The Math Ain't Mathing - All Grain Starch Conversion
DoubleJ
Post by DoubleJ »
Hi gang,
It's been a while since I've posted, but do drop by ocassionally to see what's up.
I'm here again to pick the brains of those smarter than me. I'm just coming off a 2 x 50 gal bourbon mash, very frustrating, failure. My initial sweet runs came off fine, but on my first round of sour mashing, both of my fermentations completely stalled out at 1.040/1.045 (from a ~1.080 start).
It got me thinking if I really wasn't getting a good starch to sugar conversion during mash-in. And subsequently, the (potentially) unconverted starches in my mash(es) contributed to the failure. So, out of curiosity, I went to Dr. Google and asked a couple questions.
1. How much diastatic power does it take to convert 50 lbs of corn (starch) to sugar?
- The answer I got was 3500*L (degrees Lintner)
2. And, how much diastatic power does 6 row malt contain?
- The answer I got was 160*L per pound
Hmmm... So from that info, it would theoretically take 3500/160 = ~22lbs of 6 row malt to convert all the starch to sugar in 50 lbs of corn. Thinking about this further, I then asked this next question.
3. How much 6 row malt does it take to convert the starch in 50 lbs of corn into sugar?
- The answer I got was straight forward, but contradictory at the same time. It said the general rule of thumb is ~10% malt by weight, or 5 lbs.
Wait a second.... 5 lbs x 160*L = 800*L
By the above answers in 1 and 2, it would suggest I barely have 25% of the required malt to do the conversion.
Is there some sort of multiplier effect here that I don't understand? All help is appreciated.
JJ
Seek to understand...
Turbo6ta
Re: The Math Ain't Mathing - All Grain Starch Conversion
Post by Turbo6ta »
Don't mention AI here ... They don't like AI and will jump all over you like they did me about a month ago .. I had no idea how negatively they felt about AI untill I mentioned it here.
It's in there rules somewhere
DoubleJ
Post by DoubleJ »
Nothing I can do about that now, but will keep it in mind for the future.
Bolverk
Post by Bolverk »
So 50lbs of corn has zero dp.
You need at least 30 dp points per lb, 35 is a safer number.
So 50 × 35 = 1750 dp points needed.
6 row has about 160 points per lb.
1750 ÷ 160 = 10.93 lbs of 6 row needed to convert 50lbs of corn
Mashing with malt alone takes skill, the temps and pH have to be right for success. Even with 100% malt the final gravity will be 1.010ish at best.
For bourbon, my preference is aim for an OG of 1.060ish using 20% malt for character, high temp alpha and gluco for conversion.
It might be considered cheating, but it's better than getting thirsty. :wink:
Corn Cracker
Post by Corn Cracker »
from my understanding , 2 row has more dp than 6 row so, it would take less 2 row malt to do the same conversion as 6 row. if your gonna use 6, maybe try some enzymes to help it along if your coming up short on gravity readings
I think I'll go home and fire up my still, it might not make me feel better but, I bet it will
Twisted Brick
Post by Twisted Brick »
Corn Cracker wrote: ↑Sun Sep 28, 2025 3:08 am from my understanding , 2 row has more dp than 6 row so, it would take less 2 row malt to do the same conversion as 6 row. if your gonna use 6, maybe try some enzymes to help it along if your coming up short on gravity readings
6-row has always had a higher DP (160) than 2-row (140). Best you read more and check your data before posting.
Corn Cracker
your right, just did, i reckon my meory failed me
GrumbleStill
Post by GrumbleStill »
If sweet mash worked fine, sour mash failed, and assuming grain bill and mash protocol was the same, my guess would be too much backset has messed up your mash chemistry.
Homebrewer11777
Post by Homebrewer11777 »
Something not adding up. 50 gallon mash with 50 pounds corn to get a 1.080 starting gravity? I don't believe it.
