9 gallon stainless "Firkin" aging vessel
MooseMan
Post by MooseMan »
I don't actually have my grubby mitts on it yet but I've found and agreed to buy a used 9gal stainless "Firkin" similar to this:-
I've been on the lookout for one for a couple of years, my original intention being to use it as the first vessel in a partly automatic Solera system.
I had a vision in my head, of the next vessel in the Solera being a 4.5gal version of the same cask, joined together with soldered stainless tubing and Tri clamps so that the two are sealed and the smaller one would gravity fill whenever the top, larger vessel had it's shive removed to top it up, releasing the vacuum.
This could all be madness from a delusional mind though, or would it actually work?
Then below the 2 joined vessels, more simply a couple of final 2gal or even 1gal vessels to bottle from.
But, since I've waited so long just for this one, I think I might use it right away after cleaning and keep planning the Solera in the background.
Does anyone else here use this type of "Keg" (Cask) for aging?
Any tips, troubles?
Edited:
To add a really shitty drawing explaining my auto fill idea
Homebrewer11777
Re: 9 gallon stainless "Firkin" aging vessel
Post by Homebrewer11777 »
Why a stainless tank for aging? What are you aging and why does this seem like it would do a good job in terms of oxygen exposure, angels share etc?
The hard plumbing for filling the solara seems unnecessary complication and expense. Might be cool to see it work but awkward if you ever need to move it and would take up more space than the solara really needs to.
NormandieStill
Post by NormandieStill »
I had a plan for a glass and wood solera. The idea came about when The Baker and I were hashing out a plan for making a glass version of a Badmo by clamping the wood to the jar. I then thought about making multiple vessels on one single plank, before having the idea of having the plank standing vertically (well, at a slight angle) with the jars forming a sort of staircase up it and hard plumbing connecting them on the opposite side. A steampunk-styled decorative solera system. I wouldn't necessarily auto-fill, but would have valves and possibly multiple routes to allow various mixing (and also to look cool!).
Time and budget contraints have so far nixed the idea, but I hold out hope that I'll get to it at some point.
Tammuz
Post by Tammuz »
Having a sealed keg would allow you to automate an oil less compressor. You could add air(pressure)which would push you distillate into the wood,then later have it pull a vacuum with would pull it out of the wood. This also allows you to add/pull wood from your vessel, different types of wood, and a bag of charcoal. Or as we are trying now adding dehydrated fruit to a batch of mediocre rum.
Igitur qui desiderat pacem, praeparet bellum or party till the cows come home!
PalCabral
Post by PalCabral »
Homebrewer11777 wrote: ↑Thu Oct 30, 2025 4:03 am why does this seem like it would do a good job in terms of oxygen exposure, angels share etc?
Angels share is hardly a sought after effect when aging? Rather, it's a consequence of wood aging, but in itself it's no benefit to aging, just loss. Or?
But I agree with the question why not wood? Are you planning to use oak sticks/cubes in the kegs, Moose? It's more a liquid dispensing system than a solera? We are missing the big picture.
MooseMan
Post by MooseMan »
Thanks for the input gents.
The gravity/vac thing works in my head because it will pull a vacuum when I open the tap at the bottom. This will create negative pressure in the head of the top (Largest area) vessel and potentially increase the transfer of spirit through the wood in there as it does so.
I would use a pretty std aging protocol of 1 stave or a little less, per litre of spirit. Using a mix of toasted/charred/infused white oak.
When I then remove the shive at the very top, it will lose all vac pressure and fill with air as I top up.
I would still consider it a Solera since there will be two separate aging vessels joined, with the larger one feeding the one below it, then separate vessels afterwards, being smaller again with RO water added to lower proof.
But I suppose there is a flaw in that there can be some natural interchange from vessel 1 to 2, through the pipework unless I add valves.
Homebrewer11777
PalCabral wrote: ↑Thu Oct 30, 2025 10:50 am
Fair enough...angels share is a consequence not a goal..however the angels share lost is replaced by air (especially oxygen) from outside the barrel at a hopefully slow and steady rate.
I suspect that slow exchange of barrel contents for air matters when it comes to the aging. Probably better discussion for one of the accelerated aging threads but it seems clear that a sealed container with wood and spirits in it ages differently than a barrel or other container that facilitates a slow ingress of oxygen.
tommysb
Post by tommysb »
MooseMan wrote: ↑Thu Oct 30, 2025 11:38 am But I suppose there is a flaw in that there can be some natural interchange from vessel 1 to 2, through the pipework unless I add valves.
