Using nylon mesh bags in vapor path
PalCabral
Post by PalCabral »
Hiya distillers.
For my upcoming spirit run of apple pomace wash I was thinking of chopping up apples to hang in a brew bag at the top of the boiler. I have nylon mesh brew bags meant to be used for fermentation that I can tie to the mouth of the boiler.
However, I am uncertain if nylon is a safe material to have in the vapor path. Thoughts and suggestions much appreciated.
Edit: I am pretty cerain nylon is not appropriate. What would be, is a better question? Cotton?
Re: Using nylon mesh bags in vapor path
I believe this is covered in The Rules By Which We Live at the bottom of this page. You can do whatever you want in your shed, you are drinking it.
PalCabral
Post by PalCabral »
NZChris wrote: ↑Wed Oct 01, 2025 10:58 pm I believe this is covered in The Rules By Which We Live at the bottom of this page. You can do whatever you want in your shed, you are drinking it.
My health is important to me and so are the ones of those I offer my homemade to. The rules will be followed, no doubt about that.
No to nylon . Yes to Cotton
Steve Broady
Post by Steve Broady »
You can also buy stainless steel mesh in various sizes, which might work to do the job you’re considering.
I’m using a mix of 1.5” and 2” triclamp, and recently found a great deal on a used 3” sight glass and plate with holes in it. I’ll be using them to add an infusion chamber to the top of a still, packing the sight glass with whatever I want to use and the filter plate as support. You might want to look into something similar, if your still design allows it.
Homebrewer11777
Post by Homebrewer11777 »
I use a PTFE gasket with a stainless screen that I got from Amazon (Dernord) in my site glass to hold copper pipe cuts.
DERNORD 3" PTFE (Teflon) Sanitary Gasket w/Stainless Screen - Tri Clamp Clover (10 Mesh)
jonnys_spirit
Post by jonnys_spirit »
This along with some 20 mesh stainless cloth is what I’m shooting to use for a false bottom to cook/infuse some pomace here soon.
It’ll be a little fiddly to get through a number of strips but expect it to work well and keep the fruit well away from the heating element.
Cheers,
Jonny
Tammuz
Post by Tammuz »
Look for stainless steel canister they use to smoke nuts in. They fit a 3 inch column just right. I bought a 4" tea bob off Ali to hang copper filing as it leaves the boiler.
Igitur qui desiderat pacem, praeparet bellum or party till the cows come home!
zach
Post by zach »
I have one of these stainless baskets for mashing - brew in a basket . This might work if it fits in your boiler.
PalCabral
Post by PalCabral »
Thanks guys for all the tips.
