New Pot Still I am Going to Put Together >
Turbo6ta
Post by Turbo6ta »
I am am very new to home distilling and know nothing about stills, so I ordered a cheap 3-gal Vevor pot still that I have not even unboxed yet. This was ordered prior to me being a member of the Home Distiller Forum. After reading how poorly designed the Vevor is here on the forum, I am sending it back to the vendor.
My latest plan is to put together various parts mostly purchased from Lion Brewing Solutions (an ebay vendor). I have not found a cheap 5-gal boiler pot anywhere that I can adapt other parts to, so I am going to purchase another cheap Vevor still in the 5-gal size for $67 and just use the 5-gal pot from that still. I will need to drill a 2" hole in the center of the Vevor lid in order to mount the 2" weldless tri-clamp fitting and then the distilling column.
I plan on adding a 2" slight glass and useing a 2" Liebig style condenser ... The condenser is fairly short at only 8" long, but it has 4 condenser tubes in it that are each 1/2" wide ... So that gives the 1/2" wide tubes a total length of 32" ... I think that should be enough for a fairly small 5-gal pot distiller.
Total price for this setup will be about $248 ... I could spend more for a different setup, but this should do ok for me right now (I hope).
Like I said, I am very very new to all this ... I am open to any comments, positive or negative.
_____________________________________________
Image . . . . . . Image
Rusty Ole Bucket
Re: New Pot Still I am Going to Put Together >
Post by Rusty Ole Bucket »
Check out my Electric Boozaloo II build thread below in my signature. I used that exact still, site glass and bulkhead to upgrade a 9-gallon Vevor electric kettle. Just as a little FYI, it's a tiny shotgun condenser, not a Liebig. It has been able to keep up with the Vevor kettle, no problem, but it's only about 1300 watts of power.
Lion Brewing has been a good vendor for me, I've bought a lot of parts and stuff from them.
Rusty
The Horny Goat Build
Electric Boozaloo II Build
Turbo6ta
Post by Turbo6ta »
That 'Boozaloo' build of yours is pretty nice. I really like how your heating it. I would do a heating element like that, but my little pot is only 5 gal, so I just going to heat it on my electric glass topped stove.
Rusty Ole Bucket
Turbo6ta wrote: Fri Mar 07, 2025 1:05 pm That 'Boozaloo' build of yours is pretty nice. I really like how your heating it. I would do a heating element like that, but my little pot is only 5 gal, so I just going to heat it on my electric glass topped stove.
Thanks, it was a fun build and works pretty good. I was lucky I found that electric kettle on Facecrack. You may very well have more power with your stove burner, depending on your stove you have 2000 to 4000 watts or so.
Rusty
