So i ran the first gen ujssm today, 5 gallons in my alembic on the stove, since it wasnt really enough to bother with the keg and it reminded me why I built the keg in the first place......take off speed, 3½ quarts
(last pint was 10% and oily) at 2 hours a quart plus around a 1½ hour slow warm up for a good fores cut, set up to cleaned up was about 8 hours.
I'm not doing that again, it'll be 2 fermenters from now on that I'll get 6-7 gallons of wash from each to charge the keg with. I think I should be able to strip all that and still cut today's set up to cleaned up time in half. I still have not done a stripping run in the keg to know how much time I can get it done in but, I know it will be faster than 2 quarts an hour and being out in the garage where I can just hose everything down in the driveway will be a lot quicker as well.
Right now I have 5 gallons of a hbb spin, anniversary bourbon, and 5gl corn/rye that I'm contemplating putting together in the still and stripping together then put all that with 2 gallons of my anniversary low wines i already have and running that through the thumper with mash I've got put back from the anniversary bourbon.
I just dont want to do 2 more 5g runs in the alembic. I will be glad to have it for small batch stuff but thats not what im going for right now.
Re learning things
- Corn Cracker
Re learning things
I think I'll go home and fire up my still, it might not make me feel better but, I bet it will
- ga flatwoods
Re: Re learning things
"Ain't nobody got time for that!" Lol Make enough to be worth the effort, once hot, it doesn't take that much longer to distill ten gallons of was than it does five and a lot less energy.
I am still kicking.
Ga Flatwoods
I am still kicking.
Ga Flatwoods
MooseMan
Yeah once your have a decent size boiler, going back to a little one soon reminds you that it's the same amount of work for a small volume as a big one!
I can't remember how many watts you said you put in your keg boiler CC, but I'm pretty sure stripping output will be several times what you managed on the stove!
If not, get more power!
30xs
Been a while since I’ve run mine but with 5500 watts I was around 2 gallon per hour on a strip.
- Corn Cracker
It's not a really a stripping rig, the 5gl alembic, I replaced the flakestand after it's first run years ago and made a small liebig for it. I run it on the electric stove over medium low heat sitting on a comal (flat iron skillet), it makes a nice drop doing low and slow spirit runs. . Ive not done any real stripping runs at all, I can run the alembic with a huffing steady pencil lead stream on medium hi but, thats about as close as I've come
30xs
With your setup it would seem best to ferment enough of each to get around 12 gallons of liquid from the mash. Then you could strip a keg load straight into the alembic and go straight into the spirit run. Heat up the alembic while cleaning up and putting away the stripping rig.
- Corn Cracker
That is the plan, using the alembic as a spirit/polishing still. I've only got one run on the keg set up so far. I think I'll change that today and mix and run the 2, 5 gallon mashes together, if its got too much spice from the wheat and rye I can re-run it with another batch of hbb or just corn to calm it down a little bit.
