Changes to the Rules to allow Silicone .
Forum for the discussion of any material/synthetics.Only posts with info /or links to research info allowed . Any posts recommend the use of any material without copy's or links to show proven research will be deleted
Home Distiller Forum , since it’s inception , has always strived to be a place where members and their family can enjoy the rewards of crafting their spirit in a safe and sensible way. The safety of our members and their familys have always been high priority in our aim to one day see Home Distilling legalized.
Part of this has been one of our rules to exclude all plastics and synthetics as at the time , little was known on the long term effects .Two decades later , we have reevaluated our stance on this.
The Moderation team have decided to change the Rule i to include the use of Silicone .
"Safety first and foremost! These forums take a very strong negative view on the use of plastics and synthetics in distilling. It simply is not safe to use these during any part of the distillation process with the exception of HDPE buckets which are acceptable for fermentation. There simply are too many types of plastics and a lack of reliable information for us to reliably advocate their use anywhere in the distillation apparatus. Also, from past posting history, this topic seems to quickly boil down into an almost religious flame war. Silicone and Teflon (PTFE) seals, gaskets and bungs sourced from reputable suppliers are accepted and can be discussed. There will be a wide range of beliefs and practices - keep your manners about you, and take it to private message if you must.#
This may come as a surprise to many members but we are aware that rule was made many years ago when Silicone was in it's infancy.
The Professional Distilling industry has been using Silicone products for many years now with no issues .All vendors of Home Distilling equipment include Silicone Gaskets and seals as standard . Lids on Boilers have always been sold with silicone seals and have shown no signs of degradation over the years . Modern Platinum Cured silicone sheet and tubing is of very high standard.
So, we have decided that it is only fair to change our stance to allow such material to be openly seen and discussed on this forum without penalizing members .
Home Distiller Forum does not advocate the use of Silicone .We are saying if you choose to use it , we are now OK with that .
Where Teflon is still practical to use , by all means please use it as the preferred option .
To clarify ,tri-clamp gaskets , silicone bungs , boiler lids that have a silicone seal , sheets of Platinum Cured Silicone for making custom gaskets and Platinum Cured Silicone hose are accepted.
It is Not OK to buy a tube of Silicone from the hardware store to seal up leaks nor is it ok to construct stills by joining components with a tube of Silicone .There are simply too many varieties with questionable additives . Any discussion of this will be actively moderated as in the past .
There will be no discussion of the inclusion of any other synthetic materials, period.
We recommend buying from reputable suppliers where possible to ensure the highest quality . Do not ask us if a gasket from supplier X is OK to use or not . If you feel uncomfortable about it , don't use it.
We understand that this is a personal choice . Please be respectful of each other’s right to choose either way .
Re: Changes to Rules
Please be nice .
PalCabral
Post by PalCabral »
I for one applaud the forum’s strict rules for safty but also that these can change when applicable.
May I add that I have read that silicone destined to be used in distilling can be soaked in neutral high ABV alcohol for 4 hours before use in order to leach out any unwanted material. This is at least a recommendation I have read when I researched the differences between silicone vs pfte myself.
I cannnot vouch for the efficiency of such a protocol but it seems like a easy step to include before use, if you’re still concerned about the use of silicone. Most of us will have neutral alcohol available and if a four hour soak lowers any concern you have, what damage does it do?
Salt Must Flow
Post by Salt Must Flow »
I'm not really surprised with this rule change, but I respect the previous rule.
I have always tried to use PTFE gaskets as much as possible, but have run into repeatable leaks especially with welded joints. Depending on the skill of the welder, warping of Tri-Clamp ferrules can occur. Since PTFE gaskets are so hard they have minimal compression. They cannot conform to irregularities to seal even slightly warped jonts. I have only use silicone gaskets to solve that issue where it exists. PTFE Envelope Gaskets exist, but are quite expensive. For that reason I've never tried them and have no idea if they would actually seal warped joint. If the price drops on PTFE Envelope Gaskets, I'd be happy to use them to replace silicone gaskets. Wrapping silicone gaskets with PTFE tape has always been an acceptable option if people are concerned using silicone gaskets.
Last edited by Salt Must Flow on Thu Nov 20, 2025 11:47 pm, edited 1 time in total.
Copperhead road
Post by Copperhead road »
I was totally unaware that silicone is acceptable on the forum now. I have read there is silicone tube that is platinum coated design for high proof spirits but I thought this was still a NO NO.
The rule change might be seen as an endorsement for the use of silicone.
An industrial gasket supplier did my research for me and advised me not to use it, so I never have.
Salt Must Flow
NZChris wrote: ↑Thu Nov 20, 2025 11:23 pm The rule change might be seen as an endorsement for the use of silicone.
Did you ask why? If so, what what was their reply?