Just stick a valve in the pipe between the two vessels!
MooseMan
Post by MooseMan »
tommysb wrote: ↑Fri Oct 31, 2025 7:06 am
Yeah I probably would have anyway tommy, for ease of use and setup etc. It's just concept stage at the moment.
I'm planning to collect the vessel Monday/Tuesday.
I dunno Moose , it just looks like a bad way of aging ……and a good way of pre-heating for a stripping run …iff’n you had a condenser coil in it
Aging in a SS barrel … not getting it
tommysb
Post by tommysb »
I KIND of get it - I guess the idea is 'some age, without too much oak'. Is that right Moose?
I have done some ageing in small newly-coopered 30l barrels, roughly the same size as a 72 pint Firkin. After a few months, the first draw from them was over-oaked to the point of being undrinkable without being blended back into something else - I cut it with more newmake. but it still wasn't great.
I can see some use in stainless in a hybrid part-wood, part stainless setup. In a 2-barrel setup, one oak, one SS, you wouldn't have too much oak. I don;'t think it matters if you had oak or stainless as your final vessel, but I would probably do oak, with stainless above.
If you filled the whole system (2x 30l), and left it for 6 months, you would have some over-oaked stuff in the wood barrel, and some aged, but not oaked in the SS, with some nice oxygenation effects on the oak portion. Blending half the oak back into the stainless, and half the stainless back into the oak, and leaving another 3 months you would probably have something very nice in both barrels. From there, you could start to draw off the bottom, and refill the top stainless. At some point, you could add another new oak barrel above, and now just run it as a nice 3 barrel solera. The over-influence of the new oak barrel would be reduced by the time it reached the bottom barrel, and from therein you would probably have a VERY nice system bringing complexity from the different barrels.
MooseMan
Post by MooseMan »
Yummyrum wrote: ↑Sat Nov 01, 2025 4:16 am I dunno Moose , it just looks like a bad way of aging ……and a good way of pre-heating for a stripping run …iff’n you had a condenser coil in it
When I eventually get around to building a dedicated pre-heater Yummy, it will be a pretty big one, since my main boiler is now 100lts so a 9gal would be too small. (The other 100l keg is STILL in the bushes where I got mine from, by the way, crazy)
I see what you're saying though, it's not ideal, but it's what I can get right now.
MooseMan
Post by MooseMan »
tommysb wrote: ↑Sat Nov 01, 2025 5:47 am I KIND of get it - I guess the idea is 'some age, without too much oak'. Is that right Moose?
Yes I could splash out and buy one of those 30l barrels, but I repeatedly hear the same story, over oaking.
I've been really happy with my product aged in glass with wood staves up to now, but I do need some bigger vessels as I'm running out of glass and have already run out of corks!
I have 2 SS pots that are contenders for 10l Badmo style clones ready to go, but when I saw this SS cask with the secondary port in the side, for sale cheap and local, it revived the idea of a Solera.
MooseMan
Post by MooseMan »
Ok I got the cask.
It's a "Pin" so approx 17lts or 4.5 gal.
It came with a plastic shive, and a knock in oak tap to go into the keystone.
I got them both out, plus the keystone liner, cleaned up the stainless and dug around in my fittings box.
I found a stainless threaded tri-clamp adapter that I rescued from work (Couldn't be used due to a non sanitary weld)
As luck would have it, it sort of fitted into the keystone hole!
I cleaned and pickled the welded fitting, made a couple of solder rings to sit on the lip at the bottom of the hole, and it soldered up nicely.
I already had some Oak shives, so once I've given it a good clean (It's sitting full of water for a long leak test) I'll fill with bourbon tomorrow, add the oak from the Demi's and pop a shive in.
I'm very pleased with how easy it was to convert to a useful aging vessel with a Tri clamp fitting for sampling and decanting when needed, so now I'll be looking much harder for more of these!
I'm even tempted to spray paint it and start my own colour scheme.
MooseMan
Post by MooseMan »
Got it fully cleaned and filled today.
I placed it right in my way on a bench, so that I have access to regularly decant a litre or more and pour it back in through the top, in order to get plenty of aeration and agitation.
As its on a stand with a bit of angle, I got just over 15lts of my corn&oat Bourbon in there, with a nice mix of old & new, toasted, charred and wine caramelised staves at roughly the ratio of 1 stave per 1.5 litre at 62abv.
Now for the wait!
