Circulating wash in a fermenter
For a year now I have been using a Magnetic drive pump to recirculate wash in my 200 litre fermenters after noticing it at our local Bundaberg Rum Distillery .
They have a couple of fermenters running but always one has wash pumping in and spraying into the tub . My thinking has been that it is mixing the ferment and Oxygenating it during the Yeast budding stage .
When you make a batch in a 200l (55 US gal) barrel , it is hard to mix it even with a paint stirrer , it doesn’t get all the way to the bottom . So there is a sugar or Molasses layer down low and added water up the top . Usually you’d add hot water at first to dissolve the sugar and/or Molasses , then top up with cold water .
So I’ve used the pump to pull from the bottom and squirt in the top for the first 12-15 hours to mix and Oxygenate .
This got me thinking .
If I could continue to recirculate the wash but not Oxygenate it , then it could maintain a more constant temp throughout the fermentation .
In winter , I have to wrap my fermenters in a couple of woollen
Blankets and add two Aquarium heaters to keep it warm .
But although the top seems warm , the bottom is almost 10° colder
. Fermentations can take several weeks to finish .
So I added a small length of hose to keep the return below the surface after the first 12 hours .
Temperature of the fermenter from top to bottom was stable .
Ended up only needing one aquarium heater and one blanket .
Wash fully fermented out in just under 7 days verses 2-3 weeks
Re: Circulating wash in a fermenter
Thinking about this on AHD forum today , could switch out the Aquarium heater for a RIMs tube inline with the return to the fermenter .
But figured typical big element is way overkill. Why use a 1-2kw RIMs Element when really only a few hundred watts is needed if that .
Then I figured , what about cooling in summer ?
Did some online fantasising and seems there are some Peltier coolers that could be plumbed inline with recirculating pump .
Heater in winter and cooler in summer . Just got to reverse supply to the Peltier's .
As Bluc pointed out to me elsewhere
, they are probably anodised Aluminium so not great for pumping wash through , but the concept is good . A work in progress
- Tammuz
I have no problem protecting my wash from cold temps (cold morning might be 68° F) but planned on using my dspr400 to help with the heat. I have two entry ports at the bottom of my 220l fermenters for air. This upward flow should work, not sure about a heavy grain mash as I've not tried it yet. I had it set up with a drywall mixer, but I feel more confident to use air when I'm not there watching.
Good luck with your project.
Igitur qui desiderat pacem, praeparet bellum or party till the cows come home!
quadra
Yummy you could easily make that a closed loop heater/chiller with a copper immersion loop and small pump.
- NZChris
Heat rises, so I only ever add heat from underneath the fermenter so that stratification is unlikely to cause me a problem.
When I want forced circulation, I put an aquarium air pump in the headspace of the fermenter and weight the air stone to keep it at the bottom of the fermenter. Because the pump is in the headspace, once the oxygen has been displaced by carbon dioxide, it is only pumping carbon dioxide, which does a great job of agitating my washes.
I do have 12V pumps that I could use as you suggested, but never considered using them.
- NZChris
I'm a control freak when it come to ferment temperatures.
For cooling in summer, I point a fan at loosened lagging, controlled by the same STC-1000 that is controlling any heating elements that are underneath the fermenter.
Yummy the more I read and learn the more I'm inclined to do what ever I can to slow my ferments down.
I'm over the hot n fast thing.
Something here of interest.
“The yeast employed will determine the final taste and aroma profile," says Jamaican master blender Joy Spence. Distillers that make lighter rums, such as Bacardi, prefer to use faster-working yeasts. Use of slower-working yeasts causes more esters to accumulate during fermentation, allowing for a fuller-tasting rum.”
“Different strains of yeast work at various speeds and may also result in distinct flavours. Fast fermentation produces a lighter wash that tends to be favoured in white rums.Meanwhile, darker rum merits a slow and careful fermentation where yeast is gradually added. The rate at which yeast consumes the sugar will also be affected by various minerals.”
Fermenting a type of light rum can be completed in twelve hours. It usually lasts between 24 and 36h. Puerto Rico and Cuba are the main producers of light rum, followed by Jamaica.
After slow fermentation, which can last up to 12 days, we can also get an rum heavier by the addition of dunder (deposit remaining at the bottom of the still after distillation). Rums types like Wedderburn and Plummer, which are traditional products of Jamaica, result from the slow fermentation. Those from Martinique, are also heavy beverages obtained by slow fermentation.
Finally rums of high ester content are made in the same way as the Wedderburn pushing further research of these substances.
Who is Joy Spence?
https://en.wikipedia.org/wiki/Joy_Spence ......google the name and there is more.
Who is Joy Spence?
Quadra , are you suggesting just to replace the Silicone hose with a solid copper loop ? That could be easy to do . Or do you mean something else ?
I just used the hose and pump as I switch them around all the time , but could buy a dedicated pump and leave it permanently set up …...except it might need removing as I usually take my barrel outside afterwards and jive it a good hose out .
Agree , this might not be any good for fermenting on grain or thick mashes .Tammuz wrote: ↑Sun Aug 03, 2025 5:36 am I have no problem protecting my wash from cold temps (cold morning might be 68° F) but planned on using my dspr400 to help with the heat. I have two entry ports at the bottom of my 220l fermenters for air. This upward flow should work, not sure about a heavy grain mash as I've not tried it yet. I had it set up with a drywall mixer, but I feel more confident to use air when I'm not there watching.
