Ultrasonic Cleaner - are anyone using them?
PalCabral
Post by PalCabral »
There was a time when a lot of people seemed to have lost their knickers over fast aging liquor using Ultrasonic Cleaners. Many many long forum threads where some famous names swore by them, some testifying to great results.
I am a bit curious what happened. Today, I dont see any posts mentioning this method.
Are anyone of our distinguished members on the forum actually using these jewelry cleaners today, to improve flavor of their new made liquor?
Bolverk
Re: Ultrasonic Cleaner - are anyone using them?
Post by Bolverk »
Ive been looking at them for a while trying come up with a better way than using the the bath type. Something with a probe that is a more continuous process.... still trying to find the right solution
Not sure if this helps , but my Dad was ( still is ) a watchmaker . He had an ultrasonic cleaner . It always fascinated me as a kid . It had a 40kHz transducer . It was driven by EL34 valves . There was a big knob on the front . The modulation knob . The modulation frequency was around 5 Hz . You could stick your finger in the tank . With no modulation , you couldn’t feel anything . As you turned up the modulation , you could feel it buzzing the shit out of your finger .You could also see standing waves in the liquid .
Tammuz
Post by Tammuz »
They change the flavor but they don't age it.
Igitur qui desiderat pacem, praeparet bellum or party till the cows come home!
Odin and I were experimenting with US cleaners at about the same time with similar results. Those threads are worth reading. It kickstarts flavor and color to give you an idea of later results and may shorten the aging process but it is not a substitute for aging.
NormandieStill
Post by NormandieStill »
I seem to recall Odin saying that an ultrasonic cleaner took about 2 weeks off the minimum ageing time for gin. He reckoned that the flavour of a day old gin that had been run through the US bath matched that of the same gin recipe 2 weeks after distillation.
decoy
Post by decoy »
I was around @ the time of using ultrasonic cleaners to age, I do own an ultrasonic cleaner however I have not bothered using it to age.
In my opinion it will not age!
Ultrasonic cleaners basically vibrate the crap out of stuff on and below the surface.
Ultrasonics will vibrate the timbers fiberous membranes and the spirits causing the spirits to penetrate and move around the timber faster an possibly deeper.
At the same time it will cause the oils, tannins, raw sugars and caramelised sugers within the timber to dislodge and dissolve in the spirits and permiate out faster causing the spirit to adopt that timbers colours and flavours faster.
As a possible debatable negative perhaps it will leach out more then is wanted or even components not wanted.
Other techniques. can be implemented to achieve the above by using timber shavings or sawdust, Oak staves with cross cuts every 5-10mm to expose endgrain.
The processes of aging overlooked: to use garlic as an example to highlite a known reaction with alcohol but not otherwise related..
Aged Garlic Extract (AGE): The process of making Aged Garlic Extract involves a long soaking period in alcohol, which converts the sharp, odorous compounds into more stable, less irritating sulfur compounds.
Your final collected full flavoured spirit contains many types ofHigh volatiles in low concentrations as well as oils and acids, the timbers used in barrelmaking, oak in this case, also contain many types of sugars, oils, tannins and other compunds.
How these compounds react with each other over time as well as bactiria that may be formed and or destroyed is a very contravercial debate.
Their are many shortcuts in life, are they better?
In this hobby one thing is certain, you can't replace time.
airhill
Post by airhill »
Ultrasonic devices are useful tools in this hobby, I still have my 3l and use it when required.
Do I believe ultrasonics will speed up the drinkability of product, yes. :)
In the universe there are no absolutes; only degrees of uncertainty.
At the same time commercial distilleries were experimenting with base music in their aging room adding vibration to their process. When I was experimenting with US, I read a lot of articles on different methods of aging and the different experiments that were going on.
Stonecutter
Post by Stonecutter »
https://blackenedwhiskey.com/
What they won’t think of next. I can see some practical uses like the ones you’ve explained above Bushman but it does feel awful gimmicky coming from big distilleries.
-Thomas Paine
decoy wrote: ↑Sun Oct 12, 2025 1:50 pm one thing is certain, you can't replace time
100% :thumbup:
Maybe these other methods should be refered to as artificially maturing rather than ageing.
Age hasnt played a part in many cases.
Age needs time.
Any action that moves the saturated layer away from the wood will increase the rate of extraction of the solubles in the wood. Rocking boat, boot of your car, you shaking the container, convection currents created by a heating element, vibration from any source, including sitting the jar on your speakers, (try sitting your moonshine jars on speakers playing Deliverance on an endless loop).
