Gin Basket Considerations
Spokerider
Post by Spokerider »
Gents,
I am considering buying a retail gin basket assembly, for a pot still.
No, I have never had one, nor have I seen one in operation, so I essentially know little about gin baskets, design, and use.
Of the retail options available to me, one design is "inline" with tri-clover fittings top and bottom, and the other design has a side-inlet and a side-outlet tri-clover fittings. Another notable difference between these two designs is, the side-inlet / outlet design has a 3" diameter main body, so it's basket is larger with more capacity, and it's design has a removable top, and a drain valve on it's bottom.
The pot still that said gin basket will be installed on, has 2" tri-clover fittings and is of 2" copper tube construction.
Looking for feedback on these designs please, your thoughts, and experiences with a gin basket on a pot still, are welcome please.
Re: Gin Basket Considerations
Why do you need one? I have two types of basket and seldom use either of them for gin.
Commercial ones look, to me, like they have been built by people who have never run one and have simply copied bad designs that they've found on the net.
The inline ones are very small and only have enough room for a few peels.
Many of the offset ones I've seen for sale are very small. If they won't hold enough volume of botanicals, leave them in the shop. They shouldn't need a drain valve as the desired VOCs should all be in the collection jar, not puddling under the basket, so that's an indication that they have been designed without doing enough research or running them.
I have to agree with Chris, how far down the Gin making path are you?
Have you learned to make good Gin without a Gin basket before wading even deeper into the Gin pond?
Spokerider
Thanks guys, for chiming in.
I am making, as my first attempt, a heavily-peated whiskey. It is pretty much Odin's Corn Flakes Recipe except I am adding peated malt barley to it, at 1lb of barley per gallon of mash.
In my parts, heavily peated barley is spendy stuff, at $12.50 per kg, when I can get it. It is taking some effort, and ingredients, to make enough hearts to fill a 6 gallon bourbon barrel.
Now, there is a local micro distillery that is / was experiencing the same peated malt supply / cost issues as I am, with making a heavily peated product. They came up with an innovative plan to make and use a gin basket, to instil the smokey peat flavour into their pot-still heart run. They claim that this worked great with much peat flavour, and with little peated malt needed in the gin basket, compared to mashing it. Have a look.
https://distilling.com/distillermagazin ... nnovation/
So, this is my end game. If my whiskey is still not peaty enough for my liking with just mashing technique, I will try the spirit run with some peated malt a gin basket. But first..... i need a gin basket.
Anyone done this??
Peatreek? I dunno. Maybe.... seems like very mixed opinions.
Using venturi smoke generator, and bubbling peat smoke into a concentrated solution of hearts....... maybe another option.
Right now, i am trying to determine if a gin basket in in my distilling future. I might even try other aromatic instilled recipes.
In that case, work out how much volume, width and height you need to match your still charge and don't build or buy undersized equipment.
They use an offset basket because they don't want to stink up their boiler. If you don't care about that, inline might do.
Also, if your basket is large enough, you could do a multi-shot run with some heart cut to make an essence to blend with existing stock.
Spokerider
Thanks Chris,
How do I know or recognize if xx brand gin basket is correctly sized for a 15 gallon boiler, or not??
You have mentioned undersized gin baskets in a few of your posts before, with passing on your gin basket advice and thoughts before, so i understand this question may have been previously queried by others.
Would a 15" tall, "inline" gin basket kit, made from 2" diameter tubing be considered too small for my needs?
What about a 15" tall, 3" in diameter "offset" gin basket kit? Would it too, be too little capacity for a 15 gallon boiler pot still with 2" copper? I can buy either, retail.
If I tig fab one, I can essentially size it to any reasonable capacity.
I do not know what volume parameters ought to be met, to correctly size a gin basket kit, to a particular still.
howie
Post by howie »
i have one of those gin baskets with 2" inlet & outlets and 4" body
i used it twice and it's now gathering dust.
i found that the vapour was entering the body and too much was condensating on either the botanicals or the SS basket.
this resulted in a puddle forming at the bottom of the body.
this puddle gets deeper as the incoming vapour cannot reheat the puddle.
then as the puddle gets deeper, you have the choice of dumping precious flavoured liquid via the body valve, or letting it run back down the 2" inlet pipe & back into the boiler.
i have seen a couple gin baskets with either a thumper or bubble plate type arrangement.
Insulation should stop the puddling.
You will have to work out the volume of grains that will be in the basket, then decide on, or research, a suitable height of grain so that you can calculate a minimum diameter for the basket. I can't help with that except to say that the higher the stack, the more backpressure to expect and the narrower the basket the higher the vapor speed.
I do not know if starch would drop down into the pot to burn onto an element if the basket wasn't offset. If you have a saucepan and steamer, you could do an experiment using that. Steam some grain for a few hours then do a starch test on the water, (or boil it dry?)
Tammuz
Post by Tammuz »
I would plan on an off set basket. If it's inline whatever you put in it will have the heads run thru it. Off set you can add after the heads,plus you can swap out more or different botanicals during the run. And those who say they would have a drain haven't ran bookoo botanicals. There are some whose oils are heavy which you could collect an use the essences in other things. The cost is minimal. Plus you can use this as an extension if you're going for a higher abv.
I bought some SS baskets they use for smoking nuts that fit my 3" perfectly.
Igitur qui desiderat pacem, praeparet bellum or party till the cows come home!
NZChris wrote: ↑Fri Mar 28, 2025 1:16 pm Why do you need one? I have two types of basket and seldom use either of them for gin.
Maybe to put the orange peel and citrics in the basket and the other botanicals in the pot. :ewink:
shadylane wrote: ↑Tue Apr 01, 2025 2:32 am NZChris wrote: ↑
[/quote]
Not saying one method or the other is right or wrong,
But peel in the boiler has always worked just fine for me......and while the amount used is small the flavour still comes through.
0.2g of lemon/lime zest in a 2L boiler charge at 45% is all that is needed imo.
Maybe Botonical Basket is a better name. OP called it a gin basket but it can be used for essential oils. I use the same homemade basket for both essential oils and gin. I use it on my 5 gallon pot. Below is a link. With gin I do macerate the botanicals first using Odin’s method.
viewtopic.php?t=63987
HeyBroChuckNorris
Post by HeyBroChuckNorris »
Spokerider wrote: ↑Fri Mar 28, 2025 2:34 pm Thanks guys, for chiming in.
Anyone done this??
I'm in the same city as you, and read the same article. Did you end up having success with this method? Tried anything else besides peated malt? Off topic: Do you know anyone else in the hobby locally? It would be great to have some additional contacts to speak/share/trade with.
