MCT Oil to add Body to Neutral, with health benefits.
decoy
Post by decoy »
MCT Oil or "Medium-Chain Triglycerides" is a Coconut extract.
It is available from supermarkets as a health supliment.
It is used to induce Ketosis like in the Carnivor or Aitkens diet.
It is a clear flavourless oily liquid with a very slight coconut flavour with a consistency of glycerine.
Add MCT Oil to your neutral for some body and make it a Keto friendly drink.
This is an interesting concept... you can repair your liver while you destroy it..
Google for
MCT Oil + Ethanol?
MCT oil is soluble in ethanol, which can be used to create homogeneous mixtures depending on the concentration. Ethanol acts as a solvent for MCT oil, and this property is used in some applications like creating submicrometer particles or in food/cosmetic formulations.
Research has also explored the combination of MCT oil and ethanol in biological studies, particularly regarding liver health.
What Is MCT Oil?
MCT oil is made from coconut or palm kernel oil through a process called fractionation, which refines the oil to isolate and concentrate the medium-chain triglycerides (MCTs). This process removes other fatty acids to create a more potent and pure MCT product.
bluc
Re: MCT Oil to add Body to Neutral, with health benefits.
Post by bluc »
Wouldn't this louche cant imagine oil being a good solution for body in spirit 🤮
decoy
Post by decoy »
bluc wrote: ↑Mon Oct 27, 2025 5:44 pm Wouldn't this louche cant imagine oil being a good solution for body in spirit 🤮
Its a funny oil, you have to try it, its flavour and texture are sort of nonexistant its not like an oil.
bluc
Post by bluc »
I have some will experiment.
Homebrewer11777
Post by Homebrewer11777 »
Curious to hear your results. Seems like it will be hard to get to a drinkable proof without the oil separating.
Pure Old Possum Piss
Post by Pure Old Possum Piss »
Doesn't glycerin do the same thing but without a coconut taste?
decoy
Post by decoy »
Pure Old Possum Piss wrote: ↑Tue Oct 28, 2025 3:49 pm Doesn't glycerin do the same thing but without a coconut taste?
Yes, thats the normal go to.
You can barely taste the coconut in MCT when you down a whole tablespoon.
MCT trigers Ketosis even when you have carbs, for an oil its 100% soluble in ethanol and studies indicate health benefits with liver, if thats possible.
But if you are on a carb free diet, you can combine the goodness.
