amh71 wrote: ↑Fri Jul 25, 2025 8:13 am
Dammit, I just talked myself out of building a burst fire controller because of the led flickering, plus the fact there is nothing actually wrong with my current one.
Then along comes something even newer and even more shiny to build!
amh71, don’t be put off by the LED flicker on the Burstfire controllers . It is a thing but not everyone suffers from it .
This topic may go a few ways , but I believe it is the way forward .
shadylane wrote: ↑Fri Jul 25, 2025 5:24 pm
Archaic is a plug and play, variable auto transformer that's adjustable from zero to 120%
Try getting that range with any other option
If running a still off DC, I'd use IGBT's and PWM for control.
With AC, a cheap, simple and readily available phase angle control works best.
You are correct on both accounts Shady .
If I could get my hands on …. And lift
a Variac that could handle 10kw , I would . And be proud to call it archaic
Also agree that phase angle controller ( SCR or SSVR ) is the simplest solution for AC .
But , they are crude .
The linearity of control sux .
The range of the pot sux .
The metering accuracy due to the chopped wave sux.
What they do to meters sux.
And they are so simple that there is no challenge ….that really sux
Run your AC through a Bridge Rectifier , then you have DC . What are the choices
……IGBT with PWM control .
