Hello fellow distillers,
I’ve been distilling for a couple of years now, so still reasonably new to it. I got into it because I wanted to make Limoncello and needed high ABV spirits to draw the limonoids out of the lemon peel. Started off with a Chinese ‘football’ still, then bought a second hand T500. I’ve done around 20 runs with the T500 and have been enjoying it. It creates a great, clean spirit, with very little tails. But, like many others, I have 3 issues:
1. The plastic cap, (I definitely agree with rule 1.i of the Home Distiller board rules “no plastic in the run line”.
2. The lack of a temperature probe in the still column head.
3. Separate water flows for the condenser and reflux columns.
I could include of fourth issue that others have mentioned, that of the column needing to be longer. However, I believe it is always a good idea to ask yourself, "Just because I can, does that mean I should?" I have to admit, I didn’t know the answer to that, so I asked someone who did. I spoke with my local brew shop owner about extending column height. He has used the T500 extensively, and for many years. The only extension he has done is to add a sight glass so he can see what is going on. It makes negligible difference to the finished product. After speaking with him I decided not add any extension on the T500 column. Further reasons being:
• The column height to width ratio is about 1:12, which is less than the ideal 1:15. But the column is married/tuned to the boiler. So, if I changed one, I would probably have to change the other.
• The T500 already produces a high-purity distillate at a very efficient operating cost. The expense of adding a sight glass or a 50cm/19” copper extension and all the fittings ($225AU in 2024), for a negligible improvement in purity doesn’t seem worth it.
My conclusion is that you would be better off buying a different type of still. But, good luck to anybody that wants to try it. Let me know how you go!
I’ve researched other people’s suggestions, experimented with them and come up with three cheap modifications. They require a reasonable amount of workshop knowhow, metalworking skills and tools. Get some help from someone who has these skills if you are unsure. Now some words of warning.
WARNING WARNING WARNING
For those of you who have only recently purchased a T500, before you do any modifications, use it a few times as it is. Get used to it, even if it’s only doing a few water distillation runs.
I recommend this because the first modification BYPASSES THE STILL SPIRITS PRESSURE RELEASE SAFETY FEATURE which allows not only pressure release to stop EXPLOSION, but prevents a vacuum IMPLOSION. So, it is safer if you are familiar with the T500 in its unaltered state before you go modifying it.
If you do decide to modify it, do it knowing that IT IS AT YOUR OWN RISK, AND THAT I ACCEPT NO RESPONSIBILITY FOR ANYTHING THAT MAY GO WRONG, OR ANY INJURIES YOU MIGHT INCUR.
Having said that, I see no real reason for this still to implode or explode if you take the two simple precautions:
1. Drill a hole in the new copper cap column head and put in a thermometer or a piece of cork, and
2. As SOON AS YOU HAVE FINISHED THE RUN AND TURNED THE POWER OFF, carefully/safely, with gloves/eye protection, flip the lid clips, OPEN THE LID and pop something in there (like a screwdriver) to keep it open.
Simple. These safety issues will be discussed in a bit more detail towards the end. But if you are at all unsure what you are doing, speak with a plumber, electrician, or engineer before going forward.
The best part of all three modifications is that you will be able to put your T500 back together again just as it was.
As I am Australian, I have used metric units, with freedom units listed after. I am unfamiliar with freedom units, please do your own conversions if mine seem a bit odd (like I don’t know if there is a such a thing as a 16/64” drill bit!).
The first modification is replacing the plastic cap with a copper one. You will need:
• A 50mm (2”) copper end cap,
• 10cm (4”) of standard, 12.7mm (1/2”) copper tubing,
• Lead free (Aquasafe) solder
• A brazing torch (or the wife’s kitchen culinary torch)
• Teflon PTFE plumbers’ tape
• Stainless steel hose clamps.
• Some O-rings, or the rubber washer from water tap washer (or you can use more PTFE tape if you like).
You will also need a reasonably well stocked workshop.