DoubleJ
Post by DoubleJ »
GrumbleStill wrote: ↑Sun Sep 28, 2025 4:02 am If sweet mash worked fine, sour mash failed, and assuming grain bill and mash protocol was the same, my guess would be too much backset has messed up your mash chemistry.
I was wondering about this too. I used about 12 gallons of backset. In the 55 gal barrel I used, I gave up roughly 12 gallons of it due to the grain displacement, leaving me with roughly 43 gallons of liquid to add. So 12/43 = 27.9% was used.
DoubleJ
Post by DoubleJ »
shadylane wrote: ↑Sat Sep 27, 2025 6:12 pm Mashing with malt alone takes skill, the temps and pH have to be right for success. Even with 100% malt the final gravity will be 1.010ish at best.
On the initial sweet runs, both of them finished at 1.010.
On the sour runs, I added my malts in in three steps, about 1/3 each addition. The first addition went in around 158*. About 15 - 20 minutes later, I made the second addition, and another 15 - 20 minutes later I made the final addition.
My starting gravities were around 5.3. I didn't test again until I realized the failure (about 8 days later - I was on vacation for 6 days). It tested at 4.7/4.8.
DoubleJ
Post by DoubleJ »
Bolverk wrote: ↑Sat Sep 27, 2025 5:08 pm So 50lbs of corn has zero dp.
These numbers make more sense. Thank you.
DoubleJ
Post by DoubleJ »
Homebrewer11777 wrote: ↑Sun Sep 28, 2025 4:17 am Something not adding up. 50 gallon mash with 50 pounds corn to get a 1.080 starting gravity? I don't believe it.
I bumped it a bit with sugar and honey.
NormandieStill
Post by NormandieStill »
DoubleJ wrote: ↑Sun Sep 28, 2025 7:37 am On the sour runs, I added my malts in in three steps, about 1/3 each addition. The first addition went in around 158*. About 15 - 20 minutes later, I made the second addition, and another 15 - 20 minutes later I made the final addition.
Why did you add the malt in stages? What was the temperature when you made the second and third additions? How long did you mash for? Did you starch test at any point?
DoubleJ wrote: ↑Sun Sep 28, 2025 7:39 am
That's the sort of information that would have been good to include in the original post. Did you also do this for the sweet mashes? What was the SG before the additions?
DoubleJ wrote: ↑Sun Sep 28, 2025 7:28 am
I've not done any sour mashing. Just not had the time to chain ferments like that. But everything I've read makes me think that at over 1/4 backset you might be pushing the acidity a little too far.
Were you following a recipe? If not, what were the sources you used when inventing this recipe? There's more than one deviation from what I would consider to be "standard practice" here which adds a lot of variables to account for.
Copperhead road
Post by Copperhead road »
NormandieStill wrote: ↑Sun Sep 28, 2025 9:57 pm
I agree Norm,
If you use 15% backsets you will never incur any problems. I have had them go for years that way.
DoubleJ
Post by DoubleJ »
I knew at 158* I was a touch on the hot side for a strike temp. I also knew I'd get some conversion before the enzymes were denatured, which I did because the starched up corn loosened up considerably. I didn't take temp readings for the next two additions, but I knew I'd get a few degrees of cooling from the first addition, and that, coupled with the time lag until the second addition, would've put me in the "safe" zone as far as the enzymes were concerned. The third addition was more of an experiment. I wanted to see how the corn "behaved" after the first two additions.
As far as mashing goes, my corn was ground up to a very coarse powder. It was placed in the bottom of the barrel and 24 gallons of boiling water was added. That was left to sit for about a 2 hours. The water was thoroughly mixed in to avoid clumping at the outset, and then mixed a few more times during the wait period. I didn't really fully time the total malt time, but it was around 2 hours from the first addition.
Yes, I did the same for the sweet mashes, however on the sweet mash, I added 3kg of honey, whereas on the sour mash I added 6 kg of honey. My SG before the additions was around 1.045, I believe.
