My first dunder bucket
CuriousRay
Post by CuriousRay »
I'm still only fermenting and distilling sugar washes but I have an itch then needs scratching so I decided to make mydelf a dunder bucket. I may even make myself a rum wash in March so I have something to add :)
MooseMan
Re: My first dunder bucket
Post by MooseMan »
There's nothing like being prepared Ray! 😂
CuriousRay
MooseMan wrote: ↑Tue Jan 27, 2026 11:46 am There's nothing like being prepared Ray! 😂
I learned that from a girlfriend that I went out with 40 years ago. She was always prepared.
howie
Post by howie »
good work ray.
curious, what does the offset tube do?
my taps are about halfway up the bucket to take off from the middle.
i don't know where the sludge level is on mine, and i ain't putting my hand in
CuriousRay
howie wrote: ↑Tue Jan 27, 2026 8:49 pm good work ray.
It holds the pipe vertically against the side of the bucket and stops it moving around. It was a bit too wobbly for me.
The tap is a sediment tap so it should only drain horizontally. I am not sure if it's the correct height but it's a transparent bucket so I should be able to see the sediment level. If it's wrong I can change it. I only plan to use two or three litres as a time as my fermentation buckets are 30 litres, so I am hoping it will be adequate.
planohog
Post by planohog »
Good Job, this is part of the fun and education here, you get to experiment and make your own parts.
Post by Novice »
It's easy to add an elbow and go up 4" on your drain, if needed. Maybe on your next one a larger opening on top.
I like it Curious Ray .
But I’m curious what the brown big “D” is on the lid ?
Small pouring hole is OK , I guess it means you pour stuff in slower so it doesn’t stir up the crap on the bottom so bad .
As for the crap that settles , I’d get maybe 1/8 “ to a 1/4” of sediment in a 20litre pale . I guess it would build up in time , but yiu could syphon it up if you thought it was getting close to the outlet , but Novices’s suggestion above to put an elbow on it to raise the draw height makes perfect sense . :thumbup:
howie
Post by howie »
Yummyrum wrote: ↑Wed Jan 28, 2026 10:27 pm I like it Curious Ray .
i thought it was a mesh siliconed into the lid?
CuriousRay
It's a mesh glued onto the lid. I cant remember what the glue is called now but it is food grade. I don't know why it went that color, maybe age (I've had it quite a while) I could take it off and reseal with silicone as howie mentioned though.
Small pipe as I will use a funnel to fill, I don't plan on making too much and it's an experiment so I can always increase the bucket size and amend the tap position if needed.
CuriousRay wrote: ↑Thu Jan 29, 2026 10:13 am
Doh , yeah I can see that now when I clicked the pic to make it bigger on my phone . Christ I must be loosing it . I was wondering how you expected it to get mouldy in a sealed bucket and didn’t even put two and two together .
Having said that , buckets of Dunder grow mould on them in sealed buckets after several months anyway . But not at the same rate as open .
Tammuz
Post by Tammuz »
As mentioned above, having a larger opening with a wider mesh would help collect wild yeast and bacteria quicker.
Igitur qui desiderat pacem, praeparet bellum or party till the cows come home!