The 50mm (2”) copper end cap should look like this one:
Make sure with the supplier that the INTERNAL DIAMETER (ID) of the cap is 50mm (actually 50.8mm/2”). The T500 column has an EXTERNAL DIAMETER (ED) of 50.8mm/2”. This cap will fit loosely over the top of the column. A hose clamp and the rubber O-ring inside the cap will seal it.
When you have your parts, take your column apart. Remove the column from the lid. Remove all the packing. Undo and remove the short hose at the top of the column. Remove the press nut/washer at the top of the column by prying it up with a fine screwdriver until you get enough space to grab it with a pair of pliers, then twist and pull it up the pipe. You will probably crush the press nut, but don’t worry, you won’t need it (or you can flatten it out again, or buy a new one).
Undo the 2 top screws, and the 2 bottom screws with whatever you can find to fit them (if you are trying to find the right head for these screws, they are called Robertson screws, also known as a square screw or Scrulox).
Put little smear of Vaseline on the end of the copper pipe that comes out through the plastic cap. Firmly pull up, rock, and twist the black plastic cap until it slides off. Wipe off the Vaseline. Take this opportunity to have a look at the inside of the column and the cap, see how it all fits together and works. Have a smell of your column. Perhaps it’s time to give it a good wash out! I used a long bottle brush, brushing from both ends. Then soak the copper and stainless steel saddles and the column overnight in a weak 1/20 vinegar solution. Give it another brush out the next day. You probably won’t get all the smells out, but it will be better.
Make the End Cap Connector Pipe
Now you have the column apart it’s time to shape the end cap connector pipe. This small pipe will join the reflux column to the condenser pipe. Take your 10cm (4”) of 12.7mm (½”) diameter copper pipe and slide it over the condenser pipe. You’ll notice that it is too large in its internal diameter, by about 1mm (3/64”). Not to worry! You are now going to work on your blacksmith skills. Mark out the last 3cm (1 3/16”) of the 10cm/4” pipe. Wearing gloves and using a pair of needle nosed pliers to hold one end, heat the other end with a gas torch. It doesn’t have to be red hot. Use the pliers to hold it on a piece steel or other hard surface. Then, using a small hammer start tapping on that 3cm (1 3/16”) end, tap it a bit, roll it bit, then tap again. Tap tap tap, roll, tap tap tap, roll. Keep working, tapping and heating it every minute or two. The aim is to reduce the diameter so it is a snug fit over the horizontal column arm pipe. Keep going until you are happy with it. If you’re not happy, cut it off and start with a new piece! It doesn’t need to be tight, just snug, it will be hold in place with a steel hose clamp, so it should slide on and off easily. You should end up with something that looks like this:
Take this opportunity to polish the beaten end up using a wire brush or sandpaper. It’s easier to hold on to and polish before you cut the end off. This beaten end piece of pipe is then cut to the correct length to fit between the inside of the press end cap, over the horizontal column arm pipe and up to the condenser pipe. I cut my piece off at 21mm (53/64”), but like all these measurements, they are for my T500. Please make your own measurements, make sure they fit your still:
Soldering the Connector Pipe to the End Cap
Now to work on the 50mm copper end cap. Remove the black rubber O-ring from the inside of the end cap. Now take a thin piece of wire or a paperclip and make an ‘L’ shape with it, long side about 5cm (2”), short side exactly 6mm (15/64”), like the one in this picture:
Use this piece of wire to find the point where you will drill a hole for reflux cooling pipe to come out. Hole punch at the very tip of the ‘L’, then drill a 6.5mm (16/64”) hole.
(I can only attach 6 photos in one post, so - To be continued....)
