Help please.. single malters
Eliza
Post by Eliza »
I am trying to make a single malt. 100L,25KG,six row malted barley. i get 9% after mashing. my problem comes with the yeast. i have m1and it nocks the ph bandy stopping fermentation at 5%.
my water is rainwater at ph 5. i have tried adding lime as a buffer but it didn't raise the ph above 3.2. I can try another yrast, bit I'd like to. het the m1 working. average temperature 28c. πŸ™ i do an open fermentation.
Bolverk
Re: Help please.. single malters
Post by Bolverk »
Lime (CaO) will work, but you're going to need a fair amount.
The pH scale is 10log. What that means is that for every full point, the alkalinity/acidity measured by a factor of 10. So if your goal is 5, 4 is 10x more acid, and 3x is 100x more. You're 2 full points away from where you need to be... you need to add more.
Pull out a few cups of the beer add a few spoon fulls of the lime, mix well and add back to the fermenter. Lightly stir taking care not to introduce a bunch of oxygen back to it. Wait 15 mins and take a new pH reading. Repeat until your pH is where you want it.
Personally, I like to use lye (sodium hydroxide, aka caustic soda) to get me into the ballpark as it is much stronger, and CaO to dial in the pH.
PalCabral
Post by PalCabral »
Eliza wrote: ↑Tue Sep 02, 2025 2:10 am I am trying to make a single malt. 100L,25KG,six row malted barley. i get 9% after mashing. my problem comes with the yeast. i have m1and it nocks the ph bandy stopping fermentation at 5%.
How do you measure the % after mashing, Eliza? Are you using gravity points, Brix? Or is the 9% something else than potential ABV?
SW_Shiner
Post by SW_Shiner »
What was the gravity reading? 9% potential seems high for that grain bill.
Eliza
Post by Eliza »
Bolverk wrote: ↑Tue Sep 02, 2025 3:24 am Lime (CaO) will work, but you're going to need a fair amount.
Ok. thanks for the tip. gives me hope this is not just my problem. have you tried chalk to buffer the acid from when the yeast start? i understand oyster shells are used too. i tried, but maybe i didn't crush small enough. it had a small effect.
when do you test and add more? at 4.5,4.0.?
Eliza
Post by Eliza »
PalCabral wrote: ↑Tue Sep 02, 2025 10:02 am
9% abv. the expected alcohol content. for distillation.
Bolverk
Post by Bolverk »
Eliza wrote: ↑Wed Sep 03, 2025 12:28 am
No chalk is just Cao with extra minerals. Oyster shells are a great passive buffer but they are not going to fix a crashed pH.
Just keep adding the lime, its not going to effect the flavor. Youre about 50% through your abv potential, id try to get to pH to at least 4.5.
Swedish Pride
Post by Swedish Pride »
go to the beach, grab a bucket of shells and add 2-4 big ones to the fermenter.
did you taste it when stalled though?
if still sweet, its stalled, is tart then its finished
how did you measure the ABV when stalled?
if you use a alcometer it's wrong, you need to take a gravity reading and calculate by comparing it to the starting gravity
Don't be a dick
It might not be a fermentation problem.
More likely a mash failure or infection.
Eliza
Post by Eliza »
Bolverk wrote: ↑Wed Sep 03, 2025 1:37 am
Ok. thanks. if it won't affect the flavour. but my system takes alot to raise the ph back to 4. maybe 300-400g. just suprised. This all happens with a 48 hour period.
Eliza
Post by Eliza »
Swedish Pride wrote: ↑Thu Sep 04, 2025 6:32 am go to the beach, grab a bucket of shells and add 2-4 big ones to the fermenter.
I use a refractometer. Your saying this is unreliable and i should the old way?
Eliza
Post by Eliza »
shadylane wrote: ↑Thu Sep 04, 2025 11:16 am
I try to keep everything clean. i step mash to 72. move that t to a plastic lautering barrel, into a sanitised fermenter. i open ferment. i know when there's an ifextion, you get this white film on the surface. i get often.
Bolverk
Post by Bolverk »
Eliza wrote: ↑Sat Sep 06, 2025 3:37 am
If its lacto like I suspect then its definitely possible... depends on the strain. Lactobacillus acidophilus is very fast producing and will crash a ferment pretty quickly. The desired lacto strain is plantarum. Its a slow producer and makes both acidic and lactic acids.
Swedish Pride
Eliza wrote: ↑Sat Sep 06, 2025 3:39 am
Could be, i don't know your tools or how derived your findings.
Always helps to give as much information as possible when asking for advice.
That way there be less guessing and you have a better chance of getting a solution.
Pictures also help alot
Don't be a dick
SW_Shiner
Post by SW_Shiner »
Eliza wrote: ↑Sat Sep 06, 2025 3:39 am I use a refractometer. Your saying this is unreliable and i should the old way?
Are you are using a correction table to account for the difference in density of ethanol?
There might be part or all of the problem.
If a refractometer calibrated to abv is used to directly measure the abv of a wash, the left over sugar will make it lie.
If used to measure sg after fermentation starts, alcohol will make the sg measurement high.
You need to take an OG measurement and do some math to use a refractometer for FG
Eliza
Post by Eliza »
shadylane wrote: ↑Sat Sep 06, 2025 3:14 pm
I have two. one for alcohol (up to 70%) and one for sugar. i will use the manual way and compare results. thx.
Now days I use a hydrometer for measuring SG during fermentation.
The first time I used a refractometer, I though the wash had stalled at 1.020ish
The wash tasted and looked like it was finished but the final gravity was high, and I was confused.
I didn't know refractometers were affected by alcohol and would read high.
I looked at my hydrometer 1.020 is on the same level as 5% potential alcohol.
Most likely your mash has finished dry and is much closer to 1.000 than 1.020
