my last rum was a bit overpowering for me.... half of it is going back in with what i'm running now...two strip run's of pugi rum, fallowed by a spirit run of both...if i just open my boiler and pour these low wines back in and run em'in 100% dunder will my rum be super heavy again....??...
i can cut this dunder half with water or use all water... any thoughts would be helpfull and appreciated....gonna take a little break when this second strip run finishes than fire em' back up in a couple hours...
spirit run in 100% dunder...?
Re: spirit run in 100% dunder...?
Id lose the dunder and use water
I've learned that rum can be difficult to get the cuts right on the tails. I tend to screw up my cuts when doing them as I do whiskey. Rerun it with water and make conservative cuts but wait til after a few days of airing and then make careful cuts. Then try it and see how you like it. I don't like it heavy I know that. I've also learned that young rum is extremely surprising in flavor and needs aging.
thanks for the quick response guy's...left out the dunder and ran both strips and the too heavy rum together...goona leave these jars on my cutting bench for a day or two... i smell tails kicking in in the 64% jar... i have the same tails cutting thing going on... the last rum i think i used 84% - 54%... .. i cut em 'more coservative this time....
I have zero experience with rum yet but, I air my neutral for over a week prior to bottling.
I ask because I dont know better...
My first drops of distillate fell on Nov.18 '08 quickly followed again 10 days later. I'm hooked...
I run a 1.5" reflux column 51" tall. It is a CM rig... Yea, I know... - researching LM/VM now...
