Aging containers question
- Tammuz
viewtopic.php?t=93661
This is a continuation of the above post, but for a different reason altogether.
About a year and a half ago I purchased a used barrel from Heavenly Hills . I broke it down and it's been sitting up on my flat roof in the tropics. I was planning on using 30 L beer keg to age my rum in my whiskey. I was planning on putting an air fitting on the kegs so I could pressurize and pull vacuum. My thinking at the time was to cut out the angel share..The more I read the more it seems better to use a wooden barrel for the aging.
For some reason there's not much of a price difference between a new 50 L and a 200 L barrel, all of American White oak. The people selling these cannot tell me how long the wood has been aged outdoors. I can also get 200 L used barrels from Jim beam for about 150 bucks. which is the same price as a new 50 or 200 L barrel
So my question is for those who have aged in wooden barrels. Would I get a better product using a 50 L barrel which I could probably fill in a month or put it directly into 100 or 200 L barrel and have that extra airspace and possible more angel share loss.
Or when my original idea be better of aging in 30 and 60 L beer kegs where it would give me the option of pressurizing and pulling vacuum and also be able to pull the wood when I feel it's needed. I see a good few people that are satisfied aging their product in one gallon containers with wood. That makes me wonder...
Igitur qui desiderat pacem, praeparet bellum or party till the cows come home!
Powder Monkey
Re: Aging containers question
I can’t give you an answer which is “better” but have a few points. I would buy the biggest barrel you can reasonably fill with product with consideration for time and $$ invested. Price is similar but consider shipping as that can vary significantly between a 50L UPS package and something requiring freight/oversized. New vs used would be more consideration of the product you want to make vs the price.
There’s plenty of opinions that more oxygenation (air space) accelerates/“subjectively improves” flavors but that is at the expense of the angels share. Think short filled barrels or single barrel picks from leaky barrels. Angel share may be more or less significant to you depending on your temp/humidity.
You could buy a larger barrel and continue to fill it and make it like an infinity barrel, but buying a larger barrel only to fill it half way wouldn’t be my preferred plan.
decoy
I destroyed a perfectly good new 50L Oak barrel by not having it full.
Wood barrels seem to impart nicer richer flavours and body to a spirit far better then staves in a Jar, they work by varying wood permiation
by the spirit caused by surrounding external enviroment, dissolving the timbers natural oils and sugars and leeching them back into the barrel contents.
It is believed the timber also acts as a permiable membrane releasing higher volotiles out of the barrel reducing harshness, the anvels share.
Barrels are Intended to transport and or store liquids for extended times, having a stationary barrel half full perticularly in dry regions will result in drying and over time rot in the top half of the barrel, the staves shrinking braking the air seal causing mold and rot as well as increased loss to angels share.
I have seen someone release a hybrid Stainless/wood lid spirit aging barrel, but I have not tried them, sounds interesting though.
SW_Shiner
Thats a Bad Motivator Bain Marie Barrel. Been around for a while, and are very popular here.decoy wrote: ↑Sun Oct 12, 2025 9:22 am I destroyed a perfectly good new 50L Oak barrel by not having it full.
- Copperhead road
How long did you have it sitting half full ?decoy wrote: ↑Sun Oct 12, 2025 9:22 am I destroyed a perfectly good new 50L Oak barrel by not having it full.
How bad is it leaking when you rolled it over…
Also how do you know there is mould on the inside ??
decoy
so this was the barrel new, I had it almost full, over 3/4 full, I left it age in garage on concrete under pallet racking about 1.5 years maybe a bit more.Copperhead road wrote: ↑Sun Oct 12, 2025 3:09 pm How long did you have it sitting half full ?
Over time I have sampled its progress a few times from its tap, it was excellent, I did not see any leakage etc.
One day I proceeded to crack it for a parrty, it was watery and tasted not good.
I moved the barrel and noticed top staves joints had dried and parted.
when I moved it out from under racking it started falling apart and was 1/2 or less full.
After getting it out in the back yard it fell apart.
I still have the staves, used them as a ramp for the chicken coupe etc
in the last pic you can see the rotting in a few of the staves, these where on top.
the inside sides where slimy when it fell apart
A couple of them where bad and ended up in the fire.
purchased from Roll Out The Barrels , Brisveagas
- jonnys_spirit
Badmo's are quality barrels and easier to keep full.
Any barrel needs to stay charged and if not full, rotated to keep the staves swollen. If emptied, an acidulated wine strength sugar wash or similar will work for longer term storage/maintenance. pH of 3.2'ish is similar to a white wine (12-14%abv) and will keep bacterial infection at an arms length - and you can eventually distill it if you like but 14% may be considered a bit high for distilling depending on how it got to that abv. Wine can be a good maintenance fill if you feel that you may enjoy it's contribution to say a single malt or a bourbon fill down the road. Wine kit, neutral bump to 19%abv, and some sugar for a port style fill and you can also drink the wine.. I have a badmo filled with a bastard port that's several years old that I will use as a finishing barrel for an upcoming bourbon.
A neutral barrel can be augmented with utilizing charred staves being cycled through if desired or kept more "neutral" for less oak influence..
Cheers,
jonny
Cheers,
jonny
Homebrewer11777
Super happy with my Badmos. I have 7 now including one of the new 19L barrels. Up to 15 months in the barrels so far and have been trying to keep my hands off them. Sampled the oldest at 12 months and was really happy already.