T500 Modification Still Spirits Turbo 500 Mod
Re: T500 Modification Still Spirits Turbo 500 Mod
Word of warning: Don’t use PTFE plumbers’ tape instead of solder for this join. This join provides stability between the reflux column and condenser tubes. Soldering is sturdier and safer. Take your end cap off and cool it down with cold water. Then drill one last hole in the top center of the end cap. This hole with house the temperature probe or a small piece of core, and will end up being your safety release valve. I used a 5mm (13/64”) drill and put in a spare temperature probe I had: Put your O-ring back inside the end cap. Put a 53mm hose clamp on the column. Slip the end cap on and pull it down over the column. It will be firm because of the O-ring.
The reflux tube coming out the top of the end cap will need an O-ring, washer, or some PTFE tape to seal it. I had a red tap washer that fit nicely, so I used that.
You can either hook the inlet/outlet hoses and temperature probe up the way there were originally, or go on to the second modification, which is having two input and two output hoses. Whatever you decide, you MUST:
1. INSTALL A SAFETY PLUG IN THE TOP OF THE COLUMN. Either a temperature probe loosely fitted in the top of the column with a bit of PTFE tape, or a piece of cork shaped to fit the hole. This will allow any pressure to be released in the (unlikely) event that your distillation path gets blocked.
2. When you have finished distilling, as soon as you turn off the boiler, unclip and OPEN THE LID. Leave the water running through the still. Put on gloves and safety goggles, undo the clips and tilt the column and put a screwdriver between the lid and the boiler. The first run I forgot to do this. Within seconds of turning off the boiler I could hear gurgling. I thought it was condensate trying to get out. It wasn’t. It was in fact air being sucked back through the distillate hose (where the alcohol drips out) at a very fast rate! I put my finger over the end and there was a definite vacuum. I immediately unclipped the lid, tilted the column and put a screwdriver in there to keep it open. I don’t believe the still would have imploded. But I didn’t want to find out! Taking out the temperature probe at the top would have helped here also. Further notes of vacuum warning:
• Do not distil alcohol above 40% ABV as this could also cause a vacuum, and
• Do not submerge the distillate out tube in a liquid because air cannot flow into the boiler through the outlet tube. This will cause a vacuum and the boiler to implode.
To be continued...
First mod over and done with. Well done!
Feel free to comment or ask question
As for the other mods, they really aren't worth doing. But if you are interested I can post regarding:
- Putting a temperature Probe In The Still Column Head
- Separate Water Input and Output
- How to run this setup double hose and a double temp probe T500 still
- Running the T500 with Two Temperature Probes and Inlet/Outlet Hose
Good job tomlain .
But not so sure about using that cap with an Oring and then a silicone washer on the reflux tube . Kinda defeats replacing the plastic cap . Definitely think your suggestion of wrapping teflon tape around the top of the column and wedging the cap in is a better option .
Just sealing that reflux tube is the issue .
Personally , I’d just solder the whole thing and be done with it .
Hi Yummyrum,
Yes, the o-ring and silicone washer are not ideal. The hose clamps compress the copper end cap and form a pretty tight seal. I agree though, PTFE tape is better and I'll probably replaced both the o-ring and silicone washer with it. Good suggestion!
The hose clamp on the reflux tube makes a air tight seal, so there's no problems there. I've run this setup half an dozen times now and it works like a treat.
The copper end cap is so much better. The Still Spirits people recommend not going over 65 deg C with the temp so has not to warp/melt the plastic column cap (which I've accidentally done). I don't need to worry about that anymore
I did think about soldering the whole thing, but that makes it very permanent. I wanted to make something that could be reversed if I wanted to put the plastic cap back on (e.g. I wanted to sell it down the track). I also like that I can still take it off and give the column a good clean.
Thanks for the feedback.
I tried wrapping the top of the column with teflon tape, but every time I pushed the cap on, it would push the tape down. I decided to bite the bullet and solder it on permanently. I cut it back to just above the o-ring first. Soldering was difficult because the solder just didn’t want to suck in when braising the reflux arm. But I eventually got it to seal airtight with a lot of solder. Now all that remains to do is run a wash through it!
Thanks guys.
Thanks guys.
Nice job
You’ve probably now got the safest T500 out there .
