Large Batch Plastic Mash-tuns?
Appelle22
Post by Appelle22 »
Hello all,
Ive been contemplating moving up from making several time-consuming small mashes to one larger one, however upon doing some research of the available food grade barrels its seeming that all the ones I can find are incapable of handling Gelatinization temperatures. Most capping out at either 120F or 150F. HDPE Barrels from ULINE to be specific.
Is this something that anyone using these Barrels is aware of? Im concerned of the safety implications of high heat usage of these barrels but see so many people using them. Id like to step up to those sizes of mashes but safely and without spending 700 dollars for a stainless-steel drum.
Any and all input would be greatly appreciated!
"Blessed are those willing to learn, for they have taken the reigns of their path into their own hands."
Re: Large Batch Plastic Mash-tuns?
Can't comment of Mashing but I have two different 200Litre ( US 55gal ) HDPE barrels and I often 1/4 fill them with boiling water or a mix of boiling Dunder and water and they don't wince while I'm mixing in the Molasses .I've been using them for nearly 10 years now and they show no signs of distress .
But I don't know about an hour at 90degC full of corn
Bolverk
Post by Bolverk »
Ive got the 63 gal hdpe pickle barrels, i routinely dump 210f water over corn with zero issues. No softening of plastic at all.
planohog
Post by planohog »
Eagle 30 Gallon Plastic Drum with Lid, works great with 214 water poured in. , it acutally cools off really quick to 180F , I need to insulate mine much much better. I typicall have corn meal or ground corn in the bottom .
Homebrewer11777
Post by Homebrewer11777 »
I think it is fair to wonder about the potential for chemical leaching out of the plastic. ULINE marks theirs as not suitable for storing water. I believe this means they don't want to go to the trouble or expense of obtaining and maintaining NSF/ANSI 61 certification for their barrels. Other vendors at that price point do suggest they are suitable for storing water but none of those seem to claim certification. FDA seems to safe for storage of dry food.
If you care about things like this I did find an interesting source of stainless barrels here:
https://www.bubbasbarrels.com/catalog/s ... ed-drums-0
$200 plus shipping (estimated to me was $100) gets you a 16 gauge 304 stainless barrel.
zach
Post by zach »
I also like stainless. I would look at used options. I have found some deals over the years.
https://eugene.craigslist.org/grd/d/eug ... 89012.html
I use 88 liter milk cans for mashing, ferment on grain then steam stripping in the same container. I can lift and dump at this size after scooping out some of the grain and draining the liquid.
If I went to 55 gallons, I would weld a manway to the barrel so I could dump the grains rather than scoop out the top. Kind of hard to do with plastic.