Extraction of compounds from the wood is only the start of aging, as those compounds take time to react with the VOCs from the distillate, then react with each other, ad infinitum, until you interfere with the process by bottling it or drinking it.
airhill
Post by airhill »
Unfortunately discussions on aging are worse than the discussions on copper. I am not a potstiller (well not very often) so exactly how long are you supposed to age something?'
The premise that chemical reactions cannot be sped up is imho ridiculous. :)
BTW if you think that ultrasonic effect is the same as subsonic effect I would suggest you are incorrect. (not that I don't think that low hz does not have an effect) :)
decoy
Post by decoy »
It seems to be a trend that when you first start into distilling you want everything fast, you want it to age get flavour, be perfect most trying to equal a retail product, so you can drink and show friends.
12 months down the track once you realise how quickly you can make product and you start getting a bit of a stock pile you tend to settle and experiment with what next.
The equipment that I put together for fast aging experiments hasn't been used for years.
MooseMan
Post by MooseMan »
I thought about doing a few experiments, but by the time I'd decided to have a go, I had a half decent brown spirit from just shaking and uncorking Demi's now and then, over a few months, so I haven't bothered to think about it since.
PalCabral
Post by PalCabral »
NZChris wrote: ↑Mon Oct 13, 2025 9:43 pm Any action that moves the saturated layer away from the wood will increase the rate of extraction of the solubles in the wood. Rocking boat, boot of your car, you shaking the container, convection currents created by a heating element, vibration from any source, including sitting the jar on your speakers, (try sitting your moonshine jars on speakers playing Deliverance on an endless loop).
airhill wrote: ↑Mon Oct 13, 2025 10:42 pm Unfortunately discussions on aging are worse than the discussions on copper. I am not a potstiller (well not very often) so exactly how long are you supposed to age something?'
I admit I found the threads about Ultrasonic a bit confusing because of these two reasons. It's a mix of methods being discussed.
One segment of the posters were talking about the effects of vibrations on the wood, similar to how you describe it, Chris. But when I read Odin's and some of the other earlier posts it was mainly to improve the flavors of raw newmake, without any oak involved. This is what I believe you are referring to, Airhill? The latter is not aging, I totally agree, flavor maturation is more correct, I think. The former, is not aging either, it speeds up the effect that the wood can have on flavoring and cleaning the spirit.
Two quite different things.
Even in a clear liquor, anything causing increased movement means more molecules bumping into each other speeding up the rate of reactions, hardly worth the bother in something like gin unless your gin habit has you practically sucking it out of the spout as fast as you can make it. A few degrees higher temperature will do the same, which is why rum ages faster in the tropics than whisky does in Scotland.
NZChris wrote: ↑Tue Oct 14, 2025 1:05 am, hardly worth the bother in something like gin unless your gin habit has you practically sucking it out of the spout as fast as you can make it.
Christ Chris , I nearly spat my spout sucked Gin reading that :ebiggrin:
MooseMan
Post by MooseMan »
I've taken to leaving at least one Demi of each of my aging products (Much to the wife's despair) in my conservatory at the back of the house, full sun all day when it's shining, and the coldest part of the house at night, the hot/cold cycles definitely speed up the rate at which the liquid goes in and out of the wood. (It also means they are on view and more regularly picked up for a shake and sniff!)
The ones in there are blatantly different to the ones in the garage, even after just weeks.
PalCabral
Post by PalCabral »
MooseMan wrote: ↑Tue Oct 14, 2025 2:22 am I've taken to leaving at least one Demi of each of my aging products (Much to the wife's despair) in my conservatory at the back of the house, full sun all day when it's shining, and the coldest part of the house at night, the hot/cold cycles definitely speed up the rate at which the liquid goes in and out of the wood. (It also means they are on view and more regularly picked up for a shake and sniff!)
You should sell your idea as Ultrasonic Conservatory, Moose. Interior home distiller decorator. :D
MooseMan
Post by MooseMan »
PalCabral wrote: ↑Tue Oct 14, 2025 6:55 am
Well, I'm glad you find it funny at least mate, cos Mrs Moose is on me over it on a weekly basis.
I'm digging my heels in for now, until she withdraws conjugal rights, then the Demi's all go back in the garage! :lol: :lol:
airhill
Post by airhill »
For those gin makers: https://www.theginguide.com/gin-blog/ul ... maceration
For those who think that ultrasonics is just shaking the shit out of oak, this is part of the preamble from a study on aging if rice wine.
