Simple Column Build
deanodeano
Simple Column Build
I am getting used to my pot still, and of course want to build a column for it as well. It will be attached to a standard 16.5 gallon beer keg I have modified for my boiler and will use the 2" connection. I have been scrolling through several million posts looking for the simplest column I cam to start with. Plenty of time for complications later...
Would it be feasible to simple take the appropriate length of column (3-4 ft?) and simply pack it with the appropriate number of pure copper scrub pads to start with?
I figure a couple of you know exactly where to point me for a simple build. Many thanks in advance.
greggn
Re: Simple Column Build
Your question is akin to me asking my wife "Can you make me a sandwich ?"
There's a lot you need to specify first before pointing you in any direction:
What spirit do you hope to make ?
What's your distilling environment ?
What's your power availability ?
What tools and fabrication skills do you have ?
________________
- Salt Must Flow
If you want to make a reflux column, will you be using it for making neutral?
If so, not only do you need a properly length column, you also need a reflux condenser.
I'd start by learning the different types of reflux stills and how they operate. Each are VERY different from eachother and operate differently:
VM (Vapor Management)
CCVM (Condenser Controlled Vapor Management)
LM (Liquid Management)
CM (Cooling Management)
I very MUCH prefer VM over all other designs. This page may be of some help in having a better idea of different still types, it just doesn't list the pros & cons of each.
The packed column is easy.deanodeano wrote: ↑Fri Dec 13, 2024 1:36 pm
The still head be it VM, CCVM, CM or LM is what you need to decide on.
If I were building a 2" rig a CCVM would be an easy option.
Agree with above . A packed column on it’s own isn’t really going to achieve much more than a simple pot still .
You need a reflux head above it .
Like SMF , I’m also a fan of VM design for ease of operation and it’s ability to cope with variations in power and coolant temp and flow . It is also relatively cheap .
I would strongly recommend putting a 2” tri-clamp fitting between the column and head .
Are you intending to make it yourself or just buy off the shelf modules ?
Don't be put off of the idea of a LM still, they are simple to operate and build in my opinion.
Seems these days that everyone is claiming VM's.to be a superior still .
Probably the simplest of all for a beginner builder is the CCVM.
I'll pick on CM first, since it's what I have the most experience with.
The store bought 2" CM's all have a shotgun dephlegmator and poor control characteristics.
Most use a 6" to 8" tall shotgun that is too damn big and overly sensitive to flow or temp changes.
If you're thinking about a DIY CM I'd recommend a slip in dimroth that clamps on top the column.
LM was once popular for DIY.Saltbush Bill wrote: ↑Fri Dec 13, 2024 7:05 pm Don't be put off of the idea of a LM still, they are simple to operate and build in my opinion.
It's also the only still head that doesn't require a product condenser.
Which still head is best also depends on the cooling water source.
LM and VM are the least sensitive to cooling flow and temp.
CCVM is a little more sensitive and CM absolutely needs constant flow and inlet temp to avoid being difficult to control.
MooseMan
Your head is probably spinning now deano eh!?deanodeano wrote: ↑Fri Dec 13, 2024 1:36 pm I am getting used to my pot still, and of course want to build a column for it as well. It will be attached to a standard 16.5 gallon beer keg I have modified for my boiler and will use the 2" connection. I have been scrolling through several million posts looking for the simplest column I cam to start with. Plenty of time for complications later...
The simple bit then is yes, get enough 2" to make a 20x long packed column, pack with whatever media you can get or want.
Tri clamp top and bottom.
Then decide on the type of head you want (I built a CCVM) and tell us why, and we'll help confuse you further! Haha
deanodeano
@Mooseman: "Your head is probably spinning now deano eh!?"
LOL, a little? I didn't know what I didn't know, i.e the head differences. VM, CCVM, CM or LM....
I have some reading and absorbing to do. I am comfortable fabbing copper and SS. I built my pot still and Liebig without any significant distress.
- Salt Must Flow
deanodeano, one thing that hasn't been mentioned when considering a reflux column is 'height'. The rule of thumb is for the packed column to be at least 20 times the column's diameter. So for a 2" column, you want at least 40" of packed column. 3" needs at least 5' of packed column. I'd read up on 'take-off rates' of packed columns too. Many, if not most, agree that 2" is SLOW. 3" can be at least twice as fast (around 3-3.25 liters per hour at 2750W) and uses twice the power as 2". 4" can be twice as fast (6 liters per hour or so at 5500W) and use twice the power as 3".
I knew I was into making neutral long term so I went straight to 3". After years of use I recently upgraded to 4" and really appreciate the time savings. Available height is a factor to consider if you're limited.
One last critique would be boiler size. 2" and 3" is perfectly suitable for a 15.5 gal keg boiler. A 4" column is better suited for a 30 gal boiler.
deanodeano
[/quote]
OK Boys and Girls: Can anyone point me to clear plan to build a CCVM?
[/quote]
SW_Shiner
- Salt Must Flow
googe
Gregn's reply about what you want to make is your starting point. All the rest is mute.
"Homer J Simpson"
"Homer J Simpson"
quadra
Nice! The nice thing about building a packed column with ferrules top and bottom is you can put whatever you want on top... need something quick and low tech? build a coil and Boka head this weekend and run that on your column while you build a condenser!.... then hang that off a CCVM head and reuse your coil..... and next you might feel the need to maybe add a sight glass....
Do you have any ferrules, clamps or tube on hand or will you be ordering supplies? How are you heating? And how much power do you have to work with?
googe
Hopefully he clears this up.Salt Must Flow wrote: ↑Fri Dec 13, 2024 2:02 pm If you want to make a reflux column, will you be using it for making neutral?
"Homer J Simpson"
"Homer J Simpson"
MooseMan
[/quote]
SMF has provided loads of links with reading through mate, but take a look at my build thread too, I was given tons and tons of help which led to me building something that I'm still running completely unchanged.
Maddogbrewing
I’ve been running my 2”CCVM still for about a year it is very simple to operate, but if I were to start a again I’d make it 3” atleast with two kids its not always easy to spend the day watching the still.
MooseMan
As funny as this is gents, hopefully deano is too busy reading his way to a full understanding of reflux still heads and how to make one, to pay much attention.
But I'll echo what Maddog said earlier, 2" would be a little slow to run regularly.
I have 2.5" piping on my CCVM and if I go much above 1.6l/Hr I drop below 95% ABV.
For me that's fine as I only run it a few times a year for gin stock, but 3l/Hr would be nice.