Yeah your idea of pumping air upwards makes sense , certainly in the initial stages and would work well for the thick mashes . . But would have to cut it after 12-15 hours .
I tried a cabinet with a few heat lamps down low . That was with 80litre fermenters .NZChris wrote: ↑Sun Aug 03, 2025 11:07 pm Heat rises, so I only ever add heat from underneath the fermenter so that stratification is unlikely to cause me a problem.
Now I’m using 200litre , it’s a bit harder to support the weight and keep it enclosed .
This was on a SSS where quick is going to produce less flavour .Saltbush Bill wrote: ↑Mon Aug 04, 2025 1:19 am Yummy the more I read and learn the more I'm inclined to do what ever I can to slow my ferments down.
Back in the wine days , the same principle was used . If you want a clean tasteless wine , ferment fast . If you want a Wine to have character and pickup the flavours of the fruits , ferment slow .
So I guess thats the same principle .
For Rum , I’ve only ever done it in Summer .But up here ,Summers are hotter than NSW so I am looking forward ti being able to slow things uo a bit too .
- NZChris
I sit my 200l on three bricks, wrap it in old sleeping bags and put 50-100W underneath depending on the season. In summer, I usually have to loosen the lagging and point a fan at it while the ferment is going nuts.Yummyrum wrote: ↑Tue Aug 05, 2025 12:35 amI tried a cabinet with a few heat lamps down low . That was with 80litre fermenters .NZChris wrote: ↑Sun Aug 03, 2025 11:07 pm Heat rises, so I only ever add heat from underneath the fermenter so that stratification is unlikely to cause me a problem.
- NZChris
Not all commercial rum distillers strip their ferments as soon as they finish. I read about one that leaves theirs for six days after they go dead, which occurs at around 72 hours, to allow for flavor development. I've taken to following their example.
quadra
Yummy I am thinking a scaled up version of a homebrewing immersion wort chiller would work well. Pumping in one direction, the coils passing through the top layer could scavenge heat and move it to the bottom to reduce the temperature stratification. Changing the flow direction could help with cooling. Using that unit you show above or pumping through an external heater/ fan and condenser would help better regulate the tank temperature and stratification.
In beermaking I always preferred these simple coil immersion chillers over the counterflow style or plate chillers as I could inspect and clean them much easier... and they are the cheapest option of the three.
Although a good counterflow chiller sure is tidy and compact for cooling clean liquid beer or wort with, an immersion chiller will allow you to work with anything from liquid to high solids mash.
Been thinking some more . Peltier's have a max heat transfer of around 18-20°C .( the difference between one side if them and the other)
So that might work in Summer to pull the heat out and keep a fermentation around the 25°-28°mark but it wouldn’t have the heating capacity in winter when the ambient drops down much below 10°C at night . A RIMs tube with element is probably much more efficient .
Also thinking maybe a 200-300w aquarium heater set up in a RIMs tube . Then no need for PIDs and jazz .
Agree ,many do Centrifuge to keep the pipeline flowing ( and keep the Continuous stripper free of buildup ) .
I’ve always left my Rum washes rest for a week before running to let the mud settle .
Didn’t know that some commercials do it too , but it works for me .
And if it aides flavour , then I’ll keep doing it that way
Salty , years ago I read some old paper about Rum production that said just that .Saltbush Bill wrote: ↑Mon Aug 04, 2025 1:19 am Yummy the more I read and learn the more I'm inclined to do what ever I can to slow my ferments down.
I'm over the hot n fast thing…….
They add Dunder to deliberately slow down the fermentation .
Buggered if I could ever find it again .
I always think “Why would a Commercial distillery slow thing's down when fast means more bucks quicker”
So you are probably right . Slower means more and better flavour .
- NZChris
Continuous is another ball game altogether to pot stilling as they need to do clarification trickery in order to keep their plates from blocking up rapidly, which demands shutdowns for de-scaling.Yummyrum wrote: ↑Tue Aug 05, 2025 11:44 pmAgree ,many do Centrifuge to keep the pipeline flowing ( and keep the Continuous stripper free of buildup ) .
And if it aides flavour , then I’ll keep doing it that way![]()
Yeep
From time to time while trawling the net I come across other things that allude to slower being better, Its usually when ive had a couple to many Rums, when I think to look for them again i can never find them.Yummyrum wrote: ↑Tue Aug 05, 2025 11:49 pm Salty , years ago I read some old paper about Rum production that said just that .
Need to take more care and bookmark them.
One thing I came across stated that anything you can do to slow fermentation down is advantageous.
Under pitching yeast, not oxygenating the wash, low temps, , there were others.
- NZChris
If something is really interesting, it pays to copy and paste or download it because stuff does disappear. I remember reading a very interesting old school distilling method, not here on HD, and the legal reasons for doing it, but years later when I wanted to find it again it had been eradicated from the net and no amount of searching trickery found it. It's not the only time it's happened to me. It's often 'out there' stuff that I suspect has been removed by moderators or curators to protect the general public from information they can't get their own heads around, find offensive, or think is dangerous, etc..
Bolverk
I remember reading that Hampden leaves the rum beer for their heavy marks for 6-8 months (I could be wrong on this it may have been 6-8 weeks).
I think that long might be a bit excessive but its definitely a good idea leaving the beer on the yeast to autolyse and get all those delicious fatty acid esters.
