Keg Build Question about for 2" Ferrule and for 6" Ferrule
planohog
Post by planohog »
Ferrule Fits Tri Clamp 2"
Thinking ahead, how do you suspend this in the keg for soldering so that there is room left to use a clamp. It looks like a clearance about .25 inch is required
attached image of 2" .
I noticed on my bolt on 2" tri clamp on pot lid (not keg) there is a lip that it rides on ( place for the gasket ) or a place for the nut underside to clamp
down with.
Did I find the correct part for soldering ?
I suspect I will have the same issue with the 6" ferrule. How to suspend at proper height for soldering.
Will the 6" fit on top and allow for me to use the built in 2" ferrule in center top ?
( went with six inch as my arms, very normal size, could not fit in 4" test hole in cardboard.)
This topic has 8 more replies
Register Login
