condenser help
kentuc
condenser help
Post by kentuc »
Building a new reflux condenser for the top of 2" vm column what size tubing do I want (o.d or i.d)? and what size tubing do I need to wrap it around? just looking for the basics :oops:
The true measure of a man is not how much money he has or how many toys he has. It's how many people show up at his funeral to celebrate his life.
Hawke
Re: condenser help
Post by Hawke »
You want 1/4" O.D. soft drawn tubing. May be cheaper for you to buy an icemaker hook-up kit, then to buy just tubing. Has been for me anyway.
If you are just doing a single coil, you can wrap it around something with an O.D. of 1" or 1 1/4". I used 1" pvc pipe for one of mine. It's best to fill your tubing with either salt or sand, I prefer salt because it is easier to get back out.Takes a little time to get it filled, but well worth it.
kentuc
Re: condenser help
Post by kentuc »
Thanks Hawk! What if its a double coil? use 3/4" od?
Hawke
Re: condenser help
Post by Hawke »
Yes, start with 3/4 for a double. I like to use a 'coldfinger' return as it adds some extra cooling and takes up more space. There is a stickie post here somewhere on winding coils. It would be well worth the time to read it.
HookLine
Re: condenser help
Post by HookLine »
kentuc wrote:Building a new reflux condenser for the top of 2" vm column what size tubing do I want (o.d or i.d)? and what size tubing do I need to wrap it around? just looking for the basics :oops:
For 1/4" tube I use 3/4" and 1 & 1/4" to wind it on. Overall coil length about 6-7" is enough.
Be safe.
Be discreet.
And have fun.
Tatt2d
Re: condenser help
Post by Tatt2d »
Hawke wrote:Yes, start with 3/4 for a double. I like to use a 'coldfinger' return as it adds some extra cooling and takes up more space. There is a stickie post here somewhere on winding coils. It would be well worth the time to read it.
I always thought the cold finger was the supply side of the coil...???
I ask because I dont know better...
My first drops of distillate fell on Nov.18 '08 quickly followed again 10 days later. I'm hooked...
I run a 1.5" reflux column 51" tall. It is a CM rig... Yea, I know... - researching LM/VM now...
Hawke
Re: condenser help
Post by Hawke »
Tatt2d wrote:I always thought the cold finger was the supply side of the coil...???
Not so, you want the cold water working from top to bottom, through the coil(s). (counter flow)
