blucs mash on the grain continous stripper.
We don’t condone the use of Continuous Stripping stills as a method of running 24/7 as this is a commercial setup only .
Home distillers should never leave any still run unattended and Continuous strippers should not be operated for longer periods than a Batch stripping session would typically be run to minimise operator fatigue..
bluc
Post by bluc »
Starting working on a continous stripper to steam distill on the grain. I am currently redesigning the failed continous steam gen design. very early days and not much to report yet.plates a perf plates with 6mm holes on a 8mm rod so plate tree style. Its in a 2.5" section. Heres a couple photos
This topic has 223 more replies
Register Login
