My Sacrificial Run.
Threesixzero
My Sacrificial Run.
My Sacrificial Run.
Hello Everyone,
I finally started my journey after reading many books and reading many articles here.
I purchased a module unit from Oak Stills and received it in about 2 weeks. Put it together to get myself familiar with all the components. I then did a vinegar and water run to start the cleaning process.
The Sugar Wash.
I decided to do a simple sugar wash for my sacrificial run. I just went as simple as I could.
I heated up 4 gallons of water and then dissolved 10 lbs. of sugar in it. I added a gallon of colder water to help lower the temperature below 90F so I could pitch the DADY yeast and nutrients into the wash.
I checked my SG and it was 1.090. I allowed the wash to ferment for 7 days at 75 degrees.
After the 7 days I had a FG of only 1.060. I am not sure if I had enough or even the correct nutrients for the wash. Even with the lower alcohol content I decided to run it anyway since this was only a cleaning run.
I slowly brought the still up to temperature. I could probably have brought the wash up to temperature faster but I am of course still learning how the still runs. I am using a 220v heating element and a voltage regulator to control the heat.
My final product came out at 49% ABV and a volume of about 500-600ml.
I am working on a barley and rye recipe now and I hope to be able to run that in about 2 weeks.
Thank you everyone for all the advise and support keeping this hobby alive.
Hello Everyone,
The Sugar Wash.
- Corn Cracker
Re: My Sacrificial Run.
Thats a nice set up,
find ya some tried and true recipes and follow those, do you have a ph pen or test stips for checking and adjusting ph?
I think I'll go home and fire up my still, it might not make me feel better but, I bet it will
Threesixzero
I have a PH pen on the way. I was honestly in a rush to get a run in under my belt and I was assuming that it would not matter that much for the first run.
- Corn Cracker
understandable, and you were right, just a sac run to clean and get some experience.
greggn
The output of a sacrificial run should be poured down the drain ... not bottled.
While you may elect to keep it, to use as a cleaner, it should be labeled as such. Putting it into a commercial spirits bottle makes it too easily mistaken for something that can be consumed.
________________
Threesixzero
I agree I do have it labeled do not drink on the label. I am going to transfer it to another container. Honestly i put it in that bottle to see approx. how much yield I had compared to what my math said I should have. I do not have a graduated cylinder to measure that large of a quantity yet
greggn
Carry on.
________________
- Corn Cracker
I see it written on the back, taking precautions, I like it. You'll get along real good here with that mindset
Threesixzero
Thank you I appreciate that. The last thing I want to do it get myself or anyone else sick from anything I make.Corn Cracker wrote: ↑Mon Sep 01, 2025 4:27 pm I see it written on the back, taking precautions, I like it. You'll get along real good here with that mindset
Honestly I am still in amazement that sugar, water, and yeast can create alcohol.
I love the science behind it and can not wait till I get to the art of blending. I love the personal touch you can bring to a product
- jonnys_spirit
Sounds like you’re on your way and congrats on your ferment and sac run! I gather you suspect a pH crash which may be likely. A sock full of oyster shell grit suspended in the wash can help prevent that as well as some buffering from the start.
Cheers,
jonny
Cheers,
jonny
- Corn Cracker
It is a really good feeling watching your first run come to life. All grains are a little trickier but, thats a milestone for another day.
