Still ID
Joe90
Still ID
Post by Joe90 »
A colleague gave me this set up recently:
The only info I've been able to find is a cover page stating its a Mk13 BR reflux still made by Spirits Unlimited in NZ.
It's basically a 20L aliminium pot and dome, Stainless column and condenser with external water cooling in plastic tubing. Small hole with grommet in the dome for a thermometer.
At the moment there isn't any packing in the column or condenser.
Can anyone provide a bit more info on this one? I'm thinking I may be able to use it as a pot still.
I'm currently learning with a bog standard copper T500 reflux. Not in a great hurry to change things up at the moment.
Re: Still ID
It is one of the earlier CM reflux stills . With the column packed , you could probably expect about 85-90% abv off a Turbo wash and maybe around 80-85% off a Birdwatchers .
The coolant flow through the coil at the top of the column (Tower) acts as a deflegmator . There will be some increase in purity but due to the short column length , not much higher than high 80s.
Without packing , the defleg will potentially hold back tails a bit as a Pot still .
If you disconnect the water supply from the coil and just use the condenser , it would make a little Pot still . However , that condenser is pretty tiny so it would not handle a lot of power . Probably great for a little spirit run but painful fir doing stripping runs .
Also be aware that Aluminium is not the greatest as a boiler due to the high acidity of most washes .
There is also no copper in the still which is desirable .
Simple solution is usually to put small copper pieces in the boiler , but that would be very bad with an Aluminium Pot .
Maybe it is best left on the shelf
Edited :same time as Steve broady
Steve Broady
Re: Still ID
Post by Steve Broady »
If that thing is aluminum, you might not want to use it. That’s a bit controversial here for safety reasons.
Re: Still ID
To put it bluntly it's a badly designed outdated reflux still.
Also as others have stated aluminium isn't the best choice for a boiler.
Wash and backset or dunder are acidic, acid and aluminium don't play well together longterm.
Joe90
Re: Still ID
Post by Joe90 »
Thank you for the info guys. I'll keep pottering along and working my way through reading on here. Currently have a TFFV fermenting away.
