Green neutral spirits
Forum for the discussion of any material/synthetics.Only posts with info /or links to research info allowed . Any posts recommend the use of any material without copy's or links to show proven research will be deleted
badger6724
Post by badger6724 »
I have been doing neutral spirits for years using Shady's sugar shine recipe and this is the first time this has happened. My heads started out green and as the run progressed it eventually turned clear. I tasted my cuts and the taste is definitely off. Not necessarily bad (turpentine) but not my usual neutral either. I use a T-500 copper condenser and I disassemble it and soak the saddles in citric acid solution after about a dozen runs. I am still using the same saddles for over 150 runs which are stainless with copper at the top. Any insights on why this happened and solutions to keep it from happening again?
Re: Green neutral spirits
Maybe the wash pH was too high and reacted with the copper.
badger6724
Maybe. I do use my spring water which is rather hard. But I have been using crushed oyster shells to balance PH for years without a problem. I soak the saddles in citric acid solution but only rinse the column. I am soaking the inside of the column in solution now and it is leaking out blue/green. Good sign...maybe?
Dump the still and packing into a bucket of backset, or citric acid leave 24 hours, rinse well with fresh water.
