a good base, make decent volume and taste good enough that I can try different flavors in separate jars (Apple pie, lemon drop, jalapeno, etc)
As for cuts, I haven't tried yet with the whiskey because I just don't have the volume (having a 50L still is sort of making it difficult because you have to have so much low wines in order to do a spirit run) but the channel Still it has some quite good videos about making cuts that I find pretty comforting.
At the end of the day, I think I just have to go for it and give it a try.
Homebrewer11777
Post by Homebrewer11777 »
Another vote for UJSSM here. As others have said you are already pretty close to the recipe. Three reasons:
1. It will work really well for your volume issue. Scale each generation to deliver a full boiler. Then combine Gen 1-3 low wines for your first spirit run. Gen 4-6 for your next spirit run, more or less as long as you like. For your boiler I'd scale the recipe to about a 10 gallon batch and then adjust from there. 10 gallon batches should give you about 3 gallons of low wines, 3 of those into a nice spirit run with enough product to enjoy some now while aging the rest.
2. Relies on cracked corn. Cracked corn is cheap--generally cheaper than cornmeal certainly cheaper than corn flakes, and easy to work with in this recipe. Will not give you all kinds of issues separating liquid wash from solids like you will when you get into converted corn recipes.
3. You will get plenty of help from this site. Lots of experience here with UJSSM so always somebody around to answer questions. If you are having a problem it will be very easy to troubleshoot without endless questions trying to figure out what you actually did, likely followed by shoulder shrugging that if you'd only followed the tried and true recipe we could probably help you..
Maverick1988
Homebrewer11777 wrote: Wed Jun 19, 2024 9:58 am Another vote for UJSSM here. As others have said you are already pretty close to the recipe. Three reasons:
I think I found a good source for Cracked Corn that's cheaper so I'll 100% take the advice from people on here, and I really do appreciate it.
My next initial thought is what is a good yeast for high volume?
Even following the UJSSM recipe, I'd be going for volume and a clean product hopefully. I figure a 50L Sugar and Corn recipe should give about 7L-10L of final moonshine at the end to put into individual jars (and flavor of course)
My buddy who showed me the recipe in the first place said he never did stripping runs, he made his spirit runs right away and the product he got was apparently high volume and quite good and I think he said he did it multiple times and 19L washes and said he was getting anywhere from 3L-4L of 80%-90% ABV (I think he meant 80-90 proof, that sort of makes more sense)
I have the Redstar yeast I've been using so far which has worked but not the ABV I was hoping for. I also have two packs of turbo yeast that came with the Still, but I've heard bad things about Turbo Yeast.
Are there Good Yeasts for higher volume and higher ABV?
subbrew
Post by subbrew »
Since you are going for volume and cost then red star distillers active dry yeast (DADY) is a good choice. If you are trying to push the ABV over 10% then a wine yeast such as D-47 will be better.
Maverick1988
subbrew wrote: Wed Jun 26, 2024 12:29 pm Since you are going for volume and cost then red star distillers active dry yeast (DADY) is a good choice. If you are trying to push the ABV over 10% then a wine yeast such as D-47 will be better.
There's Lalvin D47 Yeast on amazon.... is that what you mean?
subbrew
Post by subbrew »
Maverick1988 wrote: Wed Jun 26, 2024 1:05 pm
Yes, that is the one. I usually get it from my local home brew store as I know it has been kept refrigerated. I like D47 as I have found it will withstand an acid environment, into the very low 3.1 or so and still keep going where others will have stalled.
Maverick1988
subbrew wrote: Thu Jun 27, 2024 5:39 am
nice, Maybe I'll try it out
Homebrewer11777
If you follow the TnT recipe you should be fine with DADY. You would only need a more alcohol tolerant yeast if you change the recipe and try to make it more concentrated sugar solution...I'd not modify the sugar concentration in the recipe in hope to generate more booze. It works really well as written.
Pick a yeast that will like your expected fermentation temperature. Remembering that fermentation is exothermic so will tend to run 5-10 degrees above ambient temperature if you are not actively controlling the temperature. DADY likes to be between 80 and 90F. Bread yeast would be at high end of this range. If ambient is 75-80F you should be good with either of these. If keeping the fermentation at or above 80F is a challenge for you you might do better with beer yeast such as US-05 or S04. These do well from mid 60s to low 70s. I'm tending to use DADY for summer fermentations and beer yeast for cool season fermentations.
Maverick1988
Homebrewer11777 wrote: Thu Jun 27, 2024 7:01 am If you follow the TnT recipe you should be fine with DADY. You would only need a more alcohol tolerant yeast if you change the recipe and try to make it more concentrated sugar solution...I'd not modify the sugar concentration in the recipe in hope to generate more booze. It works really well as written.
Thanks I'll check it out. I've never done this recipe or any moonshine recipe before. I've done two whiskey washes. First turned out really well, second turned out okay but very low volume.
This will be the first moonshine experience on my Still.
Typically the fermentation temps range from about 70 F to 90F (I'm in Canada so the weather is a bit colder here compared too the US or other countries.) But I do have a heater int he garage where my setup is. So I can regulate it a bit.
But one day it could be 90F the next day it's totally different.
Maverick1988
What about mixing yeasts?
Twisted Brick
Post by Twisted Brick »
Some pretty good thoughts on mixing yeasts here.
Deplorable's explanation is well said and bears repeating:
Deplorable wrote: Sat Mar 26, 2022 3:46 pm The fermentation process itself is just as nuanced and complex as the alcoholic beverages it yields. Multiple factors influence the concentration and complexity of flavor compounds produced, including the source of sugar, temperature the reaction takes place at, and duration of fermentation. Then there’s the strain of yeast selected for the process. Individual strains perform in different ways depending on fermentation conditions, which ultimately impacts the “building blocks” produced by the strain.
If you're a beginner in this hobby it would be wise to experiment in a more controlled way to decide what strain of yeast you like to use.
You have a few of options available to you from here. You can make more ferments identical to the first two until you have enough to do a double distillation and keep them separate all the way through keeping notes about each.
You can do a one-and-done on each of them and learn a little about each yeast and the flavor it contributes.
Or you can mix them both together and not learn anything about the two yeasts different contributions to the spirit.
It's not uncommon for a yeast to out-perform a second yeast or dominate it flavor-wise. It's doubtful you'd be able to assess either of two yeasts' unique contributions to the spirit (even if kept white) but there's nothing stopping you.
