Continuous plastic distillation
Bolverk
Interesting video on continuous distillation of solid plastics to make fuel
https://www.facebook.com/share/r/16pQYrUbWP/
- LWTCS
Re: Continuous plastic distillation
I wonder if the gentleman's machine will produce more fuel than the "fuel" needed to operate the machine?
- PalCabral
The "plastic burner" has a popular place in the world of Swedish Moonshiners. It's cheap, it's... cheap. And you can make booze from it. Ironic that Sweden has built up a reputation of making stainless steel and products from it. But it's cheap!
Ongoing projects: Yellow Diamond Oated Bourbon v2; A Neutral spirit based on whiskey feints.
- contrahead
! Microwave ovens typically use between 600 to 1,000 watts. So if he will be using 8 magnetrons continuously, that's something like 4,800 to 8,000 watts; right? Guesstimating that his machine (if it works) will draw between 115,200 watts – 192 kWh /day ? (That's like the daily usage of 3 to 6.5 average US. households).
I thought people separated recycled plastics, because the chemistries were incompatible. (Only PET and HDPE are commonly recycled).
Omnia mea mecum porto
Bolverk
Probably not, but i saw another video where a guy was working with him to rig it up to solar and if thats the case then this could definitely fly
Bolverk
The auger thing was kinda cool, kinda like a horizontal spinning band design...
May be something worth looking at for height challenged locations
- LWTCS
Well, I'd like to see the thing process some finished product.
Bolverk
Should be able to use it as the stripper, then maybe a short vertical CM/LM for finishing?
- LWTCS
Been watching several of the kid's videos.
He has a long road to hoe imo.
- LWTCS
Saltbush Bill wrote: ↑Mon Jun 30, 2025 1:56 pmYou beat me to it Larry, that was going to be my first question.
Seems like he is still working on proof of concept for his machine?
- Rusty Ole Bucket
Interesting video, I use solar for part of my electricity, you'd need quite the array/battery bank to run that. My wife dabbles with prepping and one of the things she wanted to look into building was a plastic recycling still using propane or a wood rocket stove. The nitrogen atmosphere or working in an absolute vacuum is the hard part, vapor capture isn't easy in an off grid situation either. I researched it for a while, and came to the conclusion that making booze was easier and a lot more fun so I joined HD.
I bet I'll be more popular than the diesel guy after the apocalypse.
Rusty
Rusty
The Horny Goat Build
Electric Boozaloo II Build
Definitely not at a hobby or experimental scale.
I think there's better and more efficient ways to recycle plastic than to try turning it into fuel.
I watched the video but it was very poor so I can't say what it was about.
Based on comments there must be more than I'm seeing.