"In an ultrasonic wave process, high temperature and high pressure can be generated from circulated ultrasonic waves, causing chemical polymers to be broken into numerous mist particles (subparticles) and then recombined. In a review of sonoelectroanalysis, Saterlay and Compton (2000) concluded that ultrasonic equipment, working in the range of 20–100 kHz, is relatively inexpensive, readily available and is an enabling technology for electroanalysis. Lindley and Mason (1987) reported the types of ultrasound which are used in chemistry for effecting chemical reactivity, which were broadly divided in power between 20 and 100 kHz. They concluded that chemists are interested in ultrasound power because it provides a form of energy for the modification of chemical reactivity which is different from those normally used, such as heat, light and pressure."
The study on aging of rice wine I have not read the whole paper I only included it because it gives a slightly better understanding of the effects of ultrasonics, especially the last line. :)
I would point out that there are a lot of scientific studies on this and easy to find.
I do not discount other methods of making product more drinkable in a reduced timeline (even the most conservatives accept the oaking without the need for a barrel).
HeyBroChuckNorris
Post by HeyBroChuckNorris »
Not ultrasonic, but a (now closed) distiller in Los Angeles (Lost Spirits Distillery) claimed to have done spectro-analysis on different ages of the same rum, looking for exactly what differences there were. He then claims to have devised a way to replicate that with a contraption he built (looks like 1950s sci-fi) that uses "high-intensity light" (UV maybe?). Seems super gimicky, but I can't say I'm not curious about the final 6 day result.
https://www.smithsonianmag.com/travel/m ... 180971630/
airhill
Post by airhill »
The fact that high intensity light will speed up chemical reactions is correct, unfortunately the rest sounded like a publicity gimmick. :)
However ask yourself why you have to age certain spirits for a lengthy period of time? My answer is the newly produced spirits are initially effing awful, the results of antiquated production methods,poor cuts and rampant commercialism.
This may upset some but I feel in a few years it will be possible to produce something almost indistinguishable from a 25 year old scotch within a very short period of time. You start with clean ethanol and just have a machine mix in the appropriate esters etc. ie you are duplicating the chemical composition of a finished aged product cutting out everything else. I would note however the possibility of doing it and the actuality of doing it will be another thing, for obvious reasons.
Sorry I tend to go somewhat off topic after a few :)
decoy
Post by decoy »
airhill wrote: ↑Wed Oct 22, 2025 11:26 pm This may upset some but I feel in a few years it will be possible to produce something almost indistinguishable from a 25 year old scotch within a very short period of time. You start with clean ethanol and just have a machine mix in the appropriate esters etc. ie you are duplicating the chemical composition of a finished aged product cutting out everything else. I would note however the possibility of doing it and the actuality of doing it will be another thing, for obvious reasons.
Seing as we have derailed, lets throw some flaws and spanners into it.. someone will always think the other is better.
Diamonds where commercialised in the late 40's/50's that became the rage, in the 70's they made lab grown perfect gem quality diamonds..
Now the argument 8s there no good because their to good without flaws...
Record > Caste > CD
VHS oe Beta
CRT > Plasma > Oled...
Petrol > EV
yada yada... I'm of to Church for confession..
Interesting the direction this thread has taken. I am not against someone discovering a way to speed up aging not sure where or how it will occur. I would like to see the small craft distilleries able to compete with the larger companies. I would think (or hope) that it would bring down the price of a good whiskey.
scubatech
Post by scubatech »
I think the playing field will be leveled quicker than people think. Mankind's knowledge was doubling every 13 months and is accelerating exponentially. AI will speed that up to where it will eventually be every 72 hours or less.
Right now the barrier for most craft distillers is still financial but that will change.
Tammuz
Post by Tammuz »
MooseMan wrote: ↑Tue Oct 14, 2025 9:34 am
If she wins you could always buy an oiless compressor which would allow you to pull vacuum also. Set it up with a timer and air valves and it would be automatic. You could push and pull all day long.
HeyBroChuckNorris
airhill wrote: ↑Wed Oct 22, 2025 11:26 pm The fact that high intensity light will speed up chemical reactions is correct, unfortunately the rest sounded like a publicity gimmick. :)
Can you elaborate on what spectrum of light helps speed up reactions? Any particular wavelengths that are most effective? Just out of curiosity