My pH readings shown above wouldn't suggest an acidity problem, but that doesn't mean other parts of the chemistry were not affected.
I wouldn't consider the honey and sugar additions as a deviation as they were added well after malts. However, my three stage process may arguably be considered a deviation. I have read here on the forum of others adding their malts in two stages, with the first addition being done as a sacrificial lamb at a higher temp.
Starch testing - full disclosure here. Iodine testing (one drop on a full tablespoon) has been the bane of my distilling experience. My results have always been inconclusive. Only a couple times have I had the mash/wash stay purpley/black, so I knew for sure starch was still present. Never have I had a sample clear up entirely. Most have been somewhere in-between, albeit on the lighter side. And since I never had anyone directly to consult with, I'd always had to guess.
DoubleJ
Post by DoubleJ »
Copperhead road wrote: ↑Sun Sep 28, 2025 10:34 pm
I've done plenty Uncle Jesse in the past with 20% backsets, and never had any issues. That said, this was the first time on a multi-grain grain bill (3 grains) where I've backsetted this high.
With all the input I've received here, these are my takeaways.
1. Definitely backset with a lesser amount, maybe 20% max, but probably limited to 15% as suggested above.
2. Malt addition(s) will definitely be limited to two (if I decide to do a higher temp sacrificial addition), otherwise one single addition at a target strike temp of 152* - 155*.
What I'm thinking happened here with my failure(s) is I had an incomplete starch conversion coupled with too much backset. Both of these combined somehow messed up the chemistry (beyond what I can test for) and halted fermentation prematurely.
JJ
jonnys_spirit
Post by jonnys_spirit »
Are you opposed to using liquid enzymes primarily for conversion in addition to malts primarily for flavor? They work very well.
Cheers,
jonny
NormandieStill
DoubleJ wrote: ↑Mon Sep 29, 2025 12:59 pm With all the input I've received here, these are my takeaways.
It's possible that the initial higher temp saccharification step produced lots of unfermentable sugars, and that the enzymes at the last addition didn't have time to finish the job of cutting them up!
DoubleJ wrote: ↑Mon Sep 29, 2025 12:41 pm I wouldn't consider the honey and sugar additions as a deviation as they were added well after malts. However, my three stage process may arguably be considered a deviation. I have read here on the forum of others adding their malts in two stages, with the first addition being done as a sacrificial lamb at a higher temp.
HBB uses the addition of the honey malt with the corn during gelling as a "sacrificial malt" to thin the corn out while it gels. It only represents a small proportion of the mash bill though. If you can get your hands on them, high-temp enzymes make dealing with corn a lot easier. That way you can focus your efforts onto getting full conversion with your malts. When I'm not using YLAY for bourbon mashes, I tend to chuck in some alpha and gluco amylase (at the appropriate moments) to help get good conversion without having the get the temperatures exactly where I need them.
DoubleJ
Post by DoubleJ »
jonnys_spirit wrote: ↑Mon Sep 29, 2025 1:12 pm Are you opposed to using liquid enzymes primarily for conversion in addition to malts primarily for flavor? They work very well.
Cheers,
jonny
Not at all actually. This was one of the things I am/was considering.
jonnys_spirit
Try Sebstar HTL for the high temp enzyme during gelatinization. It turns the thick corn mush into a much thinner slurry very quickly and SebAmyl GL for the 150*F addition to convert starches. It doesn’t take much.
Cheers,
Jonny
DoubleJ
Post by DoubleJ »
NormandieStill wrote: ↑Mon Sep 29, 2025 1:18 pm
I suppose this could be possible, but being only a few degrees hotter than an ideal strike temp, one would think this situation would be minimized. Had I been, say, 15 - 20 degrees hotter, than this might be a more sound argument. But like I said, anything is possible. And unless this can be scientifically proven, it can't be discounted.
Yes, I can get high temp / alpha enzymes. Don't think I've seen high temp gluco enzymes though. Regardless, I am not opposed to using them.