Salt Must Flow wrote: ↑Thu Nov 20, 2025 11:49 pm
I wanted to know what to use, not his reasons for not recommending each of the many other materials he might have offered. He knew I was hoping silicone was ok.
kennstminet
Post by kennstminet »
I welcome this rule change and consider it necessary and helpful.
GrumbleStill
Post by GrumbleStill »
A big thanks to the moderation team for a well researched and considered change.
Tammuz
Post by Tammuz »
People that were banned for talking about silicone should be reinstated.
Igitur qui desiderat pacem, praeparet bellum or party till the cows come home!
ShineonCrazyDiamond
Post by ShineonCrazyDiamond »
Tammuz wrote: ↑Fri Nov 21, 2025 9:12 am People that were banned for talking about silicone should be reinstated.
Not how it works. We commit to you to be fair and do what's best for the community and legalization. You commit to follow the rules as they are currently written at the time you are here. No one was banned for talking about silicone. People were banned for continuing to discuss it while already personally informed it was against the rules. Or for being disrespectful about their different views.
Shine on you crazy diamond."
Homebrewer11777
Post by Homebrewer11777 »
My guess would be that people that were banned "for talking about silicone" were really banned for being unable or unwilling to make an effort to just follow the rules.
I've felt the rule was not all that logical given the commercial offerings but it was not really difficult to just follow the rule.
jonnys_spirit
Post by jonnys_spirit »
I'm a belt and suspenders kinda guy - or maybe in this case a silicone and ptfe tape kinda guy.... probably not gonna change at this point but appreciate the moving forward... I'm personally still skeptical about high temp high proof long duration contact without some more specific scientific'ish validation under those conditions...
I know that the commercial industry also delivers high volume likker in totes which I can't personally get behind either...
Cheers,
jonny
MooseMan
Post by MooseMan »
jonnys_spirit wrote: ↑Fri Nov 21, 2025 10:39 am I'm a belt and suspenders kinda guy - or maybe in this case a silicone and ptfe tape kinda guy.... probably not gonna change at this point but appreciate the moving forward... I'm personally still skeptical about high temp high proof long duration contact without some more specific scientific'ish validation under those conditions...
Cheers,
jonny
I'm sticking with PTFE, since I've developed methods to use only that, to seal anything in my stills that I need to seal.
As for the commercial industry, they put everything from bottle proof spirits all the way to 96% neutral into ton plus IBCs that are made from HDPE, which doesn't sit right with me either, but its not hot vapour to be fair
Homebrewer11777 wrote: ↑Fri Nov 21, 2025 10:13 am
That's really key.
One of the intended purposes of the rules is not only to moderate internal discussion. But to also illustrate that this is a responsible, safety oriented community to any regulatory entity that might pop in on occasion to see what the community is up to.
It is the strict adherence to many of the rules that likely provide more credibility and breadth of information here than any other past or present beverage alcohol internet community.
Members and non members alike are free to come and go as they please, take as much free info as needed. Its all here. Its just ya gotta follow the rules. Not really that difficult.
bluc
Post by bluc »
Good stuff i was worried my final continuous setup wouldn't be posted due to silicone needed in reflux return perstaltic pump head. :thumbup:
Go for it bluc :thumbup:
This is something that could never be done in the past . I think Windycity on his side by side columns used a very expensive Stainless gear pump simply to avoid using synthetics where now you can use a short length of quality silicone hose in a Parasteltic pump . This makes it much more affordable to all.
I’m gonna come out of the closet and admit that I have been using Silicone gaskets for years . This does make me feel a bit of a hypocrite being a Moderator . But , I followed the rules and never mentioned it . Personally , I believe that it is a choice we make . I use Silicone were there is no alternative , but I use it sparingly . I am not 100% sure that it is 100% safe ,and to be honest , I am not 100% sure about Teflon either , so I would in the case of bluc’s pump , use it in the pump where it is a short section .But I would not want to have meters of it running back up to the column next to it when I could use a copper or stainless tube .
I guess what I’m saying is to be as safe as possible , use the minimum to reduce the exposure .
All we have to go on is Chemical compatibility charts . It is interesting that the older charts don’t rate silicone very well . ( Which is why NZChris's gasket guy told him it was a bad choice and why HD never approved of it either) .
Newer charts for the Platinum cured Silicone rate it much better.
However the charts rarely mention concentration or temp .You are only to assume they mean 100% concentration .So with Ethanol at Azeo , what the chart says is quite relevant , but when we look at Acetone , Silicone has a bad rating .If we consider how little Acetone there really is in a run , the actual exposure time is very minimal ……my own risk assessment of it convinces me it will be OK . Surprisingly Silicone has an excellent rating for Methanol :ebiggrin:
I do like the advice on Stilldragon website to check gaskets and ideally replace them every two years .None of mine have ever shown any signs of deterioration but I should replace them .
