AMA (Agristore) grain mill grind size
- adamf
Happy with the AMA (Agristore) grain mill. It's simple, easy to use, and with the modifications found here: viewtopic.php?p=7811997#p7811997, dustless and adaptable to 5 gallon buckets or blue HDPE mashing barrels.
I'm using the 2nd finest plate for grinding malted corn and malted rye. My mash, about done, is really cloudy. Do you think if I made the grind coarser, the grain particles would settle out more readily? Curious as to what y'all think.
"...and I wound up spendin the night in a corrugated conduit with a cat." Suttree, Cormac McCarthy
- dieselduo
Re: AMA (Agristore) grain mill grind size
If you want it clearer just cold crash or wait.
- adamf
Thanks It's been three weeks and it's time to run it. It should be fine but I was wondering if the particle size was larger, maybe there'd be less suspension?
greggn
I use that plate for everything (except millet which uses the finest sieve). Almost universally, my AG process is:
ferment 4 - 5 days
immediately rack into secondary
5 - 7 days to clear
distill
I heat with a 1500W electric element and I've only scorched once and that was 100% oats.
________________
- adamf
greggn, thanksgreggn wrote: ↑Sun Sep 07, 2025 3:10 pm
ferment 4 - 5 days
5 - 7 days to clear
distill
- Twisted Brick
I use a different mill but had the same problem of finished ferments still cloudy after a month. Going to a bigger screen and particle size fixed it. I still let my ferments clear for 2w which results in much cleaner washes.
- Windy City
I bring everything to flour but i now distill on the grain. Before I built this equipment I would use mashing bags and a mop squeezer/ringer and it worked quite well. I never waited for it to settle.
- adamf
Hey TwistedTwisted Brick wrote: ↑Mon Sep 08, 2025 9:23 am I use a different mill but had the same problem of finished ferments still cloudy after a month. Going to a bigger screen and particle size fixed it. I still let my ferments clear for 2w which results in much cleaner washes.
I'll try two different grinds (particle sizes) on my next mash batch and see how they clear, and how they taste white.
Thanks!
- adamf
WC, thanks.Windy City wrote: ↑Mon Sep 08, 2025 9:53 am I bring everything to flour but i now distill on the grain. Before I built this equipment I would use mashing bags and a mop squeezer/ringer and it worked quite well. I never waited for it to settle.
I plan to distill on the grain: steam stripping the slurry I strained off. I was concerned that the cloudiness could contribute to off tastes in the product. Folks seem to feel evenly that this is not an issue, or is. I'm gonna try a coarser grind next round and compare white product taste to the finer grind I'm currently posting about.
- jonnys_spirit
I’m pretty sure I use the finest screen on the agristore mill for best efficiency. Seems to clear well enough. If you’re stripping on-grain I don’t feel like it matters. I might try the next size up on the mill though in any case to see whether squeezing is any better.
-j
-j
- Windy City
Almost all commercial distillers and many of us home distillers distill on the grain.adamf wrote: ↑Mon Sep 08, 2025 11:36 amWC, thanks.Windy City wrote: ↑Mon Sep 08, 2025 9:53 am I bring everything to flour but i now distill on the grain. Before I built this equipment I would use mashing bags and a mop squeezer/ringer and it worked quite well. I never waited for it to settle.
I can say for a fact through personal experience it works and tastes phenomenal.
i have quite a few 4 year old barrels of various bourbons, ryes and whiskeys that are just knock your socks off great and all were distilled on the grain.
my rig is a self contained steam jacketed still.
- adamf
I'm hoping. I see how the level of effort (LOE in corporate speak) increases with fermenting all grain. Choosing a recipe, following it, working with the finished ferment, handling the spent grain... it's kinda like farming!Windy City wrote: ↑Tue Sep 09, 2025 9:30 am
Steam stripping the slop/slurry post ferment, went well. I did produce some intense oily, brownish, slightly metallic looking material near the end of the strips: I assume this is the notorious Bardy Grease? I've not seen this with sugar wash or apple brandy strips. I could not separate the yeast/trub from the slop.
Prepping for the final strip with liquid wash, I was able to decant off the cloudy yeasty material at the bottom of each vessel and the wash in the boiler is fairly clear. I'm running a direct fire strip. The boiler I'm using is easy to clean, in case this liquid makes a mess.
Thanks for the support.
- adamf
Thanks J!jonnys_spirit wrote: ↑Mon Sep 08, 2025 6:00 pm I’m pretty sure I use the finest screen on the agristore mill for best efficiency. Seems to clear well enough. If you’re stripping on-grain I don’t feel like it matters. I might try the next size up on the mill though in any case to see whether squeezing is any better.
An experimental attempt at squeezing yeilded nothing. I'm going to run with the result from the strip. It is what it is.
- adamf
An update: I ran low wines in a potstill/thumper. Low wines were 35%. I diluted them to 26% by adding two more gallons water for a total of 8 gallons. The thumper was charged with 2 gallons of ~8% beer/wash, reserved from the ferment. The run went very well, with easy to cut heads after removing 800ml of fore-shots. ~1.25 gallons hearts from 169-152 proof. Tails were 142-30 proof over 1.25 gallons. The heads, hearts and tails were all compressed nicely. I ran the run fairly slowly, pencil stream/broken pencil stream. Initial taste testing of the the hearts combined and proofed to 96, was beyond expectations. The product is better then I had hoped for!
I'll have to wait to see how the product tastes after airing, and then after a few weeks. I'll then be able to discern if there are any off flavors from the yeasty steamed yeast slurry that made up 2/3's of the low wines.
Steam-stripping the mash slurry using a thumper worked flawlessly. Stripping the cloudy beer/wash (I fire with propane) resulted in no scorching.
This mash was 35:60:5 malted corn, malted rye, malt. I was concerned that the greater mash proportion, of rye could possibly scorch. There was no
sign of any. When using a thumper for steaming, my heat-up time increased by at least 30-40%. Understood. The ease of steam-stripping and the higher yield is worth the time and fuel cost. Others before me have endorsed stream-stripping-- I'll add my thumbs up
Will the cloudy wash influence the taste of the product negatively? Time will tell. This first batch will be divided up and some aged in a Badmo, while the remainder consumed white. I'm sure the continued testing will be pleasant!
Thanks to all who responded to my initial question. I appreciate your knowledge and experience.