I've been weighing the barrels every 3 months or so to track angels share and coming up with about 0.15% weight loss per month in the 6.4 liter barrels (range 0.11% to 0.19% per month) so about 2% per year which to me sounds quite reasonable and comparable to what could be expected for full sized barrels.
NormandieStill
There's another consideration with barrels (and Badmo's) versus staves in glass. A barrel has no (or almost no) end grain exposed to the spirit. Depending on the size and shape of your container, a stave could be up to 1/4 end grain by surface area. My own little experiment while not covering flavour did show a significant difference in extraction between two samples, one with one stave, and the other with the same surface area in three smaller staves. The one with three staves (again... exactly the same surface area exposed to the liquid) showed much more rapid extraction.
I would expect that higher levels of end grain would result in more wood flavours going into the spirit than just side grain. Since there's next to no end grain in a barrel, extraction will take longer, so the woody flavour will be less for the same amount of contact.
I finally have a 50L keg which I plan to get into service this year which should mean that I can finally produce enough spirit to repeat this test with spirit and taste test it.
decoy
I am certain it was one of our members that came up with this idea about 15 years ago.
Homebrewer11777
I talked to a craft distiller in Virginia who went at length to describe his disappointment with small barrels. He'd been sold on the idea that by packaging his product in 5 and 10 gallon barrels it would be short cut to having well aged brown spirits to sell. Instead the product just didn't have the aged character he was looking for and the cost was incredible on a per gallon basis.
Getting more oak in faster is shortcut I use on my home sipping product but I suspect proper ageing is a combination of slow oak extraction combined with chemical reactions between the alcohol, congeners, oxygen and compounds extracted from the oak.
- PalCabral
I guess being a "craft distiller" doesn't naturally make you a "good distiller" and that in turn could very well make you become an "ex distiller" very quickly. He could have saved himself a lot of disappointment and money by becoming a member of this forum and asked around first.Homebrewer11777 wrote: ↑Wed Oct 15, 2025 4:20 am I talked to a craft distiller in Virginia who went at length to describe his disappointment with small barrels. He'd been sold on the idea that by packaging his product in 5 and 10 gallon barrels it would be short cut to having well aged brown spirits to sell. Instead the product just didn't have the aged character he was looking for and the cost was incredible on a per gallon basis.
Homebrewer11777
I suspect being a "good distiller" is also no guarantee of avoiding becoming an "ex distiller". Assuming we are now talking about pros and not home distillers, he/she is running a business and keeping it going relies on good business planning and execution. Quality is an important part of execution but so is management of cash flow. And quality doesn't necessarily mean making the best product possible at any cost...It may well mean hitting a target product profile reliably while controlling costs through use of commercially reasonable ingredients and processes.PalCabral wrote: ↑Wed Oct 15, 2025 8:28 amI guess being a "craft distiller" doesn't naturally make you a "good distiller" and that in turn could very well make you become an "ex distiller" very quickly. He could have saved himself a lot of disappointment and money by becoming a member of this forum and asked around first.Homebrewer11777 wrote: ↑Wed Oct 15, 2025 4:20 am I talked to a craft distiller in Virginia who went at length to describe his disappointment with small barrels. He'd been sold on the idea that by packaging his product in 5 and 10 gallon barrels it would be short cut to having well aged brown spirits to sell. Instead the product just didn't have the aged character he was looking for and the cost was incredible on a per gallon basis.
- Copperhead road
It would be a lot harder for a commercial Distiller who is making Brown spirits such as whiskey due to the time frame it takes to age properly on oak. Not sure how they would cover costs and overheads until they have a finished product ready to sell, I think a small craft distiller would go broke unless they were making some sort of white spirit they could sell immediately.?
Whereas a gin distiller could start selling spirits straight away.
Homebrewer11777
We must have gotten pretty far off the OPs question by now but yes...it seems most emerging distillers have to start with neutrals that they can flavor and Gin while they sit around waiting for the brown stuff to get some age.
I am a big fan of the Badmo's and think they overcome a many of the challenges of the hobby sized barrels that are out there such as decoy showed above, along with too much oak too fast and too much Angel's share. I'd been looking at going to a 5 or maybe 10 gallon Gibbs when the 5 gallon Badmo came out and am happy to have given it a try.
- NZChris
Making any alcoholic beverage that requires long aging when you first start is a common mistake. My first large batch of wine was a red that needed long aging, so I had nothing of quality to drink until the next seasons white grapes were fermented.Homebrewer11777 wrote: ↑Wed Oct 15, 2025 1:31 pm We must have gotten pretty far off the OPs question by now but yes...it seems most emerging distillers have to start with neutrals that they can flavor and Gin while they sit around waiting for the brown stuff to get some age.
Many newbies want to start by making rum, something that really needs years of aging in tropical temperatures and should be made after putting down any number of products that can be enjoyed young or white long before their first rum matures.
So, yes, making gin and Panty Dropper type recipes is a good shortcut if you are new, have an an empty drinks cabinet, and don't want to scoff your first whiskey several years before it's aged enough for you to feel proud to share it with your friends.
- PalCabral
Narrow cuts to start with, when you’re learning, is a good way to go when you’re green. My first Bourbon is coming up to 6 months and the way narrow cut jar is tempting. But I will give it 3 more months before I make a first bottle. I know it will get better if I wait so I will.