I suspect there have been many builds that were never able to be seen here before for because they contained Silicone .
On the other hand because of the Silicone ban , builders on HD forum have really thought up some very creative ways to overcome this such as the teflon tape wrapped cardboard everlasting gasket or Shady’s string wrapped plate seal.
Don’t take this as a dumbing down of HD forums amazing creativity that have pathed the way forward in Home distilling , rather , maybe open the doors to new innovation that previously may have been too inaccessible .
The only thing that has really changed is the rule about discussing it.
Looking at chemical compatibility charts, I notice that it doesn't get an A, or a 1 for ethyl acetate, which you should all be familiar with as it is one of the first VOCs out of your still. None of the compatibilty charts I found today said how the ratings were arrived at. In the past, some of these charts quoted times and temperatures that were used in the evaluations, but I made the mistake of not downloading them while I had the chance.
airhill
Post by airhill »
I think more to the point is if for example you use silicone seals on say a boiler or joints in a column would it be able to follow through with the vapour into the product (I doubt this but if anyone could point me to any literature I would be interested).
I regularly dose stripped runs with sodium carbonate and it ends up in the boiler when I do my final run. Lets face it its not something you would voluntarily drink, but it stays in the boiler. This was just an example to demonstrate a point. :)
In the universe there are no absolutes; only degrees of uncertainty.
I suspect that questions about it's suitability for distillation, fluid transfer, and seals for long term aging, all have different answers.
This Chem compatibility chart for Platinum cured Silicone has Ethanol as A , Ethyl acetate as B , Acetone as C , Butanol as B and Propanol as A . Methanol as A . Lord forbid Amyl acetate is a D :esurprised:
It is at 21°C .
https://blog.darwin-microfluidics.com/s ... atibility/
I have to say , this chart makes me feel much more comfortable than some of the older charts .
Lets put it into some perspective .
The Rum bums love esters …. All those VOC ( volatile organic compounds) ….. such as Ethyl acetate ( fruity ) and amyl acetate ( bananas ) .So surely , if ever there was a distilling product that would attack the Silicone it would be Rum .
A bland Rum has esters of around 50 PPM ( parts per million )
So that means we are looking at 0.00005 or 0.005% of the Rum contains things that might have a slight effect on the Silicone .
Even a really high ester Rum something that is so putridly strong , you’d not drink it , let’s say 1000 PPM will have 0.1% nasties .
Yes , you can say that Silicone is not so good with Ethyl acetate and much worse with Amyl acetate but the actual amount of it in a run is so small that it’s effects would be minuscule …..In my opinion :ewink:
Once a silicone seal has been compromised by the VOCs that it does react with, is it still as safe with ethanol and other VOCs as it was prior to the damage? I don't know.
Another consideration is the contact time and the area exposed. At hobby scale our products have much more contact time with the exposed surface area compared to the likes of a large commercial distillery. Does that make a difference? Possibly. I don't know.
Does your manufacturer/supplier have recommendations for how long their seals are safe to use for your application? If they do, know what they are and replace them when they say you should.
Maybe someone should start a Silicone thread so that we're not discussing silicone on a thread about a rule change?
Or change the thread title to 'Changes to rules about discussing silicone'?
Deplorable
Post by Deplorable »
Yummyrum wrote: ↑Fri Nov 21, 2025 11:37 pm
Considering the number of micro-plastics the average person ingests, I have to agree, that any miniscule amount that might carry over in distillation is almost insignificant, but that doesn't mean one still shouldn't take all the necessary precautions to eliminate all the chemicals you can.
IAmPistolPete
Post by IAmPistolPete »
I applaud the Mods for looking at this subject objectively. As in Yummy's admission above, I suspect there a large number of members here [self included] that have been using at least some silicone gaskets all along & kept the dirty little secret. I have a mix of PTFE & silicone for different setups & configurations & never had an issue other than some discoloration & was replaced after a few years.
At least it's 1 less reason for HD drama. :moresarcasm:
If you ever find yourself being chased by a pack of wild taxidermists, do not play dead.
Homebrewer11777
+1 to Chris's suggestion for a silicone thread.
Homebrewer11777 wrote: ↑Mon Nov 24, 2025 5:36 am +1 to Chris's suggestion for a silicone thread.
You both know how to .
In the mean time I will change this topic name .
Re: Changes to the Rules to allow Silicone .
I don't use it and don't have a dog in the race, so I'll leave starting a thread about it to someone who does.
Zacher
Post by Zacher »
I did a bunch of research on commercial uses and determined that the silicone gasket I was using on my boiler was just fine. I just didn't talk about it. I applaud the mods for their flexibility and keeping up with technology. If you don't want to use it, don't.....
