Random Thought: Has Anyone Tried Making a Home Still with Fiberglass?
Alcohol is an inexpensive, clean and renewable fuel source.
Fiona727
Post by Fiona727 »
Fellow distilling enthusiasts, while tinkering with my home still today, a thought struck me: Could fiberglass be used to make a home distiller? Most stills we see are stainless steel, copper, or glass, but fiberglass has some standout features that might make it a good fit for home distilling. Let’s discuss.
Why fiberglass? It’s glass fiber-reinforced plastic, combining the strength of glass fibers with plastic’s flexibility and corrosion resistance. Plus, it’s budget-friendly—key for home distillers. It’s also lightweight, easier to handle than heavy copper gear.
Corrosion resistance is crucial in distilling. Alcohol, acids, and vapors in the process can eat away at metal over time, while glass is fragile. Fiberglass, though, holds up well against corrosion, potentially extending a still’s lifespan. For DIY builds, that means less worry about early equipment failure.
Feasibility-wise, main parts like the boiler or condenser housing seem doable. Fiberglass sheets/pipes are widely available online, and cutting/shaping tools are easy to find. With basic DIY skills and some tutorials, you could roll sheets into a boiler cylinder, piece together a condenser frame, and seal joints with food-grade resin to make a functional still.
But there are concerns. The big one is heat: fiberglass is heat-resistant, but how does it hold up under sustained high temperatures? Could it release harmful substances into the spirits? Then there’s sealing—joints need to be tight to prevent steam leaks, while accounting for thermal expansion/contraction. Also, while fiberglass is cheap, custom shapes might drive up costs, so we’d need to compare value with off-the-shelf stills.
I know this community has tons of experience, so I’d love your take. Has anyone tried this? Any professional insights on whether it’s viable? If it works, let’s brainstorm designs and tips—maybe we can unlock a new, fun, efficient way to distill at home. Looking forward to your thoughts!
Corn Cracker
Re: Random Thought: Has Anyone Tried Making a Home Still with Fiberglass?
Post by Corn Cracker »
My first thought is chemicals from the fiberglass resin leeching into the distilled vapors and being ingested, the 2nd is the heat expansion, a small water tight crack will open up under heat
I think I'll go home and fire up my still, it might not make me feel better but, I bet it will
Steve Broady
Post by Steve Broady »
Have you actually read the rules here? Specifically the ones against plastics, and maybe the one against the use of AI.
Without the mention of fuel production this not acceptable discussion.
I can see how to merge this discussion into an existing discussion in the fuel forum. But not clear how to create a new post for this in the fuel forum?
I'm locking this down for now, and we'll discuss in private.
NormandieStill
Post by NormandieStill »
Currently unlocked so I'll add my 2 cents. The problem with fibreglass is not the glass fibre (although the mats are not always glass) but the resin. If you're using 2 part epoxy then it's unlikely to be food safe. Making it food safe would involve very precise dosing to prevent unlinked resin from remaining. And even then, food safe does not mean that it can be safely used in a high temperature, solvent-rich environment!
I don't know what prices are like where you are but around here I can pick up a used 30L keg for less than 15€. Enough resin and matting to make a similarly sized boiler out of fibre glass would cost significantly more! For a beginner I suspect that making a mould, wrapping impregnated glass mats and applying appropriate pressure, attaching the metal hardware and removing the mould would require a greater skill set than learning to solder. Which you'll need to do anyway because I don't see anyone making a Liebig out of fibreglass!
The idea is just plain crazy, there are so many problems with the idea, even if used for fuel production.
Renhoekk
Post by Renhoekk »
No I haven’t thought about it because the would be a terrible idea
Stonecutter
Post by Stonecutter »
Why hasn’t this topic been locked and put directly into the “what not to use/do” board?
-Thomas Paine
Stonecutter wrote: ↑Tue Sep 16, 2025 9:45 am Why hasn’t this topic been locked and put directly into the “what not to use/do” board?
Because this topic is now in the fuel forum.
I’ve read this topic a few times and I can’t see anywhere that the OP is suggesting this method for Fuel production .
It is a bad idea :thumbdown:
Copperhead road
Post by Copperhead road »
Yummyrum wrote: ↑Tue Sep 16, 2025 1:07 pm I’ve read this topic a few times and I can’t see anywhere that the OP is suggesting this method for Fuel production .
That’s correct yummy, I don’t know how this topic ended up going sideways into fuel production and onto a fuel forum…..
Fiona727 was taking about an alcohol still,
Furthermore the idea is not a good one.
I haven't tried making a boiler out of fiberglass, because of boiling hot alcohol vapor and the resin in fiberglass. :lol:
Maybe it could be done, but there's better and cheaper ways.