Full disclosure - I do not know what YLAY is. If someone can enlighten me, by all means, please and thanks.
Further to all of this, out of curiosity I dug a little deeper into the barley malt I was using. It's the 6 row malt from CMC (Canadian Malt Co.) I reached out to them to ask what the diastatic power of that malt is. It is 157. So again, me being the thinking sorta guy that I am, starting wondering if I actually had enough Diastatic Power between my two malts (barely and rye) to begin with (based on some of the maths listed above). My grain bill was the standard Jack Daniels - 80% corn, 12% barely malt, and 8% rye. My barley malt now confirmed at 157 DP, and my rye malt is, presumably, around 100 DP. Just wondering if I was a bit short to begin with, and then coupled with my multi stage malt additions, just further exacerbated the problem(s).
While on the CMC website, I noticed they have a "Bourbon Malt". The data sheet states its Diastatic Power is >250. I am going to confirm this with them, but in the meantime, does anyone here have any experience with this malt?
JJ
DoubleJ
Post by DoubleJ »
jonnys_spirit wrote: ↑Mon Sep 29, 2025 5:35 pm Try Sebstar HTL for the high temp enzyme during gelatinization. It turns the thick corn mush into a much thinner slurry very quickly and SebAmyl GL for the 150*F addition to convert starches. It doesn’t take much.
Cheers,
Jonny
Noted - Thanks!
Copperhead road
DoubleJ wrote: ↑Mon Sep 29, 2025 5:44 pm
Yellow Label Angel Yeast
SW_Shiner
Post by SW_Shiner »
Yellow Label Angel Yeast. It is an enzyme and yeast combination that makes all grain brewing much easier. Sprinkle on top of grain and water and wait for it to finish fermenting, no mashing required. There is a good thread about it all here
Homebrewer11777
I agree, you were not anywhere close to denaturing the enzymes to the point that your fermentation would stall out at 1.040-1.045. Especially since your sweet mash did fine. The more likely culprit is the pH from the backset. Either it prevented the mash from actually converting to sugar or it you ended up with mash pH that was inhospitable for the yeast.
I am thinking that if using backset you should probably be checking mash pH with a pH meter. Backset is hardly a standard ingredient...Reading the ADI forum I see several mentions about keeping lacto out of fermentation so your backset is not too acidic. If you are using backset from a batch that got a full lacto infection (lol that would be most of mine) it may be a lot more acidic than what commercial guys are using. I believe mash pH during starch conversion should be somewhere around 5.2-5.8 while while wash pH before pitching yeast should be 4.8 to 5.0. Get a meter and use it. The cheap ones accurate to 0.1 pH units should be fine.
DoubleJ
Post by DoubleJ »
Homebrewer11777 wrote: ↑Tue Sep 30, 2025 4:57 am I am thinking that if using backset you should probably be checking mash pH with a pH meter. Backset is hardly a standard ingredient...Reading the ADI forum I see several mentions about keeping lacto out of fermentation so your backset is not too acidic. If you are using backset from a batch that got a full lacto infection (lol that would be most of mine) it may be a lot more acidic than what commercial guys are using. I believe mash pH during starch conversion should be somewhere around 5.2-5.8 while while wash pH before pitching yeast should be 4.8 to 5.0. Get a meter and use it. The cheap ones accurate to 0.1 pH units should be fine.
I have a pH meter, and use it all the time. It wasn't cheap either. I think I paid about $70 for it.
I found the pH strips unreliable and sometimes undecipherable as the colours on the strip rarely matched the colours on the scale.
Homebrewer11777
OK so what was the pH of the sour mash when you pitched the yeast?
Also what is the pH of your backset?
DoubleJ
Post by DoubleJ »
My starting pH's were around 5.3. I didn't test again until I realized the failure (about 8 days later - I was on vacation for 6 days). It tested at 4.7/4.8.
I didn't test the backset.
