First Time , using corks.
planohog
Post by planohog »
I ordered some corks for a few containers that I had. I found I had to put them in much further than I expected to keep from leaking. After some local storms I found a cork in the yard, figured that was weird, well one of the containers spit the cork out, nothing bad happend , maybe for 24 hours , angel share maybe . Im not sure about the cork idea, maybe if you were going to age over 5 years , my hooch never lasts that long. Drink some , gift a bunch. Its always a treat to hear someone say you have a good drink. Always experimenting here. I moved my stash from outside to inside, Im expecting much more barametric swings going in to winter and not so much temperature swings. My first popped cork.
Re: First Time , using corks.
Don’t push the corks in tightly. If they can breathe a bit, pressure changes won’t pop them and they will allow some O2 into the jar to assist aging.
MooseMan
Post by MooseMan »
I also don't push corks in hard on my aging vessels, so most of them weep when I give them a swirl.
In fact I've run out of corks anyway, so some of mine just have a wad of cotton to plug the top!
Homebrewer11777
Post by Homebrewer11777 »
^ what NZChris says. I like my corked one gallon jugs a lot. Leave the cork dry and don't push it in, just drop it into the opening to keep bugs out.
jonnys_spirit
Post by jonnys_spirit »
These widgetco corks work well for me with jugs and jars. No popped corks..
Cheers,
jonny
Plus 1 on the widget I corks you can buy most sizes very handy for larger jars.
jonnys_spirit
The ones for the quart mason jars are a bit loose but I find that with a little time they form a bit and seal adequately (it would leak if I shake it but for aging it works well)... The larger/wider ones do appear to be laminated or "stacked" and I've had zero issue with them being constructed in that manner.. I also have some that fit wide mouth gallon jars which are nice when I don't want to chop down a stave to 3/4 x 3/4 and keep it's original width..
Cheers,
jonny
8Ball
Post by 8Ball »
I cut a small groove on my corks to allow for air exchange in my aging jugs. Works well.
subbrew
Post by subbrew »
corks breath even when tight. Wine corks are pretty tight but still breath enough to allow a good red to age. Loose cork probably speeds aging.
Deplorable
Post by Deplorable »
8Ball wrote: ↑Wed Oct 29, 2025 8:28 am I cut a small groove on my corks to allow for air exchange in my aging jugs. Works well.
+1 All my corks are slit up the side to allow it to breath a bit while the jug is on the shelf.
planohog
Post by planohog »
ok this is great news, i will not think in terms of sealing to keep liquid from escaping.
