My First Ever
CuriousRay
My First Ever
Post by CuriousRay »
Hi,
Using the water distiller that I appropriated from my wife...
Last week I did a quick run making low wines @ 40% ABV. Today I made a "spirit run" using a voltage regulator. These are my results:
test batch.pdf
I have 18 100ml jars but ran out of jars at the end. I can definitely see (smell) a difference at the beginning but am not sure at the end. I will wait a while and try again later as maybe my nose isn't sensitive enough.
I haven't tasted yet but will do so when I have made some distilled :tired:
I think that a 37% yield is pretty good. I tested what was left and it was only about 5% even though everything I extracted was above 50% ABV even at the end.
Happy
GrumbleStill
Re: My First Ever
Post by GrumbleStill »
Congratulations on your 1st run mate. Well done.
Just out of interest, what was it that you were making?
CuriousRay
Re: My First Ever
It was a test made from a failed wine, so no plan apart from trying to distil something. If I remember correctly was 23ltrs of a 11.5% ABV blueberry wine.
I am currently making a sugar wash for my next experiment but my goal is rum and I'm planning for that but it probably won’t happen for a few months. I will run a few sugar washes through first as I want to understand how to use what I have before I go and spend money on ingredients :)
Re: My First Ever
Have you had a taste yet ?
If you have a taste of the middle jar and then go straight to the end jar you will clearly see (taste) the difference .
Always dilute the sample down to about 30%ABV before tasting .As a general rule for double distilled from a Pot , add 2 parts water to one part spirit will get you close enough . Use less water as you go further into tails .
30xs
Re: My First Ever
Post by 30xs »
Being a water distiller I’d be concerned with possible plastics in the vapor path.
CuriousRay
Re: My First Ever
Yummyrum wrote: ↑Sat Jan 17, 2026 7:35 pm Have you had a taste yet ?
I did taste it (diluted). I couldn’t really ascertain if there was a difference at the tail end. This could be because I ran out of glassware and it smeared at the end but I think I will have a better chance with a neutral.
I decided to dump the batch, make a sugar wash and buy more jars. Hopefully this will be neutral enough so that I will be able to taste the difference between heads, hearts and tails without the interference of a flavour and smear.
30xs wrote: ↑Sat Jan 17, 2026 8:27 pm Being a water distiller I’d be concerned with possible plastics in the vapor path.
Stainless steel all the way through with a silicone gasket. Thanks
Re: My First Ever
Is it an Airstill or Vevor copy ?
CuriousRay
Re: My First Ever
It's a CO-Z logo'd thing rated at 1750w. It will be the same body and condenser as the Vevor just with a different logo.
If you order enough from the factory they will OEM or ODM and logo it whatever you want AND give you your own colour for free.
Yummyrum logo'd distillation machines in dayglow orange :)
