New boiler with tiny leaks (driplets)
Hello.
I have just washed and filled my new milk can boiler from Oakstills with water to check it for leaks. I found several small leaks from where top part of the milk can is soldered to the main body. Tiny driplets are forming in several places and dropping down. Is this normal (to be expected) or something I should complain about? It’s new.
I have no clue how to solder stuff but is there something I can do myself to fix it, besides plastering the spots where it leaks with flour paste?
Curiosity may have killed a cat but if you’re too old to learn chances are that you’ve already passed away. I am reviving distilling after 30 silent years.
- Salt Must Flow
Re: New boiler with tiny leaks (driplets)
In this recent topic someone ordered an onion from Oak Stills and it arrived with a dent. They contacted Oak Stills and they are supposedly sending him another onion without the need of the original onion being returned to them. It is possible that they would replace the boiler without you needing to return it too. I imagine Oak Stills would like to see clear photos that show the nature of the problem before they would make any decisions. That would only be reasonable request.PalCabral wrote: ↑Thu Jan 16, 2025 12:00 pm Hello.
If I had two boilers for the price of one, one with leaks, I would feel like it's an opportunity to learn how to solder. It's really not difficult. If you can find a local guy who TIG welds, he could fix those spots with some quick spot welds too.
Thanks for reminding me of this thread - I remember it well. I will indeed follow your advise.Salt Must Flow wrote: ↑Thu Jan 16, 2025 12:08 pm In this recent topic[/url] someone ordered an onion from Oak Stills and it arrived with a dent. They contacted Oak Stills and they are supposedly sending him another onion without the need of the original onion being returned to them. It is possible that they would replace the boiler without you needing to return it too. I imagine Oak Stills would like to see clear photos that show the nature of the problem before they would make any decisions. That would only be reasonable request.
About the welding, not so sure. But you are right, it's an opportunity to learn. What does TIG stand for?
TIG stands for tungsten inert gas. It is the most common form of welding used on stainless steel.
- Salt Must Flow
Tungsten Inert Gas.PalCabral wrote: ↑Thu Jan 16, 2025 12:21 pmThanks for reminding me of this thread - I remember it well. I will indeed follow your advise.Salt Must Flow wrote: ↑Thu Jan 16, 2025 12:08 pm In this recent topic[/url] someone ordered an onion from Oak Stills and it arrived with a dent. They contacted Oak Stills and they are supposedly sending him another onion without the need of the original onion being returned to them. It is possible that they would replace the boiler without you needing to return it too. I imagine Oak Stills would like to see clear photos that show the nature of the problem before they would make any decisions. That would only be reasonable request.
No, that is not normal. Your boiler should not leak anywhere and it should be fixed. I would call the company and work something out to have it fixed or replaced.
Thanks guys. I have already sent a mail to the supplier to get it replaced.
Totally agree with Otis , you definitely don’t want any leaks . Depending on what you hang on it , they could get worse with time .
Out of curiosity , can you post some pics here .
- Copperhead road
Leaks are a SAFETY RISK with alcohol vapour especially when running gas boiler!
I would send it back to them for a replacement, I assume it’s new ???
I would like to see pictures as well if you can post some? Is it continuously forming new droplets, or could pockets of water from washing been trapped in small voids along the joint line? I would grab a small mirror and light and have a good look at the seam on the inside of the jug as it may have been soldered there for cosmetic finish on the outside, and if the full overlap was not completely soldered there could be a simpler explanation... ( hopefully.. ) you could also invert the jug and dry it thoroughly along the joint line with a heat gun to drive out any moisture that might be trapped.
It's not normal to have leaks.PalCabral wrote: ↑Thu Jan 16, 2025 12:00 pm
Make sure it's actually leaking, since there's several places, possibly it could be condensation due to high humidity and cold water in the boiler.
Contact the seller, show them the problem and hope they make it right.
What ever the outcome, let us know.
All.
Some feedback on this topic. Contacted Peter at Oakstills and we agreed they will send me a new boiler. They listened to my complaint, I shared photos of course, and they proposed to replace it themselves. As far as I know, they are not requesting me to send the old one back.
Oakstills Customer Services impress me, there was no problem or issue with my complaint (as it shouldn't). Thank you all for your concerns, questions and feedback.
